leebo 12 Posted March 7, 2014 Posted March 7, 2014 I'm not sure what relevant facts to include about this issue. I have several BR rips on my HDD in a MB watched folder. The web and Roku clients have no issues playing these. However, when trying to play them using Classic in WMC, there is no audio (through HDMI) When played through my computer speakers through the analogue out, I get very fast clicking noise. Additionally, at least one BR (Riddick) starts playing from a point about 5 mins into the film. I notice with Classic here is no way to select different audio tracks, and no way to select ANY subtitle. I am running Windows 7 SP1, connected to my flat screen with HDMI (windows mixer shows no activity on it's VU meters when playing these titles to MBC). MB Classic ver. 3.0.129.02-12.2 I can always install MB Theater, but I like the convenience of going through WMC since I use that for my TV watching. Also, I'm not sure how well Theater responds to a WMC remote.
ebr 16333 Posted March 7, 2014 Posted March 7, 2014 WMC does not support BD playback directly. When you say "BluRay rips" what do you actually mean? In what format are they? If they are playing at all they probably aren't actually BD folders anymore. I would start by installing LAV as this is certainly a codec issue of some sort. If they are actually still BD folder structures, you will need to install an external player that supports them.
leebo 12 Posted March 7, 2014 Author Posted March 7, 2014 WMC does not support BD playback directly. When you say "BluRay rips" what do you actually mean? In what format are they? If they are playing at all they probably aren't actually BD folders anymore. I would start by installing LAV as this is certainly a codec issue of some sort. If they are actually still BD folder structures, you will need to install an external player that supports them. I see. The movies in question are BR rips in their BR folder structure. I assume I would have to find an external player that is compatible with either MB Classic or WMC? I already have Power DVD9 installed, and that plays BR's. I don't know if I can configure MB Classic to use it though. But does your reply answer the question of why Riddick starts playing at about 5 mins into the movie? And does MB Classic have no way to change audio tracks?
Luke 42239 Posted March 7, 2014 Posted March 7, 2014 if you know that lav is installed you can pass index.bdmv to the player as the video path and lav will handle it. that's what mbt is doing, although it has the ability to assume lav will be present.
ebr 16333 Posted March 7, 2014 Posted March 7, 2014 Yeah, I'm not sure how to know if LAV is installed but I'll see if there is a reliable method for determining that. leebo - MBC will attempt to play the largest file it finds but this will not be reliable as you found. Basically, I suggest you rip to a different container or configure an external player. You can use PDVD but only as a generic player so you won't get resume tracking. MPC-HC is probably the best supported external but it isn't going to be very good at playing BD folders either.
pagali 62 Posted March 7, 2014 Posted March 7, 2014 MPC-HC is probably the best supported external but it isn't going to be very good at playing BD folders either. I think it should work OK if it's set up properly. See http://mediabrowser.tv/community/index.php?/topic/5330-help-with-zoomplayer-and-mbc/ and try configuring it the same as the bluray choice.
leebo 12 Posted March 8, 2014 Author Posted March 8, 2014 Is LAV a player? I've seen it mentioned several times but have not investigated yet. Sent from my generic not my computer device.
Tikuf 663 Posted March 8, 2014 Posted March 8, 2014 Lav is a set of filters based on ffmpeg (call it a codec pack of sorts)
ebr 16333 Posted March 8, 2014 Posted March 8, 2014 Since our current method is completely unreliable, I'm just going to use the index.bdmv for BD playback. It will just require LAV (or something else that can play it).
leebo 12 Posted March 8, 2014 Author Posted March 8, 2014 If I have ffmpeg installed, does that mean the LAV filters are also installed? Sent from my generic not my computer device.
Tikuf 663 Posted March 8, 2014 Posted March 8, 2014 No they are different Lav > https://github.com/Nevcairiel/LAVFilters/releases
ebr 16333 Posted March 8, 2014 Posted March 8, 2014 You should un-install any codec packs you have and install LAV instead. Much simpler and plays pretty much everything.
leebo 12 Posted March 8, 2014 Author Posted March 8, 2014 I don't install codec "packs".I need ffmpeg for a couple of video conversion programs I use. Sent from my generic not my computer device.
ebr 16333 Posted March 8, 2014 Posted March 8, 2014 Okay, then you can just install LAV and you should be good. The next version of MBC should then play your BDs fine (with no menus of course).
leebo 12 Posted March 9, 2014 Author Posted March 9, 2014 Okay, then you can just install LAV and you should be good. The next version of MBC should then play your BDs fine (with no menus of course). So no way to select audio or sub tracks then?
leebo 12 Posted March 9, 2014 Author Posted March 9, 2014 I think it should work OK if it's set up properly. See http://mediabrowser.tv/community/index.php?/topic/5330-help-with-zoomplayer-and-mbc/ and try configuring it the same as the bluray choice. I cannot find that page in my MBC config. How do I get there please?
ebr 16333 Posted March 9, 2014 Posted March 9, 2014 So no way to select audio or sub tracks then? No, the internal WMC player does not provide that capability. You would have to use an external one.
ebr 16333 Posted March 9, 2014 Posted March 9, 2014 I cannot find that page in my MBC config. How do I get there please? External player configuration is done through the MBC Configurator. A shortcut to it was installed in your start menu.
ebr 16333 Posted March 10, 2014 Posted March 10, 2014 So no way to select audio or sub tracks then? Also see this. But I'm not sure it will work with a BD.
leebo 12 Posted March 10, 2014 Author Posted March 10, 2014 Thanks. I found the configurator. It never occurred to me to look there because I thought the only settings were in the gear icon in MBC. Also I will check out the link above. Sent from my generic not my computer device.
