stankunas.justas 0 Posted November 25, 2017 Posted November 25, 2017 Just deployed Docerized Emby server. But it looks that Emby does not see my TV (Samsung Smart TV) for "play to "funkction". Also neither TV nor Laptop shows any DLNA server on the network. I have installed Emby app on TV - it works, also via Android app or web it is also ok. But i would really like to have feature "play to" working.. maybe i am missing something or there is some kind of trick? Emby server version: 3.2.40.0 Here is my docker config: emby: image: emby/embyserver:latest restart: unless-stopped container_name: emby volumes: - emby_config:/config - /mnt/md0/media-library:/media environment: TZ: Europe/Vilnius PUID: 1001 PGID: 10000 ports: - "8096:8096" - "1900:1900/udp" - "7359:7359/udp" - "8920:8920" Sent from my SM-N910C using Tapatalk
Luke 42239 Posted November 25, 2017 Posted November 25, 2017 Hi there, since you've just installed, would you mind installing this docker version and comparing: https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/page-1 Thanks.
stankunas.justas 0 Posted November 26, 2017 Author Posted November 26, 2017 Hi there, since you've just installed, would you mind installing this docker version and comparing: https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/page-1 Thanks. Oh, since it is docker i can install as many different images as needed Will do it and report back. But if i understood correctly it is only temporary docker container? Is there a way to migrate watched history? Like copy one or two files? Sent from my SM-N910C using Tapatalk
stankunas.justas 0 Posted November 26, 2017 Author Posted November 26, 2017 so i have tried to create container with following configuration: emby_test: image: emby/embyserver_netcore:latest restart: unless-stopped container_name: emby_test volumes: - /mnt/md0/system/containers/tests/emby/config:/config - /mnt/md0/media-library:/media-library:ro devices: - /dev/dri/renderD128:/dev/dri/renderD128 environment: PUID: 1001 #tried setting as UID or PUID, but no difference PGID: 10000 #tried setting as GID or PGID, but no difference ports: - "192.168.11.102:8096:8096" But it does not look to be working at all. this is what i can see in logs: These few line constantly repeats in loop in " Stdout logs": [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] done. [services.d] starting services [services.d] done. [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. and after each repeat in "Stderr logs" it is generating following entry: s6-applyuidgid: fatal: GIDLIST not set Though as per description in docker hub, GIDLIST is not mandatory and i don't even know what could be there.
alucryd 318 Posted November 26, 2017 Posted November 26, 2017 This is now fixed in the latest image, apologies for the inconvenience. Not sure why s6 would want that variable to always be filled, I'll probably file a bug report over there.
stankunas.justas 0 Posted December 9, 2017 Author Posted December 9, 2017 So i was able to deploy now "emby/embyserver_netcore" image, but it did not solved my issue. Anyway, i think i have found solution to this by changing container network to "host". After container was re-created with new network parameter emby immediately discovered my "samsung smart tv" and i could "play on" on it anything from the library. Sent from my SM-N910C using Tapatalk
stankunas.justas 0 Posted December 9, 2017 Author Posted December 9, 2017 Though it would be interesting to find why this is not working with bridge network on docker as i would prefer bridging instead of using host network. Sent from my SM-N910C using Tapatalk
