miniz98 73 Posted November 23, 2017 Posted November 23, 2017 Im getting this error. Unable to tune channel at this time. There may not be a tuner available. I know the tuners are available because they work on a browser. Running latest server on windows. This was not a problem on my mibox. My hdhomerun files are in a m3u file. Thanks
miniz98 73 Posted November 23, 2017 Author Posted November 23, 2017 Ok so i tried it on the mi box and its doing the same thing. It must be after i updated windows to the latest server. What changed?
Luke 42245 Posted November 23, 2017 Posted November 23, 2017 Hi there, please attach the information requested in how to report a media playback issue. thanks !
miniz98 73 Posted November 23, 2017 Author Posted November 23, 2017 Narrowed down the problem. If i add a hdhomerun tuner it works fine. If i use the hdhomerun in a m3u file it no longer works after the latest server update. Can i download the prior version of the server? my m3u has this #EXTINF:-1 tvg-name="CBS HD" channel-id="433" group-title="United States",CBS HD http://192.168.86.249:5004/auto/v4.1?duration=7200
Luke 42245 Posted November 23, 2017 Posted November 23, 2017 I'm not really sure why you you'd want to do that, but if you can please attach the above requested information we'll be happy to help you. thanks.
miniz98 73 Posted November 23, 2017 Author Posted November 23, 2017 the reason i do this is so i can set the correct channel number for my area. Can i download the prior version? it was working before the update.
Luke 42245 Posted November 23, 2017 Posted November 23, 2017 If you can please attach the emby server log i will review the issue and might be able to get you squared away. thanks.
miniz98 73 Posted November 23, 2017 Author Posted November 23, 2017 Here is the log file did clean install bare bones still get error log.txt
Solution Luke 42245 Posted November 23, 2017 Solution Posted November 23, 2017 This will be resolved on the beta channel shortly. Thanks. 1
miniz98 73 Posted November 23, 2017 Author Posted November 23, 2017 Thanks a million. I had to rig it today for the family to watch the parade lol
miniz98 73 Posted November 25, 2017 Author Posted November 25, 2017 Like problem still happening. Could you please give me the link to the last build where this wasn’t happening. This beta is not stable.
hcgonzalezpr 0 Posted December 5, 2017 Posted December 5, 2017 (edited) @@Luke Is the bug fixed the "System.InvalidOperationException: Nullable object must have a value" error on the server logs? Bug.txt Edited December 5, 2017 by hcgonzalezpr
Luke 42245 Posted December 5, 2017 Posted December 5, 2017 He's resolved for the next release, thanks.
