Very long connect times
Thanks for 3.2.50 - checking it out ! Will keep you posted !
1. It does seem that the connections are faster now.
2. Still not as speedy as before and, although I might be wrong, it seems that the drop in speed directly relates to the database. Even though the connection to the server is much faster now, it takes longer then before to update the database to display the assets.
Good work, though !
Edited by kaynemo
