andyblac644 69 Posted November 17, 2017 Posted November 17, 2017 i can't seem to get this working can anyone help ? this is what i get. 1
ebr 16342 Posted November 17, 2017 Posted November 17, 2017 What version of the server? Log? How to Report a Problem Thanks.
Tharnax 49 Posted November 17, 2017 Posted November 17, 2017 (edited) @@ebr - Me too! - Edited to add I'm running version 4.0.58.0 not .56 as stated in the OP but having the same issue. Server logs: Here This issue is making it difficult to determine which movie is in 3D and which isn't. Thanks! Edited November 17, 2017 by Tharnax
andyblac644 69 Posted November 17, 2017 Author Posted November 17, 2017 @@ebr sorry, once my server is finished with recording I'll re-install and get logs. Thanks Andy.
ebr 16342 Posted November 18, 2017 Posted November 18, 2017 Your installation appears to be missing the image processing library. Try re-installing from the website over top of it.
andyblac644 69 Posted November 18, 2017 Author Posted November 18, 2017 runing from docker, you don't an official docker .net yet do you ?
Luke 42253 Posted November 18, 2017 Posted November 18, 2017 Not yet but it's coming in the near future.
Tharnax 49 Posted November 19, 2017 Posted November 19, 2017 Your installation appears to be missing the image processing library. Try re-installing from the website over top of it. I'm assuming you mean the server? I don't know how to re-install the plug-in from the website. If you mean the server, I've done that. I've got two servers now for which both upgrades to 26 didn't go overly well, where I manually downloaded the latest stable version and installed it. In both instances it appears the cover art plug in broke the image processing library.
Luke 42253 Posted November 19, 2017 Posted November 19, 2017 @@Tharnax, try using the plugin catalog to install the latest compatible version for your server. thanks. 1
Luke 42253 Posted November 19, 2017 Posted November 19, 2017 @@andyblac644 since you're running from Docker we'll need to see a server log. Thanks.
