BEis 21 Posted November 16, 2017 Posted November 16, 2017 On my Apple TV 4th Gen, it seems that the graphic for the check mark has become corrupted. I'm referring to the check mark used for viewed items. Instead of a check, I see a green circle with a white box outline. The numbers are correct (for unviewed episodes) ... but any TV show that has all episodes viewed, or any movie that has been viewed, has this weird looking box instead of a check mark. I've tried reinstalling the app from scratch, and I've also tried rebooting the Apple TV. This problem doesn't occur on the web app, or my iPad or iPhone apps. Only on the Apple TV. Any ideas? Thanks, - Blake
ebr 16335 Posted November 16, 2017 Posted November 16, 2017 Hmmm.... That graphic is actually generated by the server and it may rely on a specific font on the server to do that. What is the platform of your server and has it changed in conjunction with this happening?
BEis 21 Posted November 16, 2017 Author Posted November 16, 2017 Hi, thanks for replying so quickly. My server is on a Mac Mini, running macOS Sierra. I'm actually a recent convert from Plex, and I only installed Emby yesterday. So I think this problem has been there from the start. Like I said, though, all other platforms are showing the checkmark correctly, which is why I thought it was something to do with the Apple TV.
ebr 16335 Posted November 16, 2017 Posted November 16, 2017 The Apple TV app may be the only one still relying on the server to produce this graphic. Luke, what font does he need to be sure he has on his Mac?
Luke 42242 Posted November 16, 2017 Posted November 16, 2017 There's no dependency. I'll have to test that, thanks.
BEis 21 Posted November 16, 2017 Author Posted November 16, 2017 Here's a picture of what I'm seeing, in case it's helpful in tracking it down.
speechles 2062 Posted November 16, 2017 Posted November 16, 2017 (edited) You mean webdings? https://github.com/MediaBrowser/Emby/search?utf8=%E2%9C%93&q=webdings&type= Emby.Drawing.ImageMagick/PlayedIndicatorDrawer.cs and Emby.Drawing.Skia/PlayedIndicatorDrawer.cs both appear to download the font to use. The problem looks like Emby.Drawing.Net/PlayedIndicatorDrawer.cs isn't downloading the font, but just expecting it to exist. Edited November 16, 2017 by speechles
Luke 42242 Posted November 16, 2017 Posted November 16, 2017 Macos is using skia so that shouldn't matter.
BEis 21 Posted November 19, 2017 Author Posted November 19, 2017 Any ideas on this issue? I'm still experiencing it, and although it's just a minor graphics issue, it is still annoying...
Luke 42242 Posted November 20, 2017 Posted November 20, 2017 @ what version of emby server are you running? thanks.
BEis 21 Posted November 20, 2017 Author Posted November 20, 2017 @@Luke, I'm running 3.2.36.0. The server says it is up to date...
Luke 42242 Posted November 21, 2017 Posted November 21, 2017 Ok, I think i have this resolved. It will take a couple releases though since the upcoming release has already in process of being packaged. thanks.
BEis 21 Posted December 6, 2017 Author Posted December 6, 2017 I'm not sure if this is meant to be fixed in 3.2.50, but I just updated, and it's not entirely fixed. Now I'm getting a check, but also still the weird box as well. Is there a cache or something I need to clear in order to resolve this? I rebooted, just to be sure. Also, some movies have the check and the box, others have just the box, and finally unwatched movies don't have anything (which is correct). But I can't figure out why some have just the box, and others have the check and the box. Both are indicating watched movies. See screenshot:
Luke 42242 Posted December 6, 2017 Posted December 6, 2017 You have to uninstall reinstall the app and delete the server cache/images folder
Luke 42242 Posted December 6, 2017 Posted December 6, 2017 Or just wait patiently and let the images get replaced over time.
BEis 21 Posted December 9, 2017 Author Posted December 9, 2017 I wanted to wait a bit to see if it cleared up on its own, but it is still showing the box and check side by side. Is there a detailed "uninstall" procedure, or does uninstalling simply involved deleting the app or overwriting it with a new version?
BEis 21 Posted December 10, 2017 Author Posted December 10, 2017 Ok, so either I'm a dolt, or something isn't working the way it's supposed to. Quit Emby. Deleted the Emby server app. Deleted the Emby Apple TV app. (I wasn't sure which app you were referring to so I deleted both) Deleted the images directory inside the cache directory (/emby-server/cache/images/). Reinstalled Emby 3.2.50.0 server. Reinstalled the Apple TV app (from TestFlight). Restarted Emby server, After this, I opened Emby on the Apple TV, and the annoying boxes were still there. I'm stumped. It's not a huge deal, it's just annoying...
Luke 42242 Posted December 12, 2017 Posted December 12, 2017 We're redoing these indicators in the app rather than having the server draw them, so I think it should be resolved with the next release of the app, thanks.
ebr 16335 Posted December 12, 2017 Posted December 12, 2017 The app-side indicators are in the new beta now.
BEis 21 Posted December 12, 2017 Author Posted December 12, 2017 Is there anything that needs to be done to get these to appear? I'm not seeing any indicators at all now, for watched or unwatched movies. Although I do see numbers for collections that contain one or more unwatched movies, or series that contain more than one unwatched episode. But the check marks are not showing up for watched items. I've restarted the app, and also restarted the server. Let me know if I need to do anything else...
ebr 16335 Posted December 13, 2017 Posted December 13, 2017 Sorry, I forgot to move the image into beta. Should be showing now.
BEis 21 Posted December 13, 2017 Author Posted December 13, 2017 Awesome! It's finally working, and looks great. I know this was a minor issue because it doesn't affect playback or anything, but it's really been bugging me because it was an eyesore. Looks great now, thanks for fixing it!
mgworek 134 Posted December 29, 2017 Posted December 29, 2017 Not sure if I should mention this here or post new topic. I have used the app in a few months. I used it today under tv shows, I get green circles but it doesn't list the number of unwatched episodes. Just the green circle is there. It told me there was a new version. I updated it but still just the green circles.
corey 317 Posted December 29, 2017 Posted December 29, 2017 Not sure if I should mention this here or post new topic. I have used the app in a few months. I used it today under tv shows, I get green circles but it doesn't list the number of unwatched episodes. Just the green circle is there. It told me there was a new version. I updated it but still just the green circles. Can you post a screenshot please?
