Sergio 4 Posted November 15, 2017 Posted November 15, 2017 (edited) Good night. I just pulled the latest image version and before replacing my installation I tried it in a new container with all the same options as the original (except for name), and I got a nice list of errors on the first run. I'll post it here, and perhaps someone wants to take a look and tell if it's normal or I have something corrupted in my "/config" stout.log sterr.log Edited November 15, 2017 by Sergio
Luke 42245 Posted November 15, 2017 Posted November 15, 2017 Hi @@Sergio, what problem are you experiencing? Thanks.
Sergio 4 Posted November 15, 2017 Author Posted November 15, 2017 (edited) Good night Luke. In fact I havent tested anything inside. But I saw some errors on plugins, anidb fetcher, gamebrowser, for example. And I wonder if I had some deprecated plugins. Also you can see some container init errors on the log. All FYI. Thanks. Edited November 15, 2017 by Sergio
Solution Luke 42245 Posted November 15, 2017 Solution Posted November 15, 2017 Try using the plugin catalog to install newer versions of those plugins, thanks. 1
Sergio 4 Posted November 15, 2017 Author Posted November 15, 2017 (edited) Thanks Luke, now it installs like silk. I only have this remaining error: Error Main: Skia not available. Will try next image processor. libSkiaSharp Will the only affected module be cover-art (that I don't use)? Edited November 15, 2017 by Sergio
Luke 42245 Posted November 15, 2017 Posted November 15, 2017 You'll be fine, nothing to worry about. 1
