Gamebrowser suggestions
For the time being, I'm trying to play my games in WMC/Gamebrowser locally on my Win 7 server. No NAS involved in the games setup and emby
Okay, Are you using any metadata from Launchbox? I just wonder if this is causing the .old files
Launchbox is on a client machine, and I configured it to not move any files, and store metadata locally.  I'm changing my script right after this post
Same error, log is below
2017-11-21 19:37:54.7105,Debug,,Attempting to wake server at address 9C-D2-1E-92-82-90,1,Application
2017-11-21 19:37:54.7105,Debug,,Wake command sent,1,Application
2017-11-21 19:37:54.7955,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application
2017-11-21 19:37:54.7955,Info,,System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application
2017-11-21 19:37:54.8755,Info,,==========Using new SQL Repo========,1,Application
2017-11-21 19:37:55.1155,Info,,Playstate initialization took 0.01 seconds.,1,Application
2017-11-21 19:37:55.1455,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader
2017-11-21 19:37:55.1655,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application
2017-11-21 19:37:55.1655,Info,,Total Kernel Init took 0.47 seconds.,1,Application
2017-11-21 19:37:55.2055,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader
2017-11-21 19:37:55.2055,Info,,Dictionary loading and validation took 0.09 seconds.,13,Worker thread for FastLoadLoader
2017-11-21 19:37:55.2455,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application
2017-11-21 19:37:55.2655,Info,,Emby (version 3.0.310.0 ) Starting up.,1,Application
2017-11-21 19:37:55.2655,Info,,Startup parameters: ,1,Application
2017-11-21 19:37:55.2855,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application
2017-11-21 19:37:55.2855,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application
2017-11-21 19:37:55.3655,Info,,Sending Http Get to http://192.168.29.119:8096/emby/System/Info/Public?format=Json,1,Application
2017-11-21 19:37:55.6755,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/Public?isDisabled=False&format=Json,1,Application
2017-11-21 19:37:55.7955,Info,,Connected to server HOMESERVER-PC at http://192.168.29.119:8096,1,Application
2017-11-21 19:37:55.7955,Info,,Server version: 3.2.36.0,1,Application
2017-11-21 19:37:55.8455,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/SplashPage,1,Application
2017-11-21 19:37:55.8755,Info,,Application Init took 0.70 seconds.,1,Application
2017-11-21 19:37:55.8955,Debug,,Sending Http Post to http://192.168.29.119:8096/emby/Users/d2d2ae38afbc45cf9c1c07d0b5ba43e0/Authenticate?format=Json,21,Worker thread for Common
2017-11-21 19:37:55.9555,Info,,Sending Http Get to http://192.168.29.119:8096/emby/System/Configuration?format=Json,21,Worker thread for Common
2017-11-21 19:37:56.0055,Info,,Sending Http Get to http://192.168.29.119:8096/emby/System/Info?format=Json,21,Worker thread for Common
2017-11-21 19:37:56.0655,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Plugins?format=Json,21,Worker thread for Common
2017-11-21 19:37:56.0955,Info,,*** Theme in use is: Chocolate,21,Worker thread for Common
2017-11-21 19:37:56.1055,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,23,Worker thread for Common
2017-11-21 19:37:56.1355,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.271.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.1355,Info,,Plug-in reference to MediaBrowser,, Version=3.0.271.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.1355,Debug,,Added Plugin assembly: BDScreenSaver,, Version=2.0.0.5,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application
2017-11-21 19:37:56.1855,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.1855,Info,,Plug-in reference to MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.1855,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.9.0,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application
2017-11-21 19:37:56.3155,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.211.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.3155,Info,,Plug-in reference to MediaBrowser,, Version=3.0.211.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.3255,Debug,,=========System looking for assembly: MediaBrowser.Model,, Version=3.0.5361.21269,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9,1,Application
2017-11-21 19:37:56.3255,Info,,Resolving MediaBrowser.Model,, Version=3.0.5361.21269,, Culture=neutral,, PublicKeyToken=6cde51960597a7f9 to C:\ProgramData\MediaBrowser-Classic\MediaBrowser.Model.dll,1,Application
2017-11-21 19:37:56.3255,Debug,,Added Plugin assembly: GameBrowser-Classic,, Version=3.0.0.42,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application
2017-11-21 19:37:56.4955,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.302.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.4955,Info,,Plug-in reference to MediaBrowser,, Version=3.0.302.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.5255,Debug,,Added Plugin assembly: Imperium,, Version=4.0.0.6,, Culture=neutral,, PublicKeyToken=null,1,Application
2017-11-21 19:37:56.6155,Debug,,Added Plugin assembly: Kismet,, Version=4.0.0.6,, Culture=neutral,, PublicKeyToken=null,1,Application
2017-11-21 19:37:56.6755,Debug,,=========System looking for assembly: MediaBrowser,, Version=2.6.1.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.6755,Info,,Plug-in reference to MediaBrowser,, Version=2.6.1.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.6755,Debug,,Added Plugin assembly: Sapphire,, Version=3.12.1.0,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application
2017-11-21 19:37:56.7455,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application
2017-11-21 19:37:56.7455,Info,,Plug-in reference to MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.310.0,1,Application
2017-11-21 19:37:56.7455,Info,,Subdued - Creating Theme,1,Application
2017-11-21 19:37:56.7605,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application
2017-11-21 19:37:56.7605,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application
2017-11-21 19:37:56.7605,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application
2017-11-21 19:37:56.7705,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application
2017-11-21 19:37:56.7705,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application
2017-11-21 19:37:56.7705,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application
2017-11-21 19:37:56.7705,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application
2017-11-21 19:37:56.7805,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application
2017-11-21 19:37:56.7805,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application
2017-11-21 19:37:56.7805,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application
2017-11-21 19:37:56.7805,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application
2017-11-21 19:37:56.7905,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application
2017-11-21 19:37:56.8105,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application
2017-11-21 19:37:56.8105,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application
2017-11-21 19:37:56.8105,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application
2017-11-21 19:37:56.8105,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Validating installed styles,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application
2017-11-21 19:37:56.8205,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application
2017-11-21 19:37:56.8305,Info,,Subdued - Theme Creation took 0.09 seconds.,1,Application
2017-11-21 19:37:56.8305,Debug,,Added Plugin assembly: Subdued,, Version=3.0.1.17,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application
2017-11-21 19:37:56.8405,Info,,BDScreenSaver (version 2.0.0.5) Plug-in Loaded.,1,Application
2017-11-21 19:37:56.8705,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application
2017-11-21 19:37:56.8905,Info,,Chocolate Theme (version 3.0.9.0) Loaded.,1,Application
2017-11-21 19:37:56.9005,Debug,,*** GAMEBROWSER *** Settings file exists: checking for root element match,1,Application
2017-11-21 19:37:56.9005,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Plugins/RegistrationRecords/gamebrowser-classic?Mb2Equivalent=gamebrowser-classic&format=Json,24,Worker thread for Common
2017-11-21 19:37:56.9005,Error,,*** GAMEBROWSER *** Exception Handled ( Exception handled.  Type=System.Xml.XmlException Msg=The 'GameSystems' start tag on line 3 does not match the end tag of 'GameBrowserSettings'. Line 16,, position 3. Src=System.Xml Method=Throw Line=0 Col=0 [n] StackTrace= [n]    at System.Xml.XmlTextReaderImpl.Throw(Exception e) [n]    at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag) [n]    at System.Xml.XmlTextReaderImpl.ParseEndElement() [n]    at System.Xml.XmlTextReaderImpl.ParseElementContent() [n]    at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) [n]    at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) [n]    at System.Xml.XmlDocument.Load(XmlReader reader) [n]    at System.Xml.XmlDocument.Load(String filename) [n]    at GameBrowser_Classic.Configuration.Settings.InitSettings() ),1,Application
2017-11-21 19:37:56.9005,Debug,,*** GAMEBROWSER *** root element not correct,1,Application
2017-11-21 19:37:56.9005,Debug,,=========System looking for assembly: GameBrowser-Classic.XmlSerializers,, Version=3.0.0.42,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application
2017-11-21 19:37:57.2606,Debug,,*** GAMEBROWSER *** Load settings,1,Application
2017-11-21 19:37:57.2806,Debug,,=========== Action called on legacy thread name: GameBrowser Registration Check,1,Application
2017-11-21 19:37:57.2806,Info,,GameBrowser-Classic (version 3.0.0.42) Plug-in Loaded.,1,Application
2017-11-21 19:37:57.2806,Info,,Imperium (version 4.0.0.6) Initializing.,1,Application
2017-11-21 19:37:57.3706,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Imperium-strings-en.xml,1,Application
2017-11-21 19:37:57.3806,Info,,Imperium (version 4.0.0.6) Theme Loaded.,1,Application
2017-11-21 19:37:57.3806,Info,,Kismet (version 4.0.0.6) Initializing.,1,Application
2017-11-21 19:37:57.4206,Debug,,=========== Action called on legacy thread name: TSoftRSS,1,Application
2017-11-21 19:37:57.4506,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Kismet-strings-en.xml,1,Application
2017-11-21 19:37:57.4706,Info,,Kismet (version 4.0.0.6) Theme Loaded.,1,Application
2017-11-21 19:37:57.4806,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Sapphire-strings-en.xml,1,Application
2017-11-21 19:37:57.5306,Info,,= SAPPHIRE = Sapphire Theme Loaded.,1,Application
2017-11-21 19:37:57.5306,Info,,Subdued - Initializing Theme,1,Application
2017-11-21 19:37:57.5306,Info,,Subdued - Checking active style: C:\ProgramData\MediaBrowser-Classic\Subdued_Styles.mcml,1,Application
2017-11-21 19:37:57.5406,Info,,Subdued - Chose random style: Subtle Red,1,Application
2017-11-21 19:37:57.5406,Info,,Subdued - Setting active style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application
2017-11-21 19:37:57.5706,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Subdued-strings-en.xml,1,Application
2017-11-21 19:37:57.5706,Info,,Subdued - Theme Initialization took 0.04 seconds.,1,Application
2017-11-21 19:37:57.5706,Info,,Subdued - Version 3.0.1.17 ready,1,Application
2017-11-21 19:37:57.5706,Info,,Plugin Loading and Init took 1.47 seconds.,1,Application
2017-11-21 19:37:57.6006,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application
2017-11-21 19:37:57.6006,Info,,Resolving WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application
2017-11-21 19:37:57.6586,Info,,Connected to ws://192.168.29.119:8096/mediabrowser,1,Application
2017-11-21 19:37:57.6906,Debug,,Sending Http Post to http://192.168.29.119:8096/emby/Sessions/Capabilities?format=Json,1,Application
2017-11-21 19:37:57.7266,Debug,,Navigating to My Library item type MediaBrowser.Library.FolderModel,1,Application
2017-11-21 19:37:57.7296,Debug,,Loading display prefs for ,1,Application
2017-11-21 19:37:57.7336,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/b32ca44d-c1d9-de2b-bcbb-62d6d949da23?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,1,Application
2017-11-21 19:37:57.8106,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38afbc45cf9c1c07d0b5ba43e0/Views?PresetViews=music&format=Json,1,Application
2017-11-21 19:37:58.1126,Debug,,Item Movies is UserView,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Trailers is TrailersChannel,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Games is UserView,1,Application
2017-11-21 19:37:58.1326,Debug,,Item TuneIn is Channel,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Collections is UserView,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Music is UserView,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Music videos is UserView,1,Application
2017-11-21 19:37:58.1326,Debug,,Item PlayOn is Channel,1,Application
2017-11-21 19:37:58.1326,Debug,,Item Recorded TV is UserView,1,Application
2017-11-21 19:37:58.1426,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application
2017-11-21 19:37:58.1526,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Items/b32ca44dc1d9de2bbcbb62d6d949da23/ThemeMedia?InheritFromParent=False&UserId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&format=Json,24,Worker thread for Common
2017-11-21 19:37:58.2326,Error,,Error getting response from http://192.168.29.119:8096/emby/Items/b32ca44dc1d9de2bbcbb62d6d949da23/ThemeMedia?InheritFromParent=False&UserId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&format=Json ( Exception.  Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n]    at System.Net.HttpWebRequest.GetResponse() [n]    at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),24,Worker thread for Common
2017-11-21 19:37:58.4826,Debug,,=========System looking for assembly: Chocolate,1,Application
2017-11-21 19:37:58.4826,Info,,Resolving plug-in reference to: Chocolate,1,Application
2017-11-21 19:37:58.7026,Debug,,=========System looking for assembly: BDScreenSaver,1,Application
2017-11-21 19:37:58.7026,Info,,Resolving plug-in reference to: BDScreenSaver,1,Application
2017-11-21 19:37:58.7451,Debug,,Loading display prefs for ,1,Application
2017-11-21 19:37:58.8176,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Localization/ParentalRatings?format=Json,1,Application
2017-11-21 19:37:58.8176,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38afbc45cf9c1c07d0b5ba43e0/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&sortBy=&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=Movie&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,28,Worker thread for Common
2017-11-21 19:37:58.8476,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Images/General?format=Json,1,Application
2017-11-21 19:37:58.8876,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Images/MediaInfo?format=Json,1,Application
2017-11-21 19:37:58.8976,Debug,,Could not find resource 'rated_none' in theme Chocolate,1,Application
2017-11-21 19:37:58.8976,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_none being cached on first access.  Should only have to do this once per session...,1,Application
2017-11-21 19:37:59.2476,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application
2017-11-21 19:38:00.2376,Debug,,Item Despicable Me Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2376,Debug,,Item Marvel's Guardians of the Galaxy Volume 2 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Kingsman: The Secret Service is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Avengers Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hurt Locker is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Pirates of the Caribbean Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Amazing Spider-Man Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Avatar is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Transformers: Age of Extinction is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hobbit: The Battle of Five Armies - New Zealand: Home of Middle-Earth - Part 3 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item 47 Ronin is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item All Dogs Go to Heaven 2 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item A Personal Journey with Martin Scorsese Through American Movies is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Big Trouble is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Body of Evidence is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Boondock Saints is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Gran Torino is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Harry Potter 8 And the Deathly Hollows PT. 2 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Inglorious Bastards is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Pride and Glory is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Exorcism of Emily Rose is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hunger Games Mocking Jay Pt. 2 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Land Before Time is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Prestige is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Whinney the Poo is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Harry Potter 7 And the Deatly Hollows PT. 1 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Basic is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hannibal Lecter Anthology is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Happy Feet is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Inception is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Madagascar is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Tarzan is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Ten Commandments is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Devil Wears Prada is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Lord of the Rings Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Matrix Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item X-Men Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Monsters,, Inc. is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Back to the Future Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item How the Grinch Stole Christmas is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Jerry Maguire is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Goonies is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Star Wars Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Cars 2 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Top Gun is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item National Lampoon's Christmas Vacation is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Beauty and the Beast is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Bourne Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Divergent is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Boss Baby is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hobbit: The Battle of the Five Armies is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Little Mermaid is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Hunger Games: Catching Fire is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Iron Man is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Jaws is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Cloudy with a Chance of Meatballs is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Rocky Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Wolf of Wall Street is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item World War Z is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Kong: Skull Island is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Captain Underpants: The First Epic Movie is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item 21 Jump Street is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Lego Movie is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Jurassic Park Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Fantastic Mr. Fox is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Gangs of New York is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Robots is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Lion King is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Spaceballs is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Big Hero 6 is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item 300 Rise of an Empire: Becoming a Warrior is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Harry Potter Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Split is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Dark Knight Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Elf is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Training Day is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Watchmen is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Black Hawk Down is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Ghostbusters Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item O Brother,, Where Art Thou? is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Troy is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Curious Case of Benjamin Button is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item A Walk Among the Tombstones is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Aliens is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Fifty Shades of Grey is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Fury is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Guardians of the Galaxy is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item The Sum of All Fears is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Unforgiven is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Shrek Collection is BoxSet,28,Worker thread for Common
2017-11-21 19:38:00.2476,Debug,,Item Chappie is Movie,28,Worker thread for Common
2017-11-21 19:38:00.2476,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/f137a2dd21bbc1b99aa5c0f6bf02a805?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,28,Worker thread for Common
2017-11-21 19:38:00.2576,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38afbc45cf9c1c07d0b5ba43e0/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&IncludeItemTypes=movie&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Despicable Me Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Ghostbusters Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Pirates of the Caribbean Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Amazing Spider-Man Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Jurassic Park Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Avengers Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Bourne Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Dark Knight Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Shrek Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item X-Men Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Rocky Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Hannibal Lecter Anthology is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Star Wars Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Harry Potter Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Matrix Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Back to the Future Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Lord of the Rings Collection is BoxSet,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item The Hurt Locker is Movie,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Kingsman: The Secret Service is Movie,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,Item Transformers: Age of Extinction is Movie,23,Worker thread for Common
2017-11-21 19:38:00.2776,Info,,RAL child retrieval for Movies option added took 0.03 seconds.,23,Worker thread for Common
2017-11-21 19:38:00.2776,Debug,,added list for Movies loaded with 20 items.,23,Worker thread for Common
2017-11-21 19:38:00.2876,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/53745093-55c9-4935-2444-7e6d794e5185?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,23,Worker thread for Common
2017-11-21 19:38:00.5376,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Channels/28b5d5b8bef4bd1f1914503b5c11ac91/Items?userid=d2d2ae38afbc45cf9c1c07d0b5ba43e0&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,21,Worker thread for Common
2017-11-21 19:38:00.8826,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items?ParentId=8f3e04c1bc361191c16f63a5c8f9c190&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,18,Worker thread for Common
2017-11-21 19:38:00.8926,Debug,,Item New and Upcoming in Theaters is ChannelFolder,21,Worker thread for Common
2017-11-21 19:38:00.8926,Debug,,Item New and Upcoming Movies on Dvd & Blu-ray is ChannelFolder,21,Worker thread for Common
2017-11-21 19:38:00.8926,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/cf6ebf1a91eb92911606a18df6a41cf0?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,21,Worker thread for Common
2017-11-21 19:38:00.8926,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Channels/Items/Latest?userid=d2d2ae38afbc45cf9c1c07d0b5ba43e0&channelIds=28b5d5b8bef4bd1f1914503b5c11ac91&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&format=Json,26,Worker thread for Common
2017-11-21 19:38:00.9926,Debug,,Item Nintendo GameCube is GamePlatform,18,Worker thread for Common
2017-11-21 19:38:00.9926,Debug,,Item Nintendo Wii is GamePlatform,18,Worker thread for Common
2017-11-21 19:38:01.0026,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/8f3e04c1bc361191c16f63a5c8f9c190?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,18,Worker thread for Common
2017-11-21 19:38:01.0226,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38afbc45cf9c1c07d0b5ba43e0/Items?ParentId=8f3e04c1bc361191c16f63a5c8f9c190&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Donkey Kong Jungle Beat is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Donkey Kong Country Returns is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Pacman World 2 is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Donkey Konga is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Smash Brothers Mele is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Nintendo GameCube is GamePlatform,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Wii Sports is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Nintendo Wii is GamePlatform,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,Item Super Mario All Stars is GameItem,24,Worker thread for Common
2017-11-21 19:38:01.0326,Info,,RAL child retrieval for Games option added took 0.02 seconds.,24,Worker thread for Common
2017-11-21 19:38:01.0326,Debug,,added list for Games loaded with 9 items.,24,Worker thread for Common
2017-11-21 19:38:01.0726,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items?ParentId=02728a59efe33be633bf9a5924832045&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0726,Debug,,Item Donkey Kong Jungle Beat is GameItem,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0726,Debug,,Item Donkey Konga is GameItem,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0726,Debug,,Item Pacman World 2 is GameItem,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0726,Debug,,Item Smash Brothers Mele is GameItem,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0726,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/02728a59efe33be633bf9a5924832045?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,38,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0826,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items?ParentId=f9eb243c40174531c21a2c69e4ae2201&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,43,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0826,Debug,,Item Donkey Kong Country Returns is GameItem,43,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0826,Debug,,Item Super Mario All Stars is GameItem,43,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0826,Debug,,Item Wii Sports is GameItem,43,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.0826,Info,,Sending Http Get to http://192.168.29.119:8096/emby/DisplayPreferences/f9eb243c40174531c21a2c69e4ae2201?userId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&client=MBC&format=Json,43,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.5626,Debug,,Item Star Wars: The Last Jedi is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Coco is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Justice League is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Three Billboards Outside Ebbing,, Missouri is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Downsizing is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item In the Fade is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Permanent is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item I,, Tonya is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item Daddy's Home 2 is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,Item American Folk is Movie,26,Worker thread for Common
2017-11-21 19:38:01.5626,Info,,RAL child retrieval for Trailers option added took 0.67 seconds.,26,Worker thread for Common
2017-11-21 19:38:01.5626,Debug,,added list for Trailers loaded with 10 items.,26,Worker thread for Common
2017-11-21 19:38:01.7226,Debug,,Navigating to Games item type MediaBrowser.Library.FolderModel,1,Application
2017-11-21 19:38:01.7226,Debug,,Loading display prefs for C:\Users\Home Server\AppData\Roaming\Emby-Server\root\default\Games,1,Application
2017-11-21 19:38:01.7626,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application
2017-11-21 19:38:01.7626,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Items/8f3e04c1bc361191c16f63a5c8f9c190/ThemeMedia?InheritFromParent=False&UserId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&format=Json,18,Worker thread for Common
2017-11-21 19:38:01.7826,Debug,,Loading display prefs for C:\Users\Home Server\AppData\Roaming\Emby-Server\root\default\Games,1,Application
2017-11-21 19:38:01.8726,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items?ParentId=02728a59efe33be633bf9a5924832045&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,34,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8826,Debug,,Item Donkey Kong Jungle Beat is GameItem,34,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8826,Debug,,Item Donkey Konga is GameItem,34,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8826,Debug,,Item Pacman World 2 is GameItem,34,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8826,Debug,,Item Smash Brothers Mele is GameItem,34,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8926,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items?ParentId=f9eb243c40174531c21a2c69e4ae2201&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,40,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8926,Debug,,Item Donkey Kong Country Returns is GameItem,40,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8926,Debug,,Item Super Mario All Stars is GameItem,40,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:01.8926,Debug,,Item Wii Sports is GameItem,40,Worker thread for UnwatchedCounterForFolderModel
2017-11-21 19:38:02.2826,Error,,Registration checked,25,Worker thread for Legacy
2017-11-21 19:38:02.2826,Info,,GameBrowser-Classic Registration confirmed.,25,Worker thread for Legacy
2017-11-21 19:38:03.7476,Debug,,Navigating to Nintendo GameCube item type MediaBrowser.Library.FolderModel,1,Application
2017-11-21 19:38:03.7576,Debug,,Loading display prefs for \\HOMESERVER-PC\Video Games\Gamecube,1,Application
2017-11-21 19:38:03.7576,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application
2017-11-21 19:38:03.7576,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Items/02728a59efe33be633bf9a5924832045/ThemeMedia?InheritFromParent=False&UserId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&format=Json,28,Worker thread for Common
2017-11-21 19:38:03.7876,Debug,,Loading display prefs for \\HOMESERVER-PC\Video Games\Gamecube,1,Application
2017-11-21 19:38:03.8476,Debug,,Could not find resource 'rated_10+' in theme Chocolate,1,Application
2017-11-21 19:38:03.8476,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_10+ being cached on first access.  Should only have to do this once per session...,1,Application
2017-11-21 19:38:05.3726,Debug,,Navigating to Donkey Kong Jungle Beat item type MediaBrowser.Library.Item,1,Application
2017-11-21 19:38:05.3926,Debug,,Loading full details for Donkey Kong Jungle Beat,1,Application
2017-11-21 19:38:05.3926,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items/9605d976-86f1-9aed-8725-49eb0047243b?format=Json,1,Application
2017-11-21 19:38:05.4726,Debug,,Item Donkey Kong Jungle Beat is GameItem,1,Application
2017-11-21 19:38:05.4826,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application
2017-11-21 19:38:05.4826,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Items/9605d97686f19aed872549eb0047243b/ThemeMedia?InheritFromParent=False&UserId=d2d2ae38afbc45cf9c1c07d0b5ba43e0&format=Json,27,Worker thread for Common
2017-11-21 19:38:05.6526,Debug,,Could not find resource 'media_unknown' in theme Chocolate,1,Application
2017-11-21 19:38:05.6526,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/media_unknown being cached on first access.  Should only have to do this once per session...,1,Application
2017-11-21 19:38:06.1126,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Plugins/RegistrationRecords/mbsupporter?Mb2Equivalent=mbsupporter&format=Json,24,Worker thread for Common
2017-11-21 19:38:06.8776,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items/9605d97686f19aed872549eb0047243b/Intros?format=Json,1,Application
2017-11-21 19:38:06.8976,Info,,No intros found for Donkey Kong Jungle Beat,1,Application
2017-11-21 19:38:06.9676,Debug,,Creating a new instance of GamePlaybackController,29,Worker thread for Common
2017-11-21 19:38:06.9776,Info,,Gamebrowser playback controller about to play Donkey Kong Jungle Beat(\\HOMESERVER-PC\Video Games\Gamecube\Donkey Kong Jungle Beat\Donkey Kong Jungle Beat.iso) ,1,Application
2017-11-21 19:38:06.9776,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application
2017-11-21 19:38:06.9776,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application
2017-11-21 19:38:06.9876,Info,,Gamebrowser playback controller playing Donkey Kong Jungle Beat,1,Application
2017-11-21 19:38:06.9876,Info,,*** GAMEBROWSER *** Trying to match GameSystem for NintendoGameCube,1,Application
2017-11-21 19:38:06.9876,Error,,*** GAMEBROWSER *** Consoles list is empty,1,Application
2017-11-21 19:38:07.7476,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Packages/MBClassic?format=Json,28,Worker thread for Common
2017-11-21 19:38:08.1476,Info,,==== Emby for WMC is up to date.,28,Worker thread for Common
2017-11-21 19:38:08.4676,Info,,Information DisplayText: Emby for WMC is up to date,1,Application
2017-11-21 19:38:09.3326,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items/9605d97686f19aed872549eb0047243b/Intros?format=Json,1,Application
2017-11-21 19:38:09.3426,Info,,No intros found for Donkey Kong Jungle Beat,1,Application
2017-11-21 19:38:09.3426,Info,,Gamebrowser playback controller about to play Donkey Kong Jungle Beat(\\HOMESERVER-PC\Video Games\Gamecube\Donkey Kong Jungle Beat\Donkey Kong Jungle Beat.iso) ,1,Application
2017-11-21 19:38:09.3426,Debug,,Stopping Gamebrowser playback controller .,1,Application
2017-11-21 19:38:09.3426,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:09.5926,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:09.8426,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:10.0926,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:10.3426,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:10.5926,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:10.8476,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:11.0976,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:11.3476,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:11.5976,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:11.8476,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:12.0976,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:12.3476,Warning,,Player didn't stop - trying ot continue anyway.,1,Application
2017-11-21 19:38:12.3476,Debug,,Stopping Gamebrowser playback controller .,1,Application
2017-11-21 19:38:12.3476,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:12.5976,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:12.8526,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:13.1026,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:13.3526,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:13.6026,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:13.8526,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:14.1026,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:14.3526,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:14.6026,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:14.8576,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:15.1076,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:38:15.3576,Warning,,Player didn't stop - trying ot continue anyway.,1,Application
2017-11-21 19:38:15.3576,Info,,Gamebrowser playback controller playing Donkey Kong Jungle Beat,1,Application
2017-11-21 19:38:15.3576,Info,,*** GAMEBROWSER *** Trying to match GameSystem for NintendoGameCube,1,Application
2017-11-21 19:38:15.3576,Error,,*** GAMEBROWSER *** Consoles list is empty,1,Application
2017-11-21 19:38:55.2873,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application
2017-11-21 19:39:54.8802,Debug,,Navigating to Nintendo Wii item type MediaBrowser.Library.FolderModel,1,Application
2017-11-21 19:39:54.8802,Debug,,Loading display prefs for \\HOMESERVER-PC\Video Games\Wii,1,Application
2017-11-21 19:39:54.8802,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application
2017-11-21 19:39:54.8902,Debug,,Loading display prefs for \\HOMESERVER-PC\Video Games\Wii,1,Application
2017-11-21 19:39:54.9402,Debug,,Could not find resource 'rated_e' in theme Chocolate,1,Application
2017-11-21 19:39:54.9402,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_e being cached on first access.  Should only have to do this once per session...,1,Application
2017-11-21 19:39:55.2702,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application
2017-11-21 19:39:56.6602,Debug,,Navigating to Donkey Kong Country Returns item type MediaBrowser.Library.Item,1,Application
2017-11-21 19:39:56.6602,Debug,,Loading full details for Donkey Kong Country Returns,1,Application
2017-11-21 19:39:56.6602,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items/492f0280-41f8-e441-79a1-17dfac01a578?format=Json,1,Application
2017-11-21 19:39:56.6902,Debug,,Item Donkey Kong Country Returns is GameItem,1,Application
2017-11-21 19:39:56.6902,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application
2017-11-21 19:39:56.7677,Info,,Received web socket message: UserUpdated,51,
2017-11-21 19:39:58.1877,Info,,Sending Http Get to http://192.168.29.119:8096/emby/Users/d2d2ae38-afbc-45cf-9c1c-07d0b5ba43e0/Items/492f028041f8e44179a117dfac01a578/Intros?format=Json,1,Application
2017-11-21 19:39:58.1977,Info,,No intros found for Donkey Kong Country Returns,1,Application
2017-11-21 19:39:58.4177,Info,,Gamebrowser playback controller about to play Donkey Kong Country Returns(\\HOMESERVER-PC\Video Games\Wii\Donkey Kong Country Returns\Donkey Kong Country Returns.iso) ,1,Application
2017-11-21 19:39:58.4177,Debug,,Stopping Gamebrowser playback controller .,1,Application
2017-11-21 19:39:58.4177,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:58.6677,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:58.9227,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:59.1727,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:59.4227,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:59.6727,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:39:59.9227,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:00.1727,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:00.4227,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:00.6727,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:00.9277,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:01.1777,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:01.4277,Warning,,Player didn't stop - trying ot continue anyway.,1,Application
2017-11-21 19:40:01.4277,Debug,,Stopping Gamebrowser playback controller .,1,Application
2017-11-21 19:40:01.4277,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:01.6777,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:01.9277,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:02.1777,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:02.4277,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:02.6777,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:02.9327,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:03.1827,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:03.4327,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:03.6827,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:03.9327,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:04.1827,Debug,,Still waiting for Gamebrowser playback controller to stop.  Reports: Playing,1,Application
2017-11-21 19:40:04.4327,Warning,,Player didn't stop - trying ot continue anyway.,1,Application
2017-11-21 19:40:04.4327,Info,,Gamebrowser playback controller playing Donkey Kong Country Returns,1,Application
2017-11-21 19:40:04.4327,Info,,*** GAMEBROWSER *** Trying to match GameSystem for Wii,1,Application
2017-11-21 19:40:04.4327,Error,,*** GAMEBROWSER *** Consoles list is empty,1,Application
throgmorton
Looking at this log your GameBrowser.XML seems corrupt and doesn't have a proper closing tag, based on the following excerpt:
I would ensure that your Gamebrowser.XML is properly formed. Since currently it doesn't load any consoles up, which is why when you launch a game its saying your console list is empty. So it has no idea what executable to use for your emulator:
Edited by throgmorton
  • Like 1
Sorry for the delay, Holidays are coming up, and my life keeps getting more hectic as I get closer to Christmas.  I inserted the closing tag ( I don't know how I have been missing this all along), and now emby will minmize, then maximize itself like it is trying to launch something.  i suspect an error with retroarch itself so i will have to investigate in that direction as well.  I posted this to say thanks one more time, and let everyone know I haven't forgotten about getting this running.
Another note for this whole thread that I think is important.  Retroarch doesn't support the Wiimote (Currently that I am aware of anyway) so I'll need dolphin in its entirety to play some games.  I also believe that retroarch will not even run wii games with the dolphin core so that explains at least some of my errors.  Retroarch DOES support gamecube games with the Wii core though.  I want to test the gamebrowser command line perameters through a CLI without using Emby/Gamebrowser to see if I'm doing something wrong there, or if there is a setting in retroarch I need to change.
here is a youtube guide I would like to try out.
Edited by jachin99
  • 1 month later...
swhitmore
Hey guys. So this week I managed to get Breath of the Wild working with CEMU on my HTPC. I've been trying to figure out how I can launch this with Emby Theatre. The guide look outdated and seem to only have options for launching local Windows and DOS games, not CEMU. Is anyone able to help? Thank you.
  • 2 weeks later...
shaefurr
I haven't tried it yet myself, but I did see Wii U game extensions we're added (.wud and .disc) in the gamebrowser resolver, I'll see if I can get it working and update the guide.
Heck, entire GB guide needs to be updated.
Sent from my VS990 using Tapatalk
  • Like 1
shaefurr
I got it working
1. Go to the server dashboard, gamebrowser plugin config, add a system as usual for Nintendo Wii U
2. In Emby Theater, add an external player with the cemu exe location, Nintendo Wii U, and this for the argument (make sure they are on seperate lines)
-g
{path}
  • Troubleshooting
  • If you get an error about the common key, that is related to cemu, its an easy fix you can find on the cemu forums, or just google it :P
  • If you see the game but have no play button, browse to the game folder and open game.xml in notepad, and change
          <GameSystem>WiiU</GameSystem>
          to
          <GameSystem>Nintendo Wii U</GameSystem>
  • Like 1
swhitmore
Thank you so much! I'll try this right now.
swhitmore
@@shaefurr I've added everything, but how do I add a shortcut to the game that's stored locally on the HTPC (not the server). I can only see how to do this for PC games.
shaefurr
Is there a reason you're keeping the game on the HTPC and not the server, can the network not handle a game of that size? I know some for WiiU are 30gb.
Anyway There is no guide for that other than Windows/DOS, because it was never intended to be setup like that.
If it wont run from the server, I think you're only option is just "pretending" its a PC game, except you would need a .bat file to use in place of a shortcut so it can load the rom. Also this would only work with Emby for WMC, Emby Theater does not support PC/DOS games yet.
Frank Drebin
Any luck with Cemu in gamebrowser III? Shortcuts dont work, it gives an error.
Im searching for weeks. Maybe an update of cemu will fix it.
ps, I'm using this for switch
-g "{rom}" -f
Edited by Frank Drebin
shaefurr
-g "{rom}" -f
I only have it working in emby theater, I don't have windows Media center so I can't test it
What error do you get?
Edited by shaefurr
swhitmore
Yeah, the games a very large, and won't run well off the server. I'm using Emby Theatre, so that won't work unfortunately. For now I'm using Steam in Big Picture mode. I found a tool called Ice what automatically adds ROMs to Steam.
shaefurr
Yeah maybe in the future we can get this working in emby, Games Roms were not 30+ GB when gamebrowser first came out :P
I used ICE for a long time, but the dev hasn't really touched it in over a year, so I switched to Steam Rom Manager, it can be a tad confusing setting it up the first time, but once you get one game system figured out its easy. Functions exactly the same as ICE though, has more options and stuff to customize, but both ICE and SRM are solid choices for steam.
Edited by shaefurr
Frank Drebin
The error i get trying opening a shortcut in gamebrowser III is "Unknown filetype" :s
In my plugin I use "lnk and rpx" as extensions.
If I open the shortcut directly in Cemu it will work with no problems.
Opening a .wux file in gamebrowser III also works.
Ps, im also using shortcuts in rpcs3 and those work also.
Sorry for my bad English
I believe i have found a bug in this whole setup. It seems that when I add my games folder via the regular emby libraries, emby generates a bad game browser.xml file, then recognizes it's bad, and marks it old. This behavior happened repeatedly to me after deleting the newly generated gb.xml and renaming gb.xml.old to gb.xml and doing a fresh library scan. I had this problem in the past and could not figure out what was going on. Tonight after my library scan emby generated a gb.xml file which contained a game systems closing tag that looked like this. <gamesystems />
I still don't have this working g but if others see emby regenerating gb.xml files that is likely why. After fixing this tag manually it stopped generating new gb.xml tags even through multiple library scans.
I'm trying to add just GameCube games via dolphin btw. I've tried Nintendo GameCube, GameCube, Nintendo Gamecube, and Gamecube for system names.
<GameSystem>Gamecube</GameSystem>
thats whats suppose to be in the game.xml file. it is case sensitive. onces that is done. just go to that game and refresh metadata and refresh mode set for "scan for new and updated files" Then refresh. This is done on Emby Theater
This is if you can't get the play button.
If you get the play button then these are the command argument
/e
{path}
I'm not too sure about what you mean by /e
        {path}
In the gamebrowser settings, I have GB pointed towards the path of my roms (Which is on a server).  Is this correct or do I point it at the exe file for my emulator?  WHen I point GB towards my emulator it doesn't show the play button anymore.
That command is what you need to put in where you add external player in Emby theater.
Are you using WMC? If that’s the case, you put that in the switches. I haven’t tried it on there so you may have to use some other command other than {path}. You will need to use /e for dolphin.
Alrite thanks I'll try it out. I have found a new issue. Emby will not see games I add to my games library from a local drive © but it does see games that I add from a network location. This happens when I add games through the emby library function. I just installed retroarch on this pc but I'm not sure if it can play games from a network location out of the box. I haven't tried setting up GB with retroarch yet but I would like to do that as well.
swhitmore
I found that the library location needs to be the same as the gamebrowser plugin settings. I recently had an issue where I accidentally used UNC paths for one, and a mapped drive for the other.
That is correct. They need to be mapped the same. It’s better to map on the network, it eliminates any sharing permission issue.
