Emby Error after starting Kodi
Go to solution Solved by totalhavoc,
totalhavoc
I'm receiving an Emby Error message when starting Kodi. It does not happen on every profile. It seems like it is only happening to profiles that have not used the various kodi boxes in the last couple of days. Log is attached.
Can't seem to get the plugin to work at all on the profiles that are not working.
kodi.log
  • Solution
totalhavoc
I have it fixed.. The Kodi beta repository became disabled on the profiles in question but not the good profiles. I had to re-enable it, then reinstall the plugin on the profiles that were not working. It's weird because usually plugins span profiles... not sure why the repo and addon worked on some but the repo was disabled and addon broke on others.
Guest
