tdiguy 99 Posted November 11, 2017 Posted November 11, 2017 I primarily use openvpn to access my emby server when i am at work and things are slow. Its not fancy but it works well. Course this "problem" is easily resolved by just setting the quality setting manually. But is there a way to specify my routers ip address as being not local ( ie 192.168.1.1 ) or if it could somehow tell that the ip pool openvpn is using is 10.*
Luke 42245 Posted November 11, 2017 Posted November 11, 2017 Hi, anything in the 192.168 range will always be detected as being on your local network.
Luke 42245 Posted November 11, 2017 Posted November 11, 2017 As far as 10.x goes, that can be a tricky one. How is that detected now?
tdiguy 99 Posted November 11, 2017 Author Posted November 11, 2017 I just noticed that its detecting my address as the public ip here at work so thats working well. I thought i had set the max mbps on it but i just saw it was not set. Sorry feature is working as intended and is actually smarter than i thought it was
