aahmyu 9 Posted November 11, 2017 Posted November 11, 2017 Hello, Does this plugin do a library scan after it finishes copying the files to library folders? And if it doesnt, is there anyway to force library scan after auto organizing? thanks
aahmyu 9 Posted November 11, 2017 Author Posted November 11, 2017 A scan should not be necessary. So they items are added to the library without need to rescan? And something else in the media theater on windows the play/pause button keep disappearing for some reason. is this a known bug?
Luke 42203 Posted November 11, 2017 Posted November 11, 2017 Correct you don't need to manually run a scan. Yes I'm aware of the button issue and am looking into it, thanks.
