mastrmind11 722 Posted November 9, 2017 Posted November 9, 2017 So I had a hung tuner that I just discovered thrashing the hell out of my HDD via log files, and when I checked the dashboard the only activity going on was my son Direct Playing something. I restarted the server via CLI and it restarted what he was watching from the beginning w/ a black screen for 30ish seconds. I was under the impression a Direct Play completely bypassed the server and thus a restart of Emby Server would/should have no effect on what's being Direct Played. Am I wrong or ...? Unfortunately this happened the same time as the orphan tuner was bombing out for days so my complete logs are a bit under 1GB per day, thus I won't be uploading them anywhere. Any insight/clarification is appreciated.
Solution ebr 16337 Posted November 10, 2017 Solution Posted November 10, 2017 In the case of streaming boxes like the Android TV ones the content is always delivered via http through the server. Only the desktop/htpc applications will go direct to your file system. 1
