secagratis 21 Posted November 8, 2017 Posted November 8, 2017 emby server shutdown problem after many errors I will log you below server-63645734832.txt
Luke 42239 Posted November 8, 2017 Posted November 8, 2017 Can you please describe the issue in more detail? Thanks.
secagratis 21 Posted November 8, 2017 Author Posted November 8, 2017 nel file di log se vedi mi ripete piu volte questo creadomi un enorme file e cosi windows interrompe emby 2017-11-08 14:22:51.296 Info HttpResultFactory: Transmit file D:\SerieTV\Film\Film\rec\cache\temp\bcee14539f5b4bbf8db912dbc56d0e9f.png 2017-11-08 14:22:51.296 Info HttpServer: HTTP Response 200 to 93.40.231.120. Time: 50ms. http://xxx.xxx.xxx.xxx:8096/emby/Items/e1e542e812ee2a66bc6c2557e91f4df0/Images/Primary/0?maxwidth=180&maxheight=270&quality=90 2017-11-08 14:22:51.299 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xxx:8096/emby/Items/5ce94d6b29d24d69e4af184bb0ee6ae9/Images/Primary/0?maxwidth=180&maxheight=270&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV; Maple2012) AppleWebKit/534.7 (KHTML, like Gecko) SmartTV Safari/534.7 2017-11-08 14:22:51.308 Info HttpResultFactory: Transmit file D:\SerieTV\Film\Film\rec\cache\temp\b08e6cfe41414f10a1a3bb0901412e7d.png 2017-11-08 14:22:51.308 Info HttpServer: HTTP Response 200 to 93.40.231.120. Time: 55ms. http://xxx.xxx.xxx.xxx:8096/emby/Items/6164170f7ee9541d8a1c1bcf5cc04c0b/Images/Primary/0?maxwidth=180&maxheight=270&quality=90 2017-11-08 14:22:51.354 Info HttpResultFactory: Transmit file D:\SerieTV\Film\Film\rec\cache\temp\369a2060875a48b0a86b0033a53c2e4f.png 2017-11-08 14:22:51.355 Info HttpServer: HTTP Response 200 to 93.40.231.120. Time: 56ms. http://xxx.xxx.xxx.xxx:8096/emby/Items/5ce94d6b29d24d69e4af184bb0ee6ae9/Images/Primary/0?maxwidth=180&maxheight=270&quality=90
Luke 42239 Posted November 8, 2017 Posted November 8, 2017 Try installing from the website on top of your existing version.
secagratis 21 Posted November 9, 2017 Author Posted November 9, 2017 he continues to give me this error 2017-11-09 08:34:15.060 Error ImageProcessor: Error in image enhancer: CoverArtMovieEnhancer *** Error Report *** Version: 3.2.36.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\system System.IO.FileNotFoundException: Could not load file or assembly 'SkiaSharp, Version=1.59.0.0, Culture=neutral, PublicKeyToken=......................................'. Impossibile trovare il file specificato. File name: 'SkiaSharp, Version=1.59.0.0, Culture=neutral, PublicKeyToken=......................................' ---> System.IO.FileNotFoundException: Could not load the specified file. File name: 'SkiaSharp' at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingEvent(AssemblyName assemblyName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingResolvingEvent(IntPtr gchManagedAssemblyLoadContext, AssemblyName assemblyName) at CoverArt.Skia.ImageSet..ctor(String name, Int32 rotation) at CoverArt.Skia.SkiaCoverArtImageProcessor.CreateImageSet(String name, Int32 rotation) at CoverArt.Entities.ProfileDefinition.CreateImageSets() at CoverArt.Entities.ProfileDefinition.GetImageSet(String itemType) at CoverArt.Entities.ProfileDefinition.Ignore(IHasMetadata item, String itemType) at CoverArt.Enhancers.CoverArtMovieEnhancer.SupportsInternal(IHasMetadata item, ImageType imageType) at CoverArt.Enhancers.CoverArtBaseEnhancer.Supports(IHasMetadata item, ImageType imageType) at Emby.Drawing.ImageProcessor.GetSupportedEnhancers(IHasMetadata item, ImageType imageType) System.IO.FileNotFoundException at CoverArt.Skia.ImageSet..ctor(String name, Int32 rotation) at CoverArt.Skia.SkiaCoverArtImageProcessor.CreateImageSet(String name, Int32 rotation) at CoverArt.Entities.ProfileDefinition.CreateImageSets() at CoverArt.Entities.ProfileDefinition.GetImageSet(String itemType) at CoverArt.Entities.ProfileDefinition.Ignore(IHasMetadata item, String itemType) at CoverArt.Enhancers.CoverArtMovieEnhancer.SupportsInternal(IHasMetadata item, ImageType imageType) at CoverArt.Enhancers.CoverArtBaseEnhancer.Supports(IHasMetadata item, ImageType imageType) at Emby.Drawing.ImageProcessor.GetSupportedEnhancers(IHasMetadata item, ImageType imageType) InnerException: System.IO.FileNotFoundException System.IO.FileNotFoundException: Could not load the specified file. File name: 'SkiaSharp' at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingEvent(AssemblyName assemblyName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingResolvingEvent(IntPtr gchManagedAssemblyLoadContext, AssemblyName assemblyName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingEvent(AssemblyName assemblyName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingResolvingEvent(IntPtr gchManagedAssemblyLoadContext, AssemblyName assemblyName) 2017-11-09 08:34:15.061 Error ImageProcessor: Error in image enhancer: CoverArtMovieEnhancer *** Error Report *** Version: 3.2.36.0 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\system System.IO.FileNotFoundException: Could not load file or assembly 'SkiaSharp, Version=1.59.0.0, Culture=neutral, PublicKeyToken=......................................'. Impossibile trovare il file specificato. File name: 'SkiaSharp, Version=1.59.0.0, Culture=neutral, PublicKeyToken=......................................' ---> System.IO.FileNotFoundException: Could not load the specified file. File name: 'SkiaSharp' at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingEvent(AssemblyName assemblyName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUsingResolvingEvent(IntPtr gchManagedAssemblyLoadContext, AssemblyName assemblyName) at CoverArt.Skia.ImageSet..ctor(String name, Int32 rotation) at CoverArt.Skia.SkiaCoverArtImageProcessor.CreateImageSet(String name, Int32 rotation) at CoverArt.Entities.ProfileDefinition.CreateImageSets() at CoverArt.Entities.ProfileDefinition.GetImageSet(String itemType) at CoverArt.Entities.ProfileDefinition.Ignore(IHasMetadata item, String itemType) at CoverArt.Enhancers.CoverArtMovieEnhancer.SupportsInternal(IHasMetadata item, ImageType imageType) at CoverArt.Enhancers.CoverArtBaseEnhancer.Supports(IHasMetadata item, ImageType imageType) at Emby.Drawing.ImageProcessor.GetSupportedEnhancers(IHasMetadata item, ImageType imageType)
Luke 42239 Posted November 9, 2017 Posted November 9, 2017 Use the plugin catalog to install a compatible version of the cover art plugin.
