ng4ever 40 Posted November 8, 2017 Posted November 8, 2017 Basically Plex puts all the dvd rips from a tv show season and puts them in a Season folder automatically. When you click on it every episode is there to play it kinda looks like Netflix which is cool! Anyway to get Emby to do this? I will post a screenshot of what I am talking about if need be.
Happy2Play 9802 Posted November 8, 2017 Posted November 8, 2017 Screenshots would display your issue better.
Luke 42203 Posted November 8, 2017 Posted November 8, 2017 Yes please be more specific and show us what the folder structure of your files looks like as well, thanks.
ng4ever 40 Posted November 8, 2017 Author Posted November 8, 2017 Yes please be more specific and show us what the folder structure of your files looks like as well, thanks. Sure they are like this. Folder for Movies called Movies Folder for TV Shows called TV Shows I just copied and pasted a Season 1 of a TV Show to the TV Shower folder. Should I have put all these TV Shows in a folder named the TV Show ?
Happy2Play 9802 Posted November 8, 2017 Posted November 8, 2017 Sure they are like this. Folder for Movies called Movies Folder for TV Shows called TV Shows I just copied and pasted a Season 1 of a TV Show to the TV Shower folder. Should I have put all these TV Shows in a folder named the TV Show ? Yes https://github.com/MediaBrowser/Wiki/wiki/TV%20naming
Luke 42203 Posted November 8, 2017 Posted November 8, 2017 Sure they are like this. Folder for Movies called Movies Folder for TV Shows called TV Shows I just copied and pasted a Season 1 of a TV Show to the TV Shower folder. Should I have put all these TV Shows in a folder named the TV Show ? Can you please provide more detail? What exactly is under the tv folder, and then what is inside the folder under that? screenshots of folder contents would be great, thanks.
