lai 0 Posted November 7, 2017 Posted November 7, 2017 HiLatest emby server (embyserver-osx-x64-3.2.36.0) on a Mac running High Sierra 10.13.1 transcoding FLAC files (stereo, hires) when playing to Chromecast Audio and when files are encoded above 48000hz (48k and below plays direct).Server and transcoding (for 88.2k and 96k) logs enclosed.Test:Same music encoded at 96k 88.2k and 48khz, all 24bits.Server started, emby app on Android started, casted to Chromecast, played in sequence each music for 10secs1) first @48khz - Direct play2) @ 88k2 hz - transcoded ts aac3) @ 96khz - again transcoding ts aacAll files played direct when using Plex in an identical setup/environment.Best regards,Lai ffmpeg-transcode-575a21e9-ad1a-4d31-bafa-58591b0d0642.txt server-63645672621.txt ffmpeg-transcode-b9a5b197-18c4-428c-8993-b249ed0da24b.txt
Luke 42238 Posted November 8, 2017 Posted November 8, 2017 I've pushed an update to our chromecast receiver. please restart the casting app and try again. thanks.
lai 0 Posted November 8, 2017 Author Posted November 8, 2017 Great... amazing support... it is working now at all bitrates.... I can start the migration to emby... Thanks
