bigeyez 10 Posted November 7, 2017 Posted November 7, 2017 Hi, These folders take a long time when browsing via DLNA and sometimes they timeout (no browsing happpens) Sometimes I get no listings in VLC on Android. Generally I will be able to get the first page listed but I cant go further down the listing, it times out like I said. But these are the only folders that has the issues, when I browse my movies, or latest music etc I do not get any issue like that. I think that something is fishy about the way those are listed. Bear in mind that I have hundreds of thousands of files in my media libraries and about 100k songs in the music lib. thanks
Luke 42239 Posted November 7, 2017 Posted November 7, 2017 Don't you already have a topic about this? I recall discussing this with you before.
bigeyez 10 Posted November 7, 2017 Author Posted November 7, 2017 I do not think so. I just started the Dlna features a week ago. Maybe I did but I doubt. I could not locate my past post if I had such thing. If the discussion was on this issue, I would be happy to read it. But I can find it.
bigeyez 10 Posted November 8, 2017 Author Posted November 8, 2017 (edited) Here is what I get (in BubbleUPNP) when I try to browse album. This happens after I enter the album folder, and some seconds later this message pop up. Sometimes I can browse the album folders, but artists folder is rarely available. They generally time out. Meanwhile "Latest" or regular movie folders are always available for browsing, I never have issues with those. I also have other DLNA servers on the same sevrer sharing the same media libraries and I never have issues with those, it I doubt that it is the hardware or the network. Edited November 8, 2017 by bigeyez
