Nisten 15 Posted November 7, 2017 Posted November 7, 2017 (edited) The last few recordings don't release the tuner or perhaps they don't stop recording when they're supposed. to. This is the 3rd time I've noticed this happening Latest examples -"The Gifted" was supposed to record Mondays from 8-9pm but the dashboard still shows an active recording for last night's (11/6/17) recording -"Crossover" was supposed to record today from 11am-1pm and as of writing this, it is 1:36pm but it still shows that its actively recording As of 1:37pm, i have manually cancelled the "Crossover" recording but i can't cancel "The Gifted" recording (just keep getting a spinning wheel) Since i'm not able to stop the "Crossover" recording that's still active, this recording is still live and taking up a tuner unnecessarily record-transcode 11-6-17 (8pm).txt record-transcode 11-7-17 (1059am).txt server log 11-7-17 (12am).txt server log 11-7-17 (155pm).txt Edited November 7, 2017 by Nisten
Solution Luke 42243 Posted November 9, 2017 Solution Posted November 9, 2017 Try doing this without the recording conversion feature and see if that makes a difference, thanks. 1
Nisten 15 Posted November 9, 2017 Author Posted November 9, 2017 Try doing this without the recording conversion feature and see if that makes a difference, thanks.ok, I'll disable that and see how it goes. Sent from my P01MA using Tapatalk
Nisten 15 Posted November 20, 2017 Author Posted November 20, 2017 Haven't had anymore problems so I think that did the trick
