Pensh 0 Posted November 7, 2017 Posted November 7, 2017 Hello, I’ve recently purchased an Apple TV, and have installed Emby, however when I try to connect to a server it constantly just says welcome “my username” then stays stuck on the spinning wheel, have seen peop,e gave had same issue, but has anybody or does anybody know of the fix?
ebr 16335 Posted November 7, 2017 Posted November 7, 2017 Okay, that will be solved as soon as we get the current beta released. That will hopefully be soon but logging in without Connect should get you going immediately. Thanks.
BEis 21 Posted November 19, 2017 Posted November 19, 2017 Following this topic because I have the same issue with spinning wheel when I'm trying to connect. How can I get access to the beta when it is available?
ebr 16335 Posted November 19, 2017 Posted November 19, 2017 Following this topic because I have the same issue with spinning wheel when I'm trying to connect. How can I get access to the beta when it is available? Hi. The beta mentioned here was release a while back. If you are having an issue now it is something different. Please describe it fully in a new thread. Thanks. How to Report a Problem
