mattykellyuk 18 Posted November 6, 2017 Posted November 6, 2017 (edited) Hi all Bit confused lots of threads so maybe a known issue. Basically a new server and the trakt plugin completes an import task but this doesn't change the playstates and then fails when i try a sync. Hope the attached log is correct. Thanks Edit: uploaded log server-63645564900.txt Edited November 6, 2017 by mattykellyuk
Luke 42203 Posted November 6, 2017 Posted November 6, 2017 The trakt plugin needs an update to respond to Trakt api changes. Until this happens a few features in the plugin may not work correctly. The Emby team will help out with it where we can. While we are here I would just like to mention that the Trakt plugin is a community addition, and contributions are welcome. The source code can be found here: https://github.com/MediaBrowser/trakt Thanks ! 1
