ebr 16335 Posted January 16, 2018 Posted January 16, 2018 here is latest crash log that on box edit: i have attached a console log aswell of SuperGirl S03E03 played and skipped forward till end, then played, then pressed STOP button on screen when it showed. the home page still show S03E03 in NEXT UP. Hmmm... did you get that log from Xcode? I need the javascript console from Safari.
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) Hmmm... did you get that log from Xcode? I need the javascript console from Safari. yes xcode console i dont see anything for emby? Edited January 16, 2018 by andyblac644
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) is this what your after ? javascript.console.txt nextup.txt Edited January 16, 2018 by andyblac644
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 looking at the nextup data the correct ep4 is in the data but, why is it still show the previous episode ep3 still ?
ebr 16335 Posted January 17, 2018 Posted January 17, 2018 yes xcode console i dont see anything for emby? Was this while the app was actually running and in the foreground? The app should show up there if so.
andyblac644 69 Posted January 17, 2018 Posted January 17, 2018 Was this while the app was actually running and in the foreground? The app should show up there if so. yes
andyblac644 69 Posted January 18, 2018 Posted January 18, 2018 (edited) @@ebr anything else i can check ? Edited January 18, 2018 by andyblac644
ebr 16335 Posted January 19, 2018 Posted January 19, 2018 Perhaps your Apple TV needs to be in a "developer mode"...
andyblac644 69 Posted January 19, 2018 Posted January 19, 2018 Perhaps your Apple TV needs to be in a "developer mode"... it is, i see developer menu.
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 anything else i can do ?, really would like to get refresh bug fixed, so i can then buy my elderly mother one, atm it would be too confusing to get her to force quit the app just to see updated home page.
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 I'm sorry, I'm at a total loss as to why you aren't seeing the updates but, when I attached to your server, it worked fine for me.
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 it not just me though, others seeing this as well ?
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 (edited) I'm sorry, I'm at a total loss as to why you aren't seeing the updates but, when I attached to your server, it worked fine for me. could try from yours as a test, see if i get the same ?, to rule out a server / network side issue. Edited January 23, 2018 by andyblac644
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 it not just me though, others seeing this as well ? Yes, at least the OP of this topic. But, without being able to reproduce it in an environment where we can see what is happening, I am at a loss to what it is. Something is going wrong somewhere obviously. Do you have another Apple TV you can test with? To start completely fresh and see if the problem still occurs?
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 sorry had to pop out, no only the one, i want another for mother, but was hoping to get refresh fixed 1st.
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 sorry had to pop out, no only the one, i want another for mother, but was hoping to get refresh fixed 1st. Okay, I invited you to my server...
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 (edited) just tried playing 11.22.63 s01e01, skiped till end press ok on the gui stop button at end. it is not updating Next up on home page so it seems it not a server / network issue ? Edited January 23, 2018 by andyblac644
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 just tried playing 11.22.63 s01e01, skiped till end press ok on the gui stop button at end. it is not updating Next up on home page Aha... that is not how I was stopping the playback. Is this always how you stop playback? What happens if you just use the menu (back) button to back out or let it continue on to the next item?
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 Well, I was hopeful that was the problem but I just did that same thing and it still worked fine for me. When you hit that button and end up back on the detail screen, does the watched check change to red?
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 Well, I was hopeful that was the problem but I just did that same thing and it still worked fine for me. When you hit that button and end up back on the detail screen, does the watched check change to red? yes, it does.
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 Aha... that is not how I was stopping the playback. Is this always how you stop playback? What happens if you just use the menu (back) button to back out or let it continue on to the next item? same thing if using the menu button.
ebr 16335 Posted January 23, 2018 Posted January 23, 2018 yes, it does. same thing if using the menu button. Okay, so that means the stop is getting triggered properly and it is just the updating of the home screen that isn't happening for you. Since it works on my device both on my and your server and doesn't work on your device on both your and my server, that points to something related to that device. With a re-install of the app and everything at defaults, is it still a problem? 1
andyblac644 69 Posted January 23, 2018 Posted January 23, 2018 (edited) hi, it seem the auto login fix has also fixed the refresh too , it is now updating , top man i owe you a beer!!!!! i now can replace my mum's shield with a AppleTV. Edited January 23, 2018 by andyblac644
