fbrassin 47 Posted January 15, 2018 Author Posted January 15, 2018 Well,i stopped episode as it was at the final titles but there still wasn't on the screen next or stop. Does this means i stopped stop early?
andyblac644 69 Posted January 15, 2018 Posted January 15, 2018 (edited) Well, that is quite strange. I just tested this with two different TV series and, in both cases, the screen refreshed immediately and showed the proper next up episodes. The Next Up row also properly re-sorted to show the last played item. If you partially watch something, does it show properly in the "Continue Watching" row when you return? no if i stop 10 mins in, and exit to home screen, i don't see any "Continue Watching" row. until i restart the app. Edited January 15, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 no if i stop 10 mins in, and exit to home screen, i don't see any "Continue Watching" row. until i restart the app. Something very strange is going on with your network communications I think. How to figure out what that is is the next question...
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) the shield updates the home screen ok, but saying that if the shield has a continue watching, and you go finish it, it says in the home screen even after it has been finished, the only to get rid of it, is to go mark the episode not watched, and watched, then when you return to the home screen it gone. Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 The first thing to try, if you have your Emby server setup for external access, would be to add me (ebr) as a guest user and see if I can reproduce the issue from here connected to your server.
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) The first thing to try, if you have your Emby server setup for external access, would be to add me (ebr) as a guest user and see if I can reproduce the issue from here connected to your server. i yes have DM your emby user name, i'll setup a share. EDIT: invite sent. Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 Okay, connected to your server and played the first episode of "Covert Affairs". Fast forwarded to about the half way point and then backed out to the home screen and I immediately got both the Continue Watching row and the Next Up row updated...
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) hmm, strange, so it a network issue? or maybe a direct play issue ? Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 Then moved over to "Misfits" and fast forwarded that one all the way to the end credits. Backed out and episode 2 is now in my next up row. I honestly don't know what is going on. I was hoping I'd have the same problem and be able to tell what it was but it appears to be working fine for me...
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) anything i can do, to help track it down ? btw how did you get a screen shot for AppleTV ? Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 anything i can do, to help track it down ? Do you own a mac? btw how did you get a screen shot for AppleTV ? Using Xcode (the Apple IDE).
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 Do you own a mac? yes Using Xcode (the Apple IDE). ok, got a guide how to setup ?
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 @@ebr can i try a test from your server ?, maybe it something to do with direct play?
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) @@ebr, ok i managed to try a remote share, the "Continue Watching" does show when i skip to 10 mins, and then exit, but letting the show run till the end where the buttons show STOP / START (next episode), pressing stop, and returning to the Home screen i still see the previous episode in the next up, it has not refreshed to the next as it should. Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 Okay, if you have a mac, you can connect your Apple TV to it wirelessly (via iTunes). Once you've done that, you can start our app on the Apple TV and then bring up Safari - which should have a "develop" menu. Bring it down and find the Apple TV and that should expand and give you an option to bring up a debug window for our app. Once that is up, watch the console while you go through the process above. Are there any errors?
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) Okay, if you have a mac, you can connect your Apple TV to it wirelessly (via iTunes). Once you've done that, you can start our app on the Apple TV and then bring up Safari - which should have a "develop" menu. Bring it down and find the Apple TV and that should expand and give you an option to bring up a debug window for our app. Once that is up, watch the console while you go through the process above. Are there any errors? i'm not seeing AppleTV in iTunes ? does the apple tv have to connected wirelessly Edited January 16, 2018 by andyblac644
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 Yes, you have to pair it with the mac (google that) the same as if you were going to use AirPlay. You can also physically connect it with a USB C cable but wireless is easier.
Dibbes 515 Posted January 16, 2018 Posted January 16, 2018 Erik, can you do this with the Windows version of iTunes as well? It doesn't seem to work for me and the documentation for this is scanty at best...
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 Yes, you have to pair it with the mac (google that) the same as if you were going to use AirPlay. You can also physically connect it with a USB C cable but wireless is easier. this? Pair your Mac to your Apple TV If you’re a developer, you can pair your Mac to your Apple TV so you can use developer features and record screenshots or capture video on Apple TV. Here's how: Make sure that your Mac and Apple TV are on the same Wi-Fi network. On your Mac, open Xcode and choose Window > Devices and Simulators. On your Apple TV, go to Settings > Remotes and Devices > Remote App and Devices. In the Xcode device manager, select your Apple TV. Enter the six-digit pin that appears on the Apple TV on your Mac. Your Apple TV is now paired with your Mac. To unpair your Mac, open Xcode > Device Manager, select your Apple TV, then choose Unpair.
ebr 16335 Posted January 16, 2018 Posted January 16, 2018 this? Pair your Mac to your Apple TV If you’re a developer, you can pair your Mac to your Apple TV so you can use developer features and record screenshots or capture video on Apple TV. Here's how: Make sure that your Mac and Apple TV are on the same Wi-Fi network. On your Mac, open Xcode and choose Window > Devices and Simulators. On your Apple TV, go to Settings > Remotes and Devices > Remote App and Devices. In the Xcode device manager, select your Apple TV. Enter the six-digit pin that appears on the Apple TV on your Mac. Your Apple TV is now paired with your Mac. To unpair your Mac, open Xcode > Device Manager, select your Apple TV, then choose Unpair. Yeah, I guess the wireless pairing requires Xcode.
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 ok it paired, Apple TV is busy: Preparing Apple TV for development soon as ready i try to get you more info
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) here is latest crash log that on box edit: i have attached a console log aswell of SuperGirl S03E03 played and skipped forward till end, then played, then pressed STOP button on screen when it showed. the home page still show S03E03 in NEXT UP. Emby.tvOS 16-01-2018, 10-24.crash.zip console.log.zip Edited January 16, 2018 by andyblac644
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 not this time, no, cbr asked for console log, i noticed there where 4 crash logs on box. so posted the latest incase it helped.
