Question about my directories
UNC Network Paths
I had failure also on backups only after upgrade and AlbumArt failure seemed to have triggered them in all occasions.
I re-installed completely and I do NOT use network paths ever I use directory path and share path
D:\Movies
ServerName\\D:\Movies
as example win10 64 fall creators
PC is main workstation and server
But since Sat on fresh install everything works as it should but do not have a startup command or service.
Just reporting same issue with backup before reinstall to note it
nothing needed Luke !
Thanks for the help man
Thanks for the feedback.
