pjshots 4 Posted November 3, 2017 Posted November 3, 2017 (edited) Under Select Listings, you can choose your country, in my case Great Britain. Then, post code is next (removed for this post), then you're supposed to have a list of lineups. This doesn't show up, only a slight drop-down on the menu and no options to select anything. Things done so far: Restarted server Updated server (think a previous update is to blame for this) Removed SD listings from Emby Checked and reset SD password details to be correct Whats next? Know you're going to ask for a log, but any other ideas? Thanks. Edited November 3, 2017 by pjshots
Luke 42237 Posted November 3, 2017 Posted November 3, 2017 SD was offline for maintenance last night. I think they are back up now. To refreshing your guide in emby.
