Umes5 0 Posted March 4, 2014 Posted March 4, 2014 (edited) Hi there, Since the update to MB Server last Saturday I've had a problem with some art not showing up in MB Classic through WMC. It is only happening for my TV Shows directory and it is only happening with maybe a third of the shows. The show info (description etc) is all fine, it is just the banners/background/season art. They are all downloaded in the directories and worked fine before I updated to the last beta on Saturday night my time. I checked the dashboard for SErver and the media library scan is hanging on 67%. I can't seem to stop this manually (it just freezes) I am attaching the log here as well. Any help much appreciated! New Text Document.txt Edited March 4, 2014 by Umes5
ebr 16357 Posted March 4, 2014 Posted March 4, 2014 I checked the dashboard for SErver and the media library scan is hanging on 67%. I can't seem to stop this manually (it just freezes) There is your answer. Moving to server section.
Umes5 0 Posted March 5, 2014 Author Posted March 5, 2014 Any takers? It does appear to be an issue with the scan of the media library but I don't know enough about the inner workings to know why that is the case.
ebr 16357 Posted March 5, 2014 Posted March 5, 2014 Just for kicks go into the Advanced section in the dashboard and disable UPnP. Then try a scan.
