jasonmcroy 320 Posted November 2, 2017 Posted November 2, 2017 On a fresh install of stable version 3.2.36.0 when I try to select the Country for Schedules Direct it just pulls up "undefined" as the listings. This is on Windows 10 using Firefox (and I tried via Edge). I have verified and re-verified my password several times, restarted the Server and my HTPC but still nothing. Screenshot: Logs: server-63645233669.txt
Solution Luke 42203 Posted November 2, 2017 Solution Posted November 2, 2017 Schedules direct is offline for maintenance. 1
jasonmcroy 320 Posted November 2, 2017 Author Posted November 2, 2017 (edited) Ah, thanks. Edit: You guys can delete this thread if you want. Edited November 2, 2017 by jasonmcroy
