GWTPqZp6b 50 Posted May 3, 2023 Posted May 3, 2023 (edited) I spotted a couple of places the log anonymiser isn't anonymising correctly. Primarily the reworked notifications is including both room ID and access token and also lots like the proxy forward header isnt being filtered too. Shonky image with manual anonymising for reference. EDIT: also looks like LiveTV updates dont anonymise correctly... Edited May 3, 2023 by GWTPqZp6b
seanbuff 1356 Posted May 3, 2023 Posted May 3, 2023 On 13/01/2022 at 12:58, seanbuff said: Let's not forget the first few lines which sometimes contains a users real name in the file path: 2022-01-05 00:00:15.632 Info App: Application version: 4.7.0.18 2022-01-05 00:00:15.632 Info App: Emby Command line: C:\Users\MyRealName\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.0-rtm.21522.10 OS/Process: x64/x64 Runtime: C:/Users/MyRealName/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Users\MyRealName\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\MyRealName\AppData\Roaming\Emby-Server\system Also still waiting on OS username path, as reported earlier ...
Luke 42245 Posted May 3, 2023 Posted May 3, 2023 1 hour ago, GWTPqZp6b said: I spotted a couple of places the log anonymiser isn't anonymising correctly. Primarily the reworked notifications is including both room ID and access token and also lots like the proxy forward header isnt being filtered too. Shonky image with manual anonymising for reference. EDIT: also looks like LiveTV updates dont anonymise correctly... Hi, the ones in your first screenshot have all been addressed in the upcoming 4.8 server release. Thanks. 1
adrianwi 279 Posted September 7, 2024 Author Posted September 7, 2024 I needed to use this again recently, and I still have some problems with how emby is doing this. Surely the default should be an anonymous log? If I go into the Admin console, select logs, click the hamburger icon, and select download, I don't download an anonymous log. This should be the default, surely? You have to click into the log file where you see the anonymised switch and click download from there. Also, if you have an IPTV service set up, the details, including the password, are displayed in the log file regardless of whether you have anonymised selected it or not. This isn't good! 2024-08-25 12:46:54.917 Error HttpClient: Connection to http://URL:8080/username/password/109 timed out Can this be reviewed again to ensure that nobody is being asked to post private details on a public forum to receive support? Thanks 2 1
