tvinhas 14 Posted November 1, 2017 Posted November 1, 2017 Hi, I tried disabling the Nfo metadata as posted on https://emby.media/community/index.php?/topic/44972-enabledisable-nfo-metadata/ , but Emby is still generating those files inside of the show directory, season and episode. Any way I can have Emby to not generate those at all?
ebr 16309 Posted November 1, 2017 Posted November 1, 2017 Hi. Uncheck the option labeled "Save artwork and metadata into media folders" under each library.
Luke 42203 Posted November 1, 2017 Posted November 1, 2017 @@tvinhas, actually this is disabled by default, so the only way you got NFO files was by turning it on.
tvinhas 14 Posted November 1, 2017 Author Posted November 1, 2017 Thanks guys, but I don't have that option enabled. Here is what I have for my library:
Happy2Play 9802 Posted November 1, 2017 Posted November 1, 2017 Thanks guys, but I don't have that option enabled. Here is what I have for my library: Look at the Metadata menu in Library, you will have to use the drop down to look at each content type.
tvinhas 14 Posted November 1, 2017 Author Posted November 1, 2017 Thanks, but I've already disabled Nfo in all of them. Do I need to restart the server after this change?
Happy2Play 9802 Posted November 1, 2017 Posted November 1, 2017 (edited) Emby will not delete any metadata already created. You have to manually do that. After saying that are you still getting nfo files in new media? I can't reproduce nfo creation with option disabled. Edited November 1, 2017 by Happy2Play
Luke 42203 Posted November 2, 2017 Posted November 2, 2017 Yes happy2play is correct. The only thing this changes is that it won't save new nfo going forward. It will not remove existing nfo files. Also, did you use the media type dropdown to uncheck the box for all media types? Thanks.
ebr 16309 Posted November 2, 2017 Posted November 2, 2017 Please consider un-checking download images in advance.
