Deuce911 10 Posted March 4, 2014 Posted March 4, 2014 What is the recommended way to add a TV series for Auto Organize to work, I have looked and can not seen to find any information about it? I want to add a new Series but even if I manually create the sub directory and restart the server it will not show up in the Edit Metadata screen. I want to retire MediCenter Master but until Movies are handled and it can create new TV Series I have to still keep it around. Thanks for the help and great product.
Luke 42301 Posted March 4, 2014 Posted March 4, 2014 create the series folder, then create a season folder. the realtime monitor should pick it up in 20 seconds or so and start downloading metadata.
Deuce911 10 Posted March 4, 2014 Author Posted March 4, 2014 I tried as you suggested and created a Folder called "Franklin and Bash" with 3 season folders names "Season 1" through "Season 3", nothing happened. Here is the log file. 3 17:37:56.5899 Info - Main: Media Browser Server started 2014-03-03 17:37:56.5899 Info - Main: Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe 2014-03-03 17:37:56.6055 Info - Main: Server: WHS-2 2014-03-03 17:37:56.6055 Info - Main: Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 2014-03-03 17:37:56.6055 Info - Main: Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server 2014-03-03 17:37:56.6055 Info - Main: Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe 2014-03-03 17:37:56.8395 Info - App: Application Configuration: 2014-03-03 17:37:56.8551 Info - App: Loading AutoBoxSets, Version=0.0.1.2, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading CoverArt, Version=4.0.5.5, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.Plugins.RottenTomatoes, Version=1.0.5169.19908, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading Trakt, Version=1.9.5165.28649, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading wmc2mb, Version=1.0.0.26, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.Api, Version=3.0.5171.19958, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5171.19957, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.Model, Version=3.0.5171.19956, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.Common, Version=3.0.5171.19957, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8551 Info - App: Loading MediaBrowser.Controller, Version=3.0.5171.19957, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.Providers, Version=3.0.5171.19958, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5171.19957, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5171.19958, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5171.19958, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.IsoMounter, Version=1.0.5079.1480, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.8707 Info - App: Loading MediaBrowser.ServerApplication, Version=3.0.5171.19958, Culture=neutral, PublicKeyToken=null 2014-03-03 17:37:56.9643 Info - App: Version 3.0.5171.19958 initializing 2014-03-03 17:37:57.0111 Info - SqliteUserRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\users.db 2014-03-03 17:37:57.0579 Info - SqliteItemRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\chapters.db 2014-03-03 17:37:57.0579 Info - SqliteItemRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\mediainfo.db 2014-03-03 17:37:57.0579 Info - SqliteFileOrganizationRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\fileorganization.db 2014-03-03 17:37:57.1827 Info - SqliteDisplayPreferencesRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\displaypreferences.db 2014-03-03 17:37:57.1827 Info - SqliteItemRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\library.db 2014-03-03 17:37:57.1827 Info - SqliteNotificationsRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\notifications.db 2014-03-03 17:37:57.1827 Info - SqliteUserDataRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\userdata_v2.db 2014-03-03 17:37:57.1827 Info - SqliteProviderInfoRepository: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\refreshinfo.db 2014-03-03 17:37:57.3387 Info - HttpServer: Calling ServiceStack AppHost.Init 2014-03-03 17:37:57.8379 Info - ServiceStackHost: Initializing Application took 748.8014ms 2014-03-03 17:37:57.8535 Info - App: Loading Http Server 2014-03-03 17:37:57.8535 Info - HttpServer: Adding HttpListener prefix http://+:8096/mediabrowser/ 2014-03-03 17:37:57.8535 Info - HttpServer: Starting HttpListner 2014-03-03 17:37:57.8691 Info - App: Starting Alchemy web socket server on port 8945 2014-03-03 17:37:57.8691 Info - App: Alchemy Web Socket Server started 2014-03-03 17:37:58.7739 Info - ServerWMC: Config IP: 192.168.1.210 (192.168.1.210), Config Port: 9080 2014-03-03 17:38:00.0219 Info - App: Core startup complete 2014-03-03 17:38:02.6739 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2014-03-03 17:38:02.6739 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2014-03-03 17:38:02.8143 Info - App: HttpClientManager POST: http://api.trakt.tv/account/settings/77449c38c9f4f9b3cdb8d3f9ef0566b167a935eb 2014-03-03 17:38:02.9859 Info - App: HttpClientManager POST: http://api.trakt.tv/account/settings/77449c38c9f4f9b3cdb8d3f9ef0566b167a935eb 2014-03-03 17:38:03.5163 Info - App: StartupTrigger fired for task: Refresh Guide 2014-03-03 17:38:03.5319 Info - App: Executing Refresh Guide 2014-03-03 17:38:03.5475 Info - App: HttpClientManager POST: http://api.trakt.tv/account/settings/77449c38c9f4f9b3cdb8d3f9ef0566b167a935eb 2014-03-03 17:38:03.5787 Info - App: StartupTrigger fired for task: Check for application updates 2014-03-03 17:38:03.5787 Info - App: Executing Check for application updates 2014-03-03 17:38:03.5943 Info - App: Check for application updates Completed after 0 minute(s) and 0 seconds 2014-03-03 17:38:03.6255 Info - App: StartupTrigger fired for task: Check for plugin updates 2014-03-03 17:38:03.6255 Info - App: Executing Check for plugin updates 2014-03-03 17:38:03.6255 Info - App: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2014-03-03 17:38:03.6411 Info - App: StartupTrigger fired for task: Log file cleanup 2014-03-03 17:38:03.6411 Info - App: Executing Log file cleanup 2014-03-03 17:38:03.6567 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds 2014-03-03 17:38:03.6723 Info - App: StartupTrigger fired for task: Cache file cleanup 2014-03-03 17:38:03.6723 Info - App: Executing Cache file cleanup 2014-03-03 17:38:03.7191 Info - App: HttpClientManager POST: http://api.trakt.tv/account/settings/77449c38c9f4f9b3cdb8d3f9ef0566b167a935eb 2014-03-03 17:38:04.1403 Info - App: HttpClientManager POST: http://api.trakt.tv/account/settings/77449c38c9f4f9b3cdb8d3f9ef0566b167a935eb 2014-03-03 17:38:04.2963 Info - CoverArt: CoverArt Version 4.0.5.5 Loaded. 2014-03-03 17:38:04.3899 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:04.7955 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3ServerNotifications.json 2014-03-03 17:38:04.8423 Info - App: HttpClientManager GET: http://mediabrowser.tv/community/index.php?/blog/rss/1-media-browser-developers-blog 2014-03-03 17:38:04.9047 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:05.1075 Info - App: Cache file cleanup Completed after 0 minute(s) and 1 seconds 2014-03-03 17:38:06.9172 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:09.3664 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping 2014-03-03 17:38:14.2180 Info - App: Refresh Guide Completed after 0 minute(s) and 10 seconds 2014-03-03 17:38:14.9200 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:17.8840 Warn - Automatic BoxSets: Please configure the BoxSet Path in the Auto BoxSets plug-in. 2014-03-03 17:38:21.5968 Info - App: Client connected from 192.168.1.90:65014 2014-03-03 17:38:46.9312 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:47.1964 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:48.2104 Error - App: Error reported by Mono.Nat: 2014-03-03 17:38:52.2196 Error - App: Error reported by Mono.Nat: 2014-03-03 17:39:04.3409 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/ 2014-03-03 17:49:08.2335 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:08.7483 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:10.7607 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:18.7635 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:50.7748 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:51.0400 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:52.0540 Error - App: Error reported by Mono.Nat: 2014-03-03 17:49:56.0632 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:12.0771 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:12.5919 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:14.6043 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:22.6071 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:54.6184 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:54.8836 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:55.8976 Error - App: Error reported by Mono.Nat: 2014-03-03 18:00:59.9068 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:15.9206 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:16.4354 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:18.4478 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:26.4507 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:58.4619 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:58.7271 Error - App: Error reported by Mono.Nat: 2014-03-03 18:11:59.7411 Error - App: Error reported by Mono.Nat: 2014-03-03 18:12:03.7503 Error - App: Error reported by Mono.Nat: 2014-03-03 18:22:19.7642 Error - App: Error reported by Mono.Nat: 2014-03-03 18:22:20.2790 Error - App: Error reported by Mono.Nat: 2014-03-03 18:22:22.2914 Error - App: Error reported by Mono.Nat: 2014-03-03 18:22:30.2942 Error - App: Error reported by Mono.Nat: 2014-03-03 18:23:02.3055 Error - App: Error reported by Mono.Nat: 2014-03-03 18:23:02.5707 Error - App: Error reported by Mono.Nat: 2014-03-03 18:23:03.5847 Error - App: Error reported by Mono.Nat: 2014-03-03 18:23:07.5939 Error - App: Error reported by Mono.Nat: 2014-03-03 18:33:23.6078 Error - App: Error reported by Mono.Nat: 2014-03-03 18:33:24.1226 Error - App: Error reported by Mono.Nat: 2014-03-03 18:33:26.1350 Error - App: Error reported by Mono.Nat: 2014-03-03 18:33:34.1378 Error - App: Error reported by Mono.Nat: 2014-03-03 18:34:06.1491 Error - App: Error reported by Mono.Nat: 2014-03-03 18:34:06.4143 Error - App: Error reported by Mono.Nat: 2014-03-03 18:34:07.4283 Error - App: Error reported by Mono.Nat: 2014-03-03 18:34:11.4375 Error - App: Error reported by Mono.Nat: 2014-03-03 18:38:00.1651 Info - App: IntervalTrigger fired for task: Organize new media files 2014-03-03 18:38:00.1651 Info - App: Executing Organize new media files 2014-03-03 18:38:00.2119 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e10.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E10.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 18:38:00.3523 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.3523 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E08.720p.HDTV.x264-EVOLVE\Franklin.and.Bash.S03E08.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 18:38:00.3835 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.3835 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E09.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E09.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 18:38:00.4303 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.4303 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e07.720p.hdtv.x264-2hd\franklin.and.bash.s03e07.720p.hdtv.x264-2hd.mp4 2014-03-03 18:38:00.4615 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.4615 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e06.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E06.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 18:38:00.4771 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.4771 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e05.proper.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E05.PROPER.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 18:38:00.5239 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.5239 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E04.720p.HDTV.x264-IMMERSE\Franklin.and.Bash.S03E04.720p.HDTV.x264-IMMERSE.mp4 2014-03-03 18:38:00.6175 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.6175 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e03.720p.hdtv.x264-2hd\franklin.and.bash.s03e03.720p.hdtv.x264-2hd.mp4 2014-03-03 18:38:00.6955 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.6955 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E02.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E02.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 18:38:00.7423 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.7423 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E01.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E01.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 18:38:00.8047 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.8047 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E10.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E10.6.50.to.SLC.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 18:38:00.8827 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.8827 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E09.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E09.Waiting.On.a.Friend.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 18:38:00.9763 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:00.9763 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E08.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E08.Last.Dance.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 18:38:01.0387 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:01.0387 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E07.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E07.Summer.Girls.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 18:38:01.0855 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 18:38:01.1167 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds 2014-03-03 18:44:27.4513 Error - App: Error reported by Mono.Nat: 2014-03-03 18:44:27.9661 Error - App: Error reported by Mono.Nat: 2014-03-03 18:44:29.9785 Error - App: Error reported by Mono.Nat: 2014-03-03 18:44:37.9814 Error - App: Error reported by Mono.Nat: 2014-03-03 18:45:09.9926 Error - App: Error reported by Mono.Nat: 2014-03-03 18:45:10.2578 Error - App: Error reported by Mono.Nat: 2014-03-03 18:45:11.2718 Error - App: Error reported by Mono.Nat: 2014-03-03 18:45:15.2810 Error - App: Error reported by Mono.Nat: 2014-03-03 18:55:31.2949 Error - App: Error reported by Mono.Nat: 2014-03-03 18:55:31.8097 Error - App: Error reported by Mono.Nat: 2014-03-03 18:55:33.8221 Error - App: Error reported by Mono.Nat: 2014-03-03 18:55:41.8249 Error - App: Error reported by Mono.Nat: 2014-03-03 18:56:13.8362 Error - App: Error reported by Mono.Nat: 2014-03-03 18:56:14.1014 Error - App: Error reported by Mono.Nat: 2014-03-03 18:56:15.1154 Error - App: Error reported by Mono.Nat: 2014-03-03 18:56:19.1246 Error - App: Error reported by Mono.Nat: 2014-03-03 19:06:35.1385 Error - App: Error reported by Mono.Nat: 2014-03-03 19:06:35.6533 Error - App: Error reported by Mono.Nat: 2014-03-03 19:06:37.6657 Error - App: Error reported by Mono.Nat: 2014-03-03 19:06:45.6685 Error - App: Error reported by Mono.Nat: 2014-03-03 19:07:17.6797 Error - App: Error reported by Mono.Nat: 2014-03-03 19:07:17.9449 Error - App: Error reported by Mono.Nat: 2014-03-03 19:07:18.9590 Error - App: Error reported by Mono.Nat: 2014-03-03 19:07:22.9682 Error - App: Error reported by Mono.Nat: 2014-03-03 19:17:38.9820 Error - App: Error reported by Mono.Nat: 2014-03-03 19:17:39.4968 Error - App: Error reported by Mono.Nat: 2014-03-03 19:17:41.5092 Error - App: Error reported by Mono.Nat: 2014-03-03 19:17:49.5121 Error - App: Error reported by Mono.Nat: 2014-03-03 19:18:21.5233 Error - App: Error reported by Mono.Nat: 2014-03-03 19:18:21.7885 Error - App: Error reported by Mono.Nat: 2014-03-03 19:18:22.8025 Error - App: Error reported by Mono.Nat: 2014-03-03 19:18:26.8117 Error - App: Error reported by Mono.Nat: 2014-03-03 19:28:42.8256 Error - App: Error reported by Mono.Nat: 2014-03-03 19:28:43.3404 Error - App: Error reported by Mono.Nat: 2014-03-03 19:28:45.3528 Error - App: Error reported by Mono.Nat: 2014-03-03 19:28:53.3556 Error - App: Error reported by Mono.Nat: 2014-03-03 19:29:25.3669 Error - App: Error reported by Mono.Nat: 2014-03-03 19:29:25.6321 Error - App: Error reported by Mono.Nat: 2014-03-03 19:29:26.6461 Error - App: Error reported by Mono.Nat: 2014-03-03 19:29:30.6553 Error - App: Error reported by Mono.Nat: 2014-03-03 19:38:01.2286 Info - App: IntervalTrigger fired for task: Organize new media files 2014-03-03 19:38:01.2286 Info - App: Executing Organize new media files 2014-03-03 19:38:01.2598 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e10.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E10.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 19:38:01.2910 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.3066 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E08.720p.HDTV.x264-EVOLVE\Franklin.and.Bash.S03E08.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 19:38:01.3378 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.3378 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E09.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E09.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 19:38:01.4158 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.4158 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e07.720p.hdtv.x264-2hd\franklin.and.bash.s03e07.720p.hdtv.x264-2hd.mp4 2014-03-03 19:38:01.4626 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.4626 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e06.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E06.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 19:38:01.4938 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.4938 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e05.proper.720p.hdtv.x264-evolve\Franklin.and.Bash.S03E05.PROPER.720p.HDTV.x264-EVOLVE.mp4 2014-03-03 19:38:01.5406 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.5562 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E04.720p.HDTV.x264-IMMERSE\Franklin.and.Bash.S03E04.720p.HDTV.x264-IMMERSE.mp4 2014-03-03 19:38:01.5874 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.5874 Info - App: Sorting file \\Dad-PC\Finished Files\franklin.and.bash.s03e03.720p.hdtv.x264-2hd\franklin.and.bash.s03e03.720p.hdtv.x264-2hd.mp4 2014-03-03 19:38:01.6186 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.6186 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E02.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E02.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 19:38:01.6498 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.6498 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S03E01.720p.WEB-DL.DD5.1.H.264-KiNGS\Franklin.and.Bash.S03E01.720p.WEB-DL.DD5.1.H.264-KiNGS.mp4 2014-03-03 19:38:01.6966 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.6966 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E10.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E10.6.50.to.SLC.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:01.7278 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.7278 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E09.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E09.Waiting.On.a.Friend.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:01.7746 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.7746 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E08.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E08.Last.Dance.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:01.8058 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.8058 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E07.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E07.Summer.Girls.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:01.8838 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.8838 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E06.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E06.Voir.Dire.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:01.9462 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:01.9462 Info - App: Sorting file \\Dad-PC\Finished Files\Franklin.and.Bash.S02E05.720p.WEB-DL.DD5.1.H.264\Franklin.and.Bash.S02E05.L'Affaire.du.Coeur.720p.WEB-DL.DD5.1.H.264-CtrlHD.mp4 2014-03-03 19:38:02.0086 Warn - App: Unable to find series in library matching name franklin.and.bash. 2014-03-03 19:38:02.0086 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds 2014-03-03 19:39:46.6692 Error - App: Error reported by Mono.Nat: 2014-03-03 19:39:47.1840 Error - App: Error reported by Mono.Nat: 2014-03-03 19:39:49.1964 Error - App: Error reported by Mono.Nat: 2014-03-03 19:39:57.1992 Error - App: Error reported by Mono.Nat: 2014-03-03 19:40:29.2104 Error - App: Error reported by Mono.Nat: 2014-03-03 19:40:29.4756 Error - App: Error reported by Mono.Nat: 2014-03-03 19:40:30.4896 Error - App: Error reported by Mono.Nat: 2014-03-03 19:40:34.4989 Error - App: Error reported by Mono.Nat: 2014-03-03 19:50:50.5127 Error - App: Error reported by Mono.Nat: 2014-03-03 19:50:51.0275 Error - App: Error reported by Mono.Nat: 2014-03-03 19:50:53.0399 Error - App: Error reported by Mono.Nat: 2014-03-03 19:51:01.0428 Error - App: Error reported by Mono.Nat: 2014-03-03 19:51:33.0540 Error - App: Error reported by Mono.Nat: 2014-03-03 19:51:33.3192 Error - App: Error reported by Mono.Nat: 2014-03-03 19:51:34.3332 Error - App: Error reported by Mono.Nat: 2014-03-03 19:51:38.3424 Error - App: Error reported by Mono.Nat: 2014-03-03 20:01:54.3563 Error - App: Error reported by Mono.Nat: 2014-03-03 20:01:54.8711 Error - App: Error reported by Mono.Nat: 2014-03-03 20:01:56.8835 Error - App: Error reported by Mono.Nat: 2014-03-03 20:02:04.8863 Error - App: Error reported by Mono.Nat: 2014-03-03 20:02:36.8976 Error - App: Error reported by Mono.Nat: 2014-03-03 20:02:37.1628 Error - App: Error reported by Mono.Nat: 2014-03-03 20:02:38.1768 Error - App: Error reported by Mono.Nat: 2014-03-03 20:02:42.1860 Error - App: Error reported by Mono.Nat: 2014-03-03 20:12:58.1999 Error - App: Error reported by Mono.Nat: 2014-03-03 20:12:58.7147 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:00.7271 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:08.7299 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:40.7411 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:41.0063 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:42.0203 Error - App: Error reported by Mono.Nat: 2014-03-03 20:13:46.0296 Error - App: Error reported by Mono.Nat: 2014-03-03 20:19:51.8346 Info - App: Client connected from 192.168.1.90:63551 2014-03-03 20:21:19.7876 Info - App: Client connected from 192.168.1.90:63652 2014-03-03 20:21:36.8384 Info - App: LogFileWebSocketListener Begin transmitting over websocket to 192.168.1.90:63652 2014-03-03 20:24:02.0434 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:02.5582 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:04.5706 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:12.5735 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:44.5847 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:44.8499 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:45.8639 Error - App: Error reported by Mono.Nat: 2014-03-03 20:24:49.8731 Error - App: Error reported by Mono.Nat:
Luke 42301 Posted March 4, 2014 Posted March 4, 2014 well you have to get the series to show up in your library first. then after that, auto-organize will work
Deuce911 10 Posted March 4, 2014 Author Posted March 4, 2014 That is the question that I have, what do I have to do to get it to show up? I created the folders now what is the next step? I know I can get it started with Media Center Master but I would prefer not to use it. I don't mean to be a pain but what am I missing? Thanks in advance.
Luke 42301 Posted March 4, 2014 Posted March 4, 2014 see post #2. that's about it. if the realtime monitor doesn't pick it up run a library scan.
politby 88 Posted March 4, 2014 Posted March 4, 2014 Is there an ETA on when auto organize will be able to create library entries for new series? Sent from my Nexus 4 using Tapatalk
AshranPewter 6 Posted March 5, 2014 Posted March 5, 2014 Is there an ETA on when auto organize will be able to create library entries for new series? Sent from my Nexus 4 using Tapatalk I'm interested if this is on the planning board for this feature as well. Automatically creating series/season folders would take an annoying step out of the equation for automating everything.
