Paxalou 4 Posted October 31, 2017 Posted October 31, 2017 (edited) Hi, I always update to the newest version as soon as I can... So did I , recently. Burt now, nothing works anymore .... I mean, I have a beautifl halloween background with nice music (thanks! ) but, all my movie covers have disappeared, and it's impossible to play any movie... So... I don't understand... EDIT: oh , it seems that I can play some movies...But...The cover are not back..And if I "identify" a movie, the cover is set, opk, but if I browse a little in Emby and than come back again into the library, the cover has disappeared again... Edited October 31, 2017 by Paxalou
Luke 42245 Posted October 31, 2017 Posted October 31, 2017 Hi, have you tried running a library scan? thanks.
Paxalou 4 Posted October 31, 2017 Author Posted October 31, 2017 (edited) Oh, I just did it, and now, everything has disappeared from the main page... ! Edited October 31, 2017 by Paxalou
Luke 42245 Posted October 31, 2017 Posted October 31, 2017 Check the library access settings for your emby users. Make sure each emby user has access to the libraries. Thanks.
Paxalou 4 Posted October 31, 2017 Author Posted October 31, 2017 (edited) What a big mess here... I have acess to all libraries. (4 librairies) The other user, my girlfriend, has normally access to 2 librairies. But in "Users - > MyGirlFirend", I can only select "camera uplaods" and all the libraries has...disapeared... hum... EDIT: by the way: updating a librairie is now an non-ending process...This screen is never terminating... Edited October 31, 2017 by Paxalou
Paxalou 4 Posted October 31, 2017 Author Posted October 31, 2017 (edited) I have 4 libraires, and here is the main page : It's such a mess here...Maybe I should uninstall everything, apurge conf files ? If yes, how do I that ? EDIT; oh and another strange thing : When I go to "Library", then select a library, and the go to "Manage folders", every change I do are not saved. Example: I select "Enable real time monitoring" and I choose a "Preferred metadata language", but none of these changes are saved. Never. I can repeat tht again and again, but this is never saved.... Just now tell me how I can create a library... Nothing works here ! Oh my God, everything was so fine before halloween... Re-EDIT: Oh-oh, I did a little "sudo apt-get remove emby-server --purge", and the a little "sudo dpkg -i emby-server-deb_3.2.35.0_amd64.deb"...and now, it seems to work... hum.. I think you made something wrong with your update... So, just tell me where was the problem...on my side on on your side ? Thanks for your answer... Edited October 31, 2017 by Paxalou
