Sp3kt3r 13 Posted October 30, 2017 Posted October 30, 2017 I'm having issue with Chromecast, can't connect, just blackscreen. Other apps works fine (youtube, netflix...) I tried with webapp and also android app and with more than one chromecast. I also restarted emby... what else should I tried ?
Luke 42203 Posted October 30, 2017 Posted October 30, 2017 Hi, restart your casting app and try again, thanks.
Sp3kt3r 13 Posted October 30, 2017 Author Posted October 30, 2017 (edited) Ok, I did a full reboot of everything (chromecast, and chrome explorer (web app) and now it's working. what did you do ? BUT it takes a while to see the "ready to cast'' at least a good 10 second... ? no big deal but what could cause that ? network issue ? I'll have to look Thx luke ! Edited October 30, 2017 by Sp3kt3r
Sp3kt3r 13 Posted October 31, 2017 Author Posted October 31, 2017 Just a quick update.. on my side everything is back to normal.
kaithar 0 Posted November 1, 2017 Posted November 1, 2017 Ditto, I suspect I was running in to chromecast caching even though I had tried to hard reboot the thing. Ignored it for a day and it started working again
