Help Qnap TS-231P...
I'm looking to buy a Qnap ts 231p, but I have many doubts. would it support at least 20 clients connected to the emby? the cost here in Brazil is too high for the wrong investment. Can someone help?
Edited by InMemoriam
PenkethBoy
Hi
Can you gives some more info on what clients you want to use?
also will the client be on you lan or wan or a mixture?
your media would have to be in a format to avoid transcoding as the nas might be able to do one transcode stream but not much more
