RedBaron164 18 Posted October 27, 2017 Posted October 27, 2017 (edited) I'm running the Emby app on a Pixel XL running Android 8. If I have a music queue or playlist going it will play usually two songs and stop playing due to the screen locking. If I unlock the screen it will usually resume playing. It has the same behavior if I'm using bluetooth speakers or the headphone jack. Is there anyway to fix this so music will continue to play with the screen locked? *Edit - I re-produced the issue yesterday and pulled logs off my phone and attached them here. a4f1fa71-7334-44b7-ba5a-5f114648671c.log Edited November 1, 2017 by RedBaron164
wedgekc 12 Posted December 16, 2017 Posted December 16, 2017 hi @wedgekc, we're looking into this, thanks. I know you said it happens even with the screen on, but i'm going to lock this and refer you here: https://emby.media/c...creen-turns-off because it is all connected. So please monitor that topic for updates. Thanks ! I did a quick search on the okhttp client and the error and the okhttp client seems to be the problem and it has been a problem for a while. Is this the same issue that causes streaming to stop when switching networks (wifi to 4g)?
Luke 42244 Posted December 16, 2017 Posted December 16, 2017 We're looking into it, thanks. And no, I don't think it's related to okhttp as the audio player doesn't utilize that. 1
Luke 42244 Posted December 19, 2017 Posted December 19, 2017 As a test, can you please try out this version? https://emby.media/community/index.php?/topic/53753-emby-for-android-libmpv-testing/ Thanks !
RedBaron164 18 Posted December 21, 2017 Author Posted December 21, 2017 As a test, can you please try out this version? https://emby.media/community/index.php?/topic/53753-emby-for-android-libmpv-testing/ Thanks ! Will I need to side load this or is it listed in the Google Play store?
Luke 42244 Posted December 21, 2017 Posted December 21, 2017 That's a side load. Instructions are in the thread. Thanks.
wedgekc 12 Posted December 22, 2017 Posted December 22, 2017 Unfortunately, the new app/player does not resolve the issue for me. The stream still dies after a song or two. The new player is transcoding my mp3s, too.
Luke 42244 Posted December 28, 2017 Posted December 28, 2017 Please try the test version again, thanks.
Luke 42244 Posted January 25, 2018 Posted January 25, 2018 There are improvements for this in the beta version of the app. If you'd like to try that you can learn how here: https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ Thanks ! 1
sparkplug188 3 Posted September 9, 2018 Posted September 9, 2018 I encountered this same problem on my Pixel XL running Android 9. I happen to use a Sennheiser Momentum 2.0 Bluetooth headset, but the problem also occurs using the speakers and headphone jack, same as OP. The only unusual thing is how this problem started after seemingly no change on my part. I stream music from the app daily, until one day it wouldn't autoplay with the phone locked. These things did not resolve the problem: Restarted the app and rebooted (many times) Uninstalled the app and reinstalled the latest stable version Switched to the beta version Gave the app permission to access storage Enabled Unrestricted data usage in Android's app settings menu Turned off Battery Optimization in Android's app settings menu Unpaired the headset and paired it back again Turned on Smartlock to keep the phone unlocked while paired to my headset This did resolve the problem: Disable the Android lock screen entirely by removing my PINI consider this an acceptable work-around and the issue is resolved.
phrogz 0 Posted September 17, 2018 Posted September 17, 2018 Since one or two weeks, same issue here, can't remove the Pin (having some client certificates for WiFi). But it seems to happen also when the app is running in the background (just happen when I was writing the message here).
phrogz 0 Posted September 17, 2018 Posted September 17, 2018 So I was able to reproduce one bug... I don't know if it is linked to this issue: Launch the emby app, play an album, and press back icon (in the Android navigation) until seeing the Android main screen, the music will stop, but you will still have an unresponsive "emby banner" in the notification bar: you can tap on anything like play, next, previous, or if you tap the banner it doesn't show the emby app. Android ver:8.0.0 Model:lg v30+
Luke 42244 Posted September 17, 2018 Posted September 17, 2018 We'll do some testing on this, thanks,.
Joe Farmer 2 Posted September 27, 2018 Posted September 27, 2018 (edited) I have the same problem since my phone update to Android 8.0.0, as long as the screen is not locked it plays music without issue, even if the Emby app is not on the screen but as soon as the screen locks it will play another one or two songs at most before it stops. I then have to unlock the screen and open the app for it to start again, very frustrating when trying to listen to music in my car through an AUX connection (not bluetooth). Before the Android 8.0.0 update it was working fine though. I have tried the Always on Screen setting but that didn't work, can't seem to find any options on the phone to stop it going to sleep or to allow Emby to keep running in the background while the phone is asleep. Edited September 27, 2018 by Joe Farmer
stuclark 0 Posted September 27, 2018 Posted September 27, 2018 Just to add; after the initial report of this issue, the problem was fixed in an Embryo release a few months ago (even on Android 8) before now returning as an issue. I'm afraid I can't be more specific on dates as I didn't keep a track of when it started working as expected and when it broke again... In fact my only notification that it was broken was the resurrection of this thread Sent from my LM-G710 using Tapatalk
Joe Farmer 2 Posted September 27, 2018 Posted September 27, 2018 Just to add; after the initial report of this issue, the problem was fixed in an Embryo release a few months ago (even on Android 8) before now returning as an issue. I'm afraid I can't be more specific on dates as I didn't keep a track of when it started working as expected and when it broke again... In fact my only notification that it was broken was the resurrection of this thread Sent from my LM-G710 using Tapatalk For me it definitely started after the Android 8.0.0 update a couple of weeks ago. Before that I had no problems with the Emby app on the Play Store which was only installed a few months ago.
letterman 40 Posted September 27, 2018 Posted September 27, 2018 I have the same problem since update to android 8.0.0 / Samsung Experience-Version 9.0 on Galaxy S9+ Always changes and problems in main and very important features. It is really frustrating. I think it's not the fault of emby, Android seems to change security settings. but emby neets to react fast. Others players don't stop. It is not a new thing, that emby is very sensitive playing the next song since I use it. Hope that this will be solved soon (also in connection with gapless playing...)
darkassassin07 674 Posted September 27, 2018 Posted September 27, 2018 I have the same problem on android 7.1.1 App 3.0.16 If emby is not the active app with the screen unlocked, playback pauses after a song or two.
Joe Farmer 2 Posted September 28, 2018 Posted September 28, 2018 (edited) We are looking into it, thanks guys. Hi Luke, Not sure if this helps but I found when you go into App Permissions for the Emby app there is only one permission you can turn on/off which is Storage but setting that doesn't solve the problem. What I did notice however is if you tap All Permissions it shows a number of permissions you can't turn on/off and one of those is 'Prevent phone from sleeping' which I assume is the problem in that the app does not prevent the phone from sleeping which stops playback. Hence why it takes a song or two, depending on the length of the song, for it to stop playing after the screen locks. Edited September 28, 2018 by Joe Farmer
Hallscottd@gmail.com 0 Posted October 1, 2018 Posted October 1, 2018 Started happening with me sometime in the past week. Note 9, Android 8.1.0, Emby for Android client Mobile 3.0.16, Server version 3.5.3.0, bluetooth speaker. It was working fine last time I used it, a little over a week ago. Now runs about 5-7 minutes then stops after completing the track.
ghost2015 1 Posted October 2, 2018 Posted October 2, 2018 Hi, have the same problem on Mi MIX2 phone after update to android 8 and MIUI 10
