kanipek 230 Posted October 26, 2017 Author Posted October 26, 2017 Reporting back. Just finished a guide refresh. 3.2.34 all the guide data is now back. 1
clarkss12 304 Posted October 26, 2017 Posted October 26, 2017 Same problem here. I just installed LibreELEC on my Mecool M8S Pro (Amlogic S912), and installed Emby server from there. For 2 days, I have been trying to get the EPG to populate, but it only populates 7 channels from about 36 channels. I tested my other servers, and they all populate with current data. I am running Emby server Version 3.2.27.0 Schedules Direct for guide data. Server log.txt
Spames 2 Posted October 26, 2017 Posted October 26, 2017 Reporting back. Just finished a guide refresh. 3.2.34 all the guide data is now back. Huh! Yeah, me too. refresh took a little longer.
TylerV76 84 Posted October 26, 2017 Posted October 26, 2017 Reporting back. Just finished a guide refresh. 3.2.34 all the guide data is now back. Same here
SikSlayer 254 Posted October 26, 2017 Posted October 26, 2017 Reporting back. Just finished a guide refresh. 3.2.34 all the guide data is now back. Same for me.
clarkss12 304 Posted October 26, 2017 Posted October 26, 2017 Just performed a guide refresh, but still no improvement, missing most of my guide data.
TylerV76 84 Posted October 26, 2017 Posted October 26, 2017 Just performed a guide refresh, but still no improvement, missing most of my guide data. There was an issue with version .27 back in August. Have you tried it on the current version?
clarkss12 304 Posted October 26, 2017 Posted October 26, 2017 There was an issue with version .27 back in August. Have you tried it on the current version? Unfortunately, I am at the mercy of the LibreELEC/Emby mods...... I really was shocked to see the .27 version, when I installed the Emby server on my LibreELEC box.
Luke 42243 Posted October 26, 2017 Posted October 26, 2017 Try refreshing your guide. At least for me, all channels but one have full data again.
clarkss12 304 Posted October 26, 2017 Posted October 26, 2017 I have refreshed my box numerous times, and also powered down my box several times also.......... But this only occurs on my new server, my other servers do not have this problem...... strange.
DarWun 357 Posted October 26, 2017 Posted October 26, 2017 (edited) I'm reporting back to say that the guide was fully populated when I got home from work a few minutes ago. There was no Emby update between when I reported the problem yesterday and now, so I don't think the original issue was with Emby. Edited October 26, 2017 by DarWun
SikSlayer 254 Posted November 2, 2017 Posted November 2, 2017 Log.txt It's happening again. This time, refreshing takes a mere 20 seconds and I get NO data at all.
SikSlayer 254 Posted November 2, 2017 Posted November 2, 2017 (edited) False alarm, apparently SD knows. Notice: **** KNOWN SERVER ISSUES. TRY AGAIN LATER IF AFFECTED. **** SD_JSON:Server offline for maintenance. Edited November 2, 2017 by SikSlayer
dranderson402 31 Posted November 2, 2017 Posted November 2, 2017 False alarm, apparently SD knows. Notice: **** KNOWN SERVER ISSUES. TRY AGAIN LATER IF AFFECTED. **** SD_JSON:Server offline for maintenance. Where did you see this? The message I see is dated 7/26/2017. I don't see any new posts about this at SD and I have the same blank guide problem. Why can't emby leave the last known guide data in place if it receives an error? At least that way stuff could still record. Now I have to fire up my mythtv to make sure I get my recordings.
SikSlayer 254 Posted November 2, 2017 Posted November 2, 2017 dranderson402, on 02 Nov 2017 - 6:34 PM, said: Where did you see this? The message I see is dated 7/26/2017. I don't see any new posts about this at SD and I have the same blank guide problem. https://www.schedule...ect.org/account There's no date for the message; I would have noticed it last week if that was the case. dranderson402, on 02 Nov 2017 - 6:34 PM, said: Why can't emby leave the last known guide data in place if it receives an error? At least that way stuff could still record. Now I have to fire up my mythtv to make sure I get my recordings. That's the same thing I thought actually.
dranderson402 31 Posted November 2, 2017 Posted November 2, 2017 dranderson402, on 02 Nov 2017 - 6:34 PM, said: https://www.schedule...ect.org/account There's no date for the message; I would have noticed it last week if that was the case. dranderson402, on 02 Nov 2017 - 6:34 PM, said: That's the same thing I thought actually. Yeah, now I see it when I log in. I was going to the forums. Sent from my SM-G920P using Tapatalk
theniteow1 25 Posted November 3, 2017 Posted November 3, 2017 (edited) Hello, running into an issue tonight. Looks like Emby upgraded itself to the latest version 3.2.36.00. Now all the sudden the guide says <No Program Data>. I tried to correct the issue, by redownloading the guide from Schedules Directed, and it didn't fix it. So I deleted the mappings, now when I try to resetup the guides, all I get for country selection is "Undefined" over and over again, and I am unable to select my Zip Code or download anything. I verified my account is still active with Schedules Direct. Has anybody else encountered this? Edited November 3, 2017 by theniteow1
Luke 42243 Posted November 3, 2017 Posted November 3, 2017 @@theniteow1 see previous responses in this topic. thanks.
theniteow1 25 Posted November 3, 2017 Posted November 3, 2017 @@Luke thanks for redirecting me, so it looks like Schedules Direct is having some kind of issue? UPDATE: Now I am able to select my Country, put in a zip code, but it doesn't offer any listings to download.
Luke 42243 Posted November 3, 2017 Posted November 3, 2017 No issue, they are just offline for maintenance
SikSlayer 254 Posted November 3, 2017 Posted November 3, 2017 No issue, they are just offline for maintenance They're back up it seems. Downloading guide data now.
nominion 7 Posted November 3, 2017 Posted November 3, 2017 I'm getting the same symptoms as @@theniteow1 after the maintenance was completed by Schedules Direct. You can input the country and zip code, but the lineup drop down doesn't let you pick a lineup. I've deleted Schedules Direct as the Guide Provider in Emby, restarted the server, and have tried re-adding it with the same result. I'm able to login to the Schedules Direct website and select the correct lineup for my zip code. Anyone have any thoughts? 1
Luke 42243 Posted November 3, 2017 Posted November 3, 2017 {"code":3001,"message":"Retrieving headends disabled."} It appears they are still offline for maintenance.
theniteow1 25 Posted November 3, 2017 Posted November 3, 2017 I'm getting the same symptoms as @@theniteow1 after the maintenance was completed by Schedules Direct. You can input the country and zip code, but the lineup drop down doesn't let you pick a lineup. I've deleted Schedules Direct as the Guide Provider in Emby, restarted the server, and have tried re-adding it with the same result. I'm able to login to the Schedules Direct website and select the correct lineup for my zip code. Anyone have any thoughts? Still having the same problem. I'm hoping they resolve this fairly quickly.
