Guest asrequested Posted October 25, 2017 Posted October 25, 2017 Sometimes playing Live TV, it's playing the audio track for the visually impaired (the descriptive voice over)
Luke 42243 Posted October 25, 2017 Posted October 25, 2017 It's direct playing, so it looks like this is just what mpv thinks is the default track.
Guest asrequested Posted October 25, 2017 Posted October 25, 2017 So far it just looks it's one channel. It plays correctly in the HDHR player. I'll have to look a little deeper and try to figure out what mpv is doing.
pvcleave 4 Posted November 1, 2017 Posted November 1, 2017 (edited) I have this same problem. I have it only on the FXX channel in the Windows 10 Theater app. The normal Windows app plays fine. However, in some programs it will play spanish instead of the descriptive audio track. In addition, if I record a program, it will play the correct audio, regardless of app. Edited November 1, 2017 by pvcleave
Guest asrequested Posted November 1, 2017 Posted November 1, 2017 When you record, the server chooses the stream. With desktop app (assuming you direct play), mpv chooses the stream. Luke, one thing I didn't mention was that there isn't an option to select the correct stream. In these cases, they broadcast both, but they don't appear in Theater. Can that be corrected, so we at least can choose?
Luke 42243 Posted November 1, 2017 Posted November 1, 2017 When you record, the server chooses the stream. Correction - if you record without the recording conversion feature enabled, then the entire live stream is preserved as it was, including all available tracks.
Guest asrequested Posted November 1, 2017 Posted November 1, 2017 Correction - if you record without the recording conversion feature enabled, then the entire live stream is preserved as it was, including all available tracks. Oh, that's good. Can we have the same for live TV?
Luke 42243 Posted November 2, 2017 Posted November 2, 2017 It's the same thing when direct playing with mpv in emby theater.
Guest asrequested Posted November 2, 2017 Posted November 2, 2017 (edited) It's the same thing when direct playing with mpv in emby theater. Hmmmm...if that were the case, why did I not have the option to choose the other track? I remember that we used to have the option in the overlay, but it's not there, anymore. I'm going to poke around in the mpv logs. Edited November 2, 2017 by Doofus
Guest asrequested Posted November 2, 2017 Posted November 2, 2017 Ok, so yes both audio tracks are delivered. Nice! [cplayer] (+) Audio --aid=1 --alang=eng (ac3 6ch 48000Hz) [ 1.774][i][cplayer] Audio --aid=2 --alang=spa (ac3 2ch 48000Hz) And obviously mpv needs to select one to play. [ 1.796][v][af] Audio filter chain: [ 1.796][v][af] [in] 48000Hz stereo 2ch spdif-ac3 [ 1.796][v][af] [out] 48000Hz stereo 2ch spdif-ac3 [ 1.796][v][af] [ao] 48000Hz stereo 2ch spdif-ac3 [ 1.796][v][ao] Trying audio driver 'wasapi' [ 1.796][v][ao] Using preferred device 'SC-95 (Intel(R) Display Audio)' [ 1.796][v][ao/wasapi] requested format: 48000 Hz, stereo channels, spdif-ac3 [ 1.798][v][ao/wasapi] Selecting device by name: 'SC-95 (Intel(R) Display Audio)' [ 1.798][v][ao/wasapi] Selecting device '{890bc9dd-2254-4ba7-8bcb-e2e9c85694e2}' (SC-95 (Intel(R) Display Audio)) [ 1.798][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{890bc9dd-2254-4ba7-8bcb-e2e9c85694e2} [ 1.804][v][ao/wasapi] Trying stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) -> ok [ 1.804][v][ao/wasapi] Accepted as stereo spdif-ac3 @ 48000hz -> stereo spdif-ac3 (16/16 bits) @ 48000hz (exclusive) [ 1.805][v][ao/wasapi] Device period: 10 ms [ 1.824][v][ao/wasapi] Buffer frame count: 480 (10 ms) [ 1.824][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 48000. [ 1.825][v][ao/wasapi] device buffer: 480 samples. [ 1.826][v][ao/wasapi] using soft-buffer of 10752 samples. [ 1.826][i][cplayer] AO: [wasapi] 48000Hz stereo 2ch spdif-ac3 [ 1.826][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 1.826][v][cplayer] Inserting volume filter. [ 1.826][v][af] Adding filter volume [ 1.826][v][af] Setting option 'warn' = 'no' (flags = 0) [ 1.826][v][af] Adding filter lavrresample [ 1.826][v][af] Removing filter lavrresample [ 1.826][w][volume] Filter volume apparently cannot be used due to spdif passthrough - removing it. [ 1.826][v][af] Removing filter volume [ 1.826][v][af] Audio filter chain: [ 1.826][v][af] [in] 48000Hz stereo 2ch spdif-ac3 [ 1.826][v][af] [out] 48000Hz stereo 2ch spdif-ac3 [ 1.826][v][af] [ao] 48000Hz stereo 2ch spdif-ac3 What I'm asking for is to have the selection back in the overlay, so that if the wrong one is selected, we can easily switch. There apparently is provision for this
Luke 42243 Posted November 2, 2017 Posted November 2, 2017 The track selection was lost after we removed probing the live stream. We need to rebuilt it but instead use the track list from the player rather than the server. Between now and the time when that happens, i would imagine you could do something with your mpv conf to influence what track gets chosen.
Guest asrequested Posted November 2, 2017 Posted November 2, 2017 The track selection was lost after we removed probing the live stream. We need to rebuilt it but instead use the track list from the player rather than the server. Between now and the time when that happens, i would imagine you could do something with your mpv conf to influence what track gets chosen. I briefly looked into something like that. Using the # shortcut would be great, but they aren't enabled. If I get the occurring more often, I'll look further into it
