aahmyu 9 Posted October 24, 2017 Posted October 24, 2017 Hello, im trying to use "postman" to try to get an access token im sending a post request to "Users/AuthenticateByName" in the body im sending { "username": "test", "password": "" } i keep getting a response of "Invalid user or password entered." And yes ive read this page: https://github.com/MediaBrowser/Emby/wiki/Authentication Thanks
ebr 16332 Posted October 24, 2017 Posted October 24, 2017 What are you really trying to accomplish? i.e. Why do you want to get an access token?
aahmyu 9 Posted October 24, 2017 Author Posted October 24, 2017 (edited) What are you really trying to accomplish? i.e. Why do you want to get an access token? atm nothing really. just want to explore a bit in the api. I probably want to do something when i have time. can you tell me what im missing? i added the headers same as in the docs and still doesnt work. and also i cant use swagger endpoints at all without the access token. so thats why i want one. Thanks Edited October 24, 2017 by aahmyu
ebr 16332 Posted October 24, 2017 Posted October 24, 2017 also i cant use swagger endpoints at all without the access token. so thats why i want one. Okay, that's what I wanted to know because there are easier ways to make that work. In the server there is a "Security" section where you can generate an API key that can then be used for things like swagger. As for your auth call, assuming all the headers are correct, it doesn't look like you did this: The password must be sent in the body, in three different form fields: pw - password in plain text password - password in Sha1 passwordMd5 - password in MD5 IMPORTANT - The Emby login API is in a state of transition, and this is why three different forms of the password are required. Beginning April 1, 2018, only the "pw" param will be required. Until then, all three are needed in order to support both newer and older servers.
aahmyu 9 Posted October 24, 2017 Author Posted October 24, 2017 Okay, that's what I wanted to know because there are easier ways to make that work. In the server there is a "Security" section where you can generate an API key that can then be used for things like swagger. As for your auth call, assuming all the headers are correct, it doesn't look like you did this: thanks for your reply i tried doing this. but i keep getting this "Value cannot be null. Parameter name: appName"? im using the same headers as from the docs.
ebr 16332 Posted October 24, 2017 Posted October 24, 2017 Add that to the header. It is missing from the doc.
thatoneguy99 33 Posted November 11, 2017 Posted November 11, 2017 Did you ever get this going? Sent from my phone!
aahmyu 9 Posted November 11, 2017 Author Posted November 11, 2017 Did you ever get this going? Sent from my phone! Yeah. but im not sure if its the right way to do it but it works. My problems were happening because of bad headers These headers worked for me: { Content-Type: application/json X-Emby-Authorization: MediaBrowser Client="Android", Device="Samsung Galaxy SIII", DeviceId="xxx", Version="1.0.0.0" } And in the body you need this: {"Password":"","PasswordMd5":"","Username":"","Pw":""} Make sure to fill the user name and passwords if you have password for the user Hope this helps
Luke 42239 Posted November 11, 2017 Posted November 11, 2017 Well done. These instructions are also available on our wiki: https://github.com/MediaBrowser/Emby/wiki/Authentication Thanks !
Luke 42239 Posted July 6, 2018 Posted July 6, 2018 Swagger params are finally back and better then ever: https://emby.media/community/index.php?/topic/60520-34127-swagger-params/ Enjoy.
jervaise 0 Posted January 11, 2020 Posted January 11, 2020 Add that to the header. It is missing from the doc. I was trying in Swagger, added the appName but still getting Value cannot be null. (Parameter 'appName'). Is there something else to add?
Luke 42239 Posted January 11, 2020 Posted January 11, 2020 Yes, everything mentioned here: https://github.com/MediaBrowser/Emby/wiki/Authentication Please let us know if this helps. Thanks.
