lolvince 0 Posted October 23, 2017 Posted October 23, 2017 bonjour, j'ai acheté une licence à l'année, et j'aurai aimé pouvoir utiliser le mode cinéma.j'ai installer le module "trailers 1.1.2.0", voici la configuration : et voici la configuration du mode cinéma : cependant, si je lance un film, ou une série, aucune bande annonce se lance ... test fait sur chrome/firefox/tel android/shield TV quelqu'un peu me dire ce que j'ai oublié ? merci.
ebr 16333 Posted October 23, 2017 Posted October 23, 2017 Hi. There is also a user-level setting within each app. Did you turn that on?
lolvince 0 Posted October 23, 2017 Author Posted October 23, 2017 oui absolument, l'option est bien coché pour chaque profil ! Paramètres de lecture > Activer le mode cinéma (OK)
ebr 16333 Posted October 23, 2017 Posted October 23, 2017 Then it is possible that simply no content matched whatever you were playing. Please play something that you believe should have something in Cinema Mode and then post the logs. Thanks. How to Report a Problem
