vangeliis 8 Posted October 30, 2017 Posted October 30, 2017 Really good news !!! I've created manually the folder ~/.config and everything works fine !!! I can launch EmbyServer.app directly from Applications's folder. Fab! Well done! I wonder why upon lunching EmbyServer you couldn't create the .config folder. Perhaps @@Luke can fix this.....
Luke 42238 Posted October 30, 2017 Posted October 30, 2017 Please try this version: https://github.com/MediaBrowser/Emby/releases/download/3.2.35.0/embyserver-osx-x64-3.2.35.0.zip For testing purposes, please delete the .config folder. Thanks.
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 (edited) Please try this version: https://github.com/MediaBrowser/Emby/releases/download/3.2.35.0/embyserver-osx-x64-3.2.35.0.zip For testing purposes, please delete the .config folder. Thanks. I've tried with this release. It works fine but the behavior is different : I removed .config folder from my home path. The emby-server folder doesn't exist. When launching EmbyServer.app, the emby-server folder is create and no crash occurs. I able to discover my libraries and use Emby normally. All my libraries are described in the emby-server directory. So what is the normal situation : .config folder or emby-server folder ? Thanks, Edited October 31, 2017 by scouty
Luke 42238 Posted October 31, 2017 Posted October 31, 2017 can you attach an emby server log? thanks.
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 not able to upload the log.webarchive even if I rename the file. could you send me your email by pm for me to send it to you ? regards,
Luke 42238 Posted October 31, 2017 Posted October 31, 2017 Why aren't you able to upload it? What happens when you try?
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 on the forum, when I attach the file ( after selecting it ), it says : "upload fails"
Luke 42238 Posted October 31, 2017 Posted October 31, 2017 Ok easiest thing to do is create a paste: https://paste2.org/
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 here it is : https://paste2.org/X9K0k0cm
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 So what is the normal situation : .config folder or emby-server folder ? Thanks, I've a new type of error but it seems to be related to something else. When discovering my movies, at some point, the discovery process stops and when I try to connect to the web page, safari replies : Too many open files. Do want me to open a new topic ? regards,
Luke 42238 Posted October 31, 2017 Posted October 31, 2017 I've a new type of error but it seems to be related to something else. When discovering my movies, at some point, the discovery process stops and when I try to connect to the web page, safari replies : Too many open files. Do want me to open a new topic ? regards, Yes please, thanks.
T800 10 Posted October 31, 2017 Posted October 31, 2017 Not sure if this is the same thing but I have to reboot every time I update.
scouty 0 Posted October 31, 2017 Author Posted October 31, 2017 Yes, it's also the only way I found at the moment to restart emby. I will open a new topic for this issue
Luke 42238 Posted October 31, 2017 Posted October 31, 2017 Not sure if this is the same thing but I have to reboot every time I update. Why do you feel that you need to do that?
T800 10 Posted November 1, 2017 Posted November 1, 2017 I started to reply to this but then I thought it best to do the latest update and then report. Since the new mono update I shutdown Emby, download the new version (which is labeled "Electron" when it's starting), drop it into Applications but then it will not start without a reboot. This update will start but still shows it's on the old version. I have to reboot for it to show the new one. Was on Version 3.2.34.0. Shutdown Emby, downloaded update, installed, started Emby, still Version 3.2.34.0. Reboot, now Version 3.2.35.0
vangeliis 8 Posted November 1, 2017 Posted November 1, 2017 @@T800 I wonder whether your LunchServices database is corrupted. You could try to manually delete the LaunchServices preference file. Quit all open applications and navigate to ~/Library/Preferences. Locate com.apple.LaunchServices.plist, delete the file, then reboot your Mac. Vangeliis
T800 10 Posted November 1, 2017 Posted November 1, 2017 @@T800 I wonder whether your LunchServices database is corrupted. You could try to manually delete the LaunchServices preference file. Quit all open applications and navigate to ~/Library/Preferences. Locate com.apple.LaunchServices.plist, delete the file, then reboot your Mac. Vangeliis I will give that a try, thanks
Luke 42238 Posted November 1, 2017 Posted November 1, 2017 See here: https://docs.microsoft.com/en-us/dotnet/core/macos-prerequisites?tabs=netcore2x We'll have to see if it's something we can incorporate into the app or not. Thanks.
