SkyBox 0 Posted October 22, 2017 Posted October 22, 2017 I'm running the trial theater product and there is no option that I see for for external players. Was this removed? Pretty sure it was in older versions. Would like to play my blu-ray and dvd folders, preferrably Total Media theater 5 as my external player.
Solution Luke 42243 Posted October 22, 2017 Solution Posted October 22, 2017 Hi @@SkyBox, no, it is there under app settings. Make sure you are running the desktop app: https://emby.media/emby-theater.html Thanks. 1
SkyBox 0 Posted October 24, 2017 Author Posted October 24, 2017 Thanks Luke, I was using the webserver.
