Sammy 791 Posted October 22, 2017 Posted October 22, 2017 I'm having issues with stuttered / juddery playback using frame rate switching with mpv. Here's some screen grabs of my settings and the logs consistent with the time this occurred although it is occurring often. Last night I had to shut off frame rate switching in order to watch the movie without getting nauseous. ServerLog22102017.txt ffpmeglog22102017.txt
Luke 42243 Posted October 22, 2017 Posted October 22, 2017 Try setting the app back to default settings.
Sammy 791 Posted October 22, 2017 Author Posted October 22, 2017 Try setting the app back to default settings.Works great. No Judder at all. Sent from my SM-G930P using Tapatalk 1
Luke 42243 Posted October 22, 2017 Posted October 22, 2017 Do you remember which ones you changed? We are probably at the point where we have too many settings in the UI now and need to consider removing some. @
Sammy 791 Posted October 22, 2017 Author Posted October 22, 2017 Do you remember which ones you changed? We are probably at the point where we have too many settings in the UI now and need to consider removing some. @Just turning off frame rate switching but leaving the rest as posted in the OP fixed it. I have had frame rate switching work just fine but last night was unwatchable. Look at all the dropped frames in the "Stats for Nerds" in just a minute or two of playback. Sent from my SM-G930P using Tapatalk
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 (edited) A couple of things. First, what GPU are you using? Second, you have HWA set to auto and it's using dxva2-copy. That should be d3d, assuming you're using windows. Third, the whole bottom section of settings requires extra processing. I leave all those, alone. Without knowing your GPU, I'm shooting in the dark. Do you also know how to get an mpv log? That would be helpful. But I think we need to manage GPU usage, more efficiently. I was recently getting frame dropping, like that. I reconfigured a great deal, to get it to stop. Hardware and software, but I think my issue was with something I was using. Edited October 23, 2017 by Doofus
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 You should also disable display sync. That will cause a lot of dropped frames
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 A couple of things. First, what GPU are you using? Second, you have HWA set to auto and it's using dxva2-copy. That should be d3d, assuming you're using windows. Third, the whole bottom section of settings requires extra processing. I leave all those, alone. Without knowing your GPU, I'm shooting in the dark. Do you also know how to get an mpv log? That would be helpful. But I think we need to manage GPU usage, more efficiently. I was recently getting frame dropping, like that. I reconfigured a great deal, to get it to stop. Hardware and software, but I think my issue was with something I was using. You should also disable display sync. That will cause a lot of dropped framesI have come to the conclusion that Intel iGPU HD4600 does not handle 23.976 fps well and have turned it off and set HWA to none and now have zero dropped frames. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 (edited) Recommendations on a good GPU around the $100 price point would be nice. My Radeon HD7850 gave up the ghost recently so I'm using on board video right now. Sent from my SM-G930P using Tapatalk Edited October 23, 2017 by Sammy
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 Works great. No Judder at all. Sent from my SM-G930P using Tapatalk If this is to be the best answer then does frame rate switching actaully work in mpv? Seems to be a "maybe" answer because it depends on the GPU? Shouldn't this work with iGPU? I had it working long ago, back in 2011, on an i3 iGPU with madVR (no advanced settings though). Why can't I expect that on a 4th generation i5 iGPU in mpx?
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 Try setting it to d3d without copyback, turn off display sync and everything else at default.
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 Try setting it to d3d without copyback, turn off display sync and everything else at default.Is that setting good with Win7x64Pro? Sent from my SM-G930P using Tapatalk
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 (edited) Ah that was why it chose DXVA2 copyback. No, you need win 8 and up. So with copyback, it's writing to your RAM. That could possibly be why you have dropped frames. Unfortunately DXVA2 is not well supported, now. But there is a way for you to try it. Do you have an mpv.conf? Edited October 23, 2017 by Doofus
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 (edited) You can set your HWA to auto and put this in your mpv.conf hwdec=dxva2 opengl-backend=dxinterop And disable display sync Edited October 23, 2017 by Doofus
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 Ah that was why it chose DXVA2 copyback. No, you need win 8 and up. So with copyback, it's writing to your RAM. That could possibly be why you have dropped frames. Unfortunately DXVA2 is not well supported, now. But there is a way for you to try it. Do you have an mpv.conf?I do have 12Gbs DDR3 1600 RAM and about 6Gbs free most of the time. I do not have a mpv config file. I have not been following the mpv thread for some time now. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 You can set your HWA to auto and put this in your mpv.conf hwdec=dxva2 opengl-backend=dxinterop And disable display sync How / where to setup mpv.conf? Thanks. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 (edited) Recommendations on a good GPU around the $100 price point? I also have this thread going at avsforums. Sent from my SM-G930P using Tapatalk Edited October 23, 2017 by Sammy
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 I do have 12Gbs DDR3 1600 RAM and about 6Gbs free most of the time. I do not have a mpv config file. I have not been following the mpv thread for some time now. Sent from my SM-G930P using Tapatalk The possible issue with copyback is that it's slower than DXVA2. Coupled with display sync, I would expect frame dropping. Your first test should be HWA auto and display sync off.
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 The possible issue with copyback is that it's slower than DXVA2. Coupled with display sync, I would expect frame dropping. Your first test should be HWA auto and display sync off. That is where it is set right now. No frame drops but no frame rate switching either.
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 So with those settings, frame rate switching doesn't work at all? If that's the case we need to get you set up with logging so @@randomevents can take a look.
Sammy 791 Posted October 23, 2017 Author Posted October 23, 2017 I'm considering getting this GPU. Thoughts?
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 That'll work. But remember that nvenc only supports two transcodes.
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 (edited) You should read through this thread, but it's for server use. https://emby.media/community/index.php?/topic/10723-gpu-transcoding-intel-quicksync-and-nvidia-nvenc/page-65&do=findComment&comment=502352 Edited October 23, 2017 by Doofus
Guest asrequested Posted October 23, 2017 Posted October 23, 2017 (edited) Disregard this post Edited October 23, 2017 by Doofus
