fighuass 1 Posted October 21, 2017 Posted October 21, 2017 Okay, so I have a folder called Videos, and inside Videos I have a LOT of folders. I want to add Videos to a library in Emby, and have the subfolders be separated from each other, so I don't get all the videos mixed up. Is there a way to do that without making a new library for every single subfolder?
ebr 16309 Posted October 21, 2017 Posted October 21, 2017 Yes, use either Home Videos or Unset-Mixed for the library type - depending on if you need online metadata or not.
ebr 16309 Posted October 21, 2017 Posted October 21, 2017 You could also have a regular Movie library and use the "Folders" view...
