vangeliis 8 Posted October 21, 2017 Posted October 21, 2017 Hi, I'm using emby server Mac 3.2.33 with high sierra and I'm having problems with external greek srt subtitles (please see attached srt file) when using direct play. The subtitles are displayed as gibberish on the telly while the web player displays them correctly. The srt file is UTF-8. Any clues? Thanks, Vangeliis HHhH.gre.srt
Luke 42238 Posted October 21, 2017 Posted October 21, 2017 Can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Luke 42238 Posted October 21, 2017 Posted October 21, 2017 Can you download the latest version from the website and see if the issue persists? Thanks !
vangeliis 8 Posted October 21, 2017 Author Posted October 21, 2017 Can you download the latest version from the website and see if the issue persists? Thanks ! I tried version 3.2.33.9 a few days ago with no luck with the subtitles and have issues with quitting the app as reported in another post. Can you make version 3.2.33.15 available for the Mac to test?
vangeliis 8 Posted October 22, 2017 Author Posted October 22, 2017 Ok, 3.2.33.17 is up, thanks. I'll give it a go and report back. Thanks for all the amazing work you guys are doing.
vangeliis 8 Posted October 22, 2017 Author Posted October 22, 2017 Ok, 3.2.33.17 is up, thanks. Hi Luke, 3.2.33.17 is a mixed bag for me. Although the server quits properly now and as others requested there is only a menubar icon, I still can not remote control my LG TV from the browser interface (direct cast) and greek subtitles still play up.
vangeliis 8 Posted October 22, 2017 Author Posted October 22, 2017 Please see post #2 thanks. Log file attached. Hope it helps. Appreciate the effort you are putting into this. Vangeliis server-63644297746.txt
Luke 42238 Posted October 23, 2017 Posted October 23, 2017 How do the subtitles appear in the web app?
vangeliis 8 Posted October 23, 2017 Author Posted October 23, 2017 How do the subtitles appear in the web app? As they should, correct Greek and not gibberish. Also subs with unicode characters also appear correctly in the web app but not over DLNA.
vangeliis 8 Posted October 25, 2017 Author Posted October 25, 2017 @@Luke Hi, New version 3.2.34.0 for the macOS does not fix the greek subtitles and/or the problem with unicode characters. To me it looks like that both issues are related- the macOS server does not correctly detect that the character set in the .srt file is unicode and is sending it to the TV as ISO Latin 1. Is this possible? log file is attached. server-63644550235.txt
Luke 42238 Posted October 25, 2017 Posted October 25, 2017 What year is your LG model? In my testing it works fine but I have a pretty new LG, a 2016 model.
vangeliis 8 Posted October 25, 2017 Author Posted October 25, 2017 2013. I use another app called firestream (https://itunes.apple.com/gb/app/firestream-upnp-dlna-media-server/id1005325119?mt=12) and .srt subtitles with either unicode characters like ♪ or with greek language are displayed correctly. Baffling....
vangeliis 8 Posted October 25, 2017 Author Posted October 25, 2017 {movie name}.gre.srt or {movie name}.eng.srt
vangeliis 8 Posted October 26, 2017 Author Posted October 26, 2017 @@Luke Just a bit more information: I copied the Greek subtitles .srt and the .srt with the unicode characters to an USB pendrive and both play correctly using the LG build in media player.
vangeliis 8 Posted October 28, 2017 Author Posted October 28, 2017 (edited) Hi @@Luke I've done a bit more testing and when the greek srt unicode file is embedded into the mkv container then the subtitles "play" correctly over DNLA (direct play). It seems the problem in post #13 only occurs with external srt files? Log file attached. server-63644805863.txt Edited October 28, 2017 by vangeliis
vangeliis 8 Posted November 4, 2017 Author Posted November 4, 2017 Hi @@Luke Just tested the latest Mac version 3.2.36.0 and the problem (see post #1) with external unicode srt subtitles still persists. The same srt file plays well when muxed into the mkv container. Any ideas? Thanks, Vangeliis
Luke 42238 Posted November 4, 2017 Posted November 4, 2017 I'm not able to reproduce on a newer LG. I will continue to test though. Thanks.
vangeliis 8 Posted November 4, 2017 Author Posted November 4, 2017 I'm not able to reproduce on a newer LG. I will continue to test though. Thanks. Hi @@Luke, Thanks for trying. I've also noticed that when the unicode srt (greek or English language) is muxed into the mkv container then my TV does not allow me to change the language code as it's greyed out (see attached photo IMG_0367) but when the same unicode srt file is external then my TV allows me to change the language code (see attached photo IMG_0368). Do you see the same?
Luke 42238 Posted November 5, 2017 Posted November 5, 2017 If we remuxed on the fly then that would make sense because we will be stripping out all other subtitle tracks during that process. If it is direct playing to the TV, then I'm not sure, it just depends on what the TV supports.
vangeliis 8 Posted November 5, 2017 Author Posted November 5, 2017 (edited) If we remuxed on the fly then that would make sense because we will be stripping out all other subtitle tracks during that process. If it is direct playing to the TV, then I'm not sure, it just depends on what the TV supports. Hi @@Luke, Thanks for your comment. I suppose what I was trying to say in my previous post is that when the subtitles file is correctly sent to the TV via direct-play as unicode then the TV software detects it's a unicode subtitles file and auto-disables the option to change the character encoding (which makes perfect sense). For some reason when the subtitle file is external then the TV software does not recognise it as unicode and allows me to change the character encoding -but none of the options is unicode encoding. Is there a way to force Emby to direct-play all external srt files as unicode? Thanks. /edit Please see attached server log. I noticed when direct playing Barbie Dolphin Magic.mp4 the associated extrenal srt file does not get assigned a character encoding. Is this relevant? thanks again. server-63645475454.txt Edited November 5, 2017 by vangeliis
Luke 42238 Posted November 5, 2017 Posted November 5, 2017 Again, I'm not exactly sure what the issue is for older LG models. What I can say is that for newer models there is no issue. When I have an opportunity to personally test this out then I'll be able to figure it out. Thanks.
