mbnwa 49 Posted March 25, 2018 Posted March 25, 2018 (edited) Confirmed. Beta app allows playback over T-Mobile LTE. I uninstalled the beta and installed the App Store version and that broke functionality. Another interesting observation is that for some reason, I am able to select 720p playback. I was under the impression that T-Mobile restricted video streaming over LTE to 480p? If you are using HTTPS to stream, T-Mobile would not be able to analyze your stream and because you're not Netflix or YouTube with a common set of IP's or hostnames they can validate against odds are you are flying under the T-Mobile 480p restriction. It would be the same as if you used ExpressVPN or a VPN service of sorts and forced all your cellular data over that link, they would not be able to analyze it because it's encrypted. Edited March 25, 2018 by mbnwa
Luke 42147 Posted March 29, 2018 Posted March 29, 2018 @@hstamas, I've hidden your post. Please keep beta feedback in the testing section of the community. Thanks.
hstamas 179 Posted April 6, 2018 Posted April 6, 2018 (edited) It really shouldn't fix it because regardless of what player we use, the same rules still apply. It is possible that the player's http modules have the requirements self-contained. I will do some testing on that soon. Thanks for the feedback. @@Luke, just wondering if you have it on your roadmap to fix the underlying issue? From what I have researched the Emby IOS app needs to be updated to support IVP6 correct? Edited April 6, 2018 by hstamas
szerby 0 Posted April 24, 2018 Author Posted April 24, 2018 How is the IPv6 update coming? I requested to be in the beta, but got no response.
Luke 42147 Posted May 12, 2018 Posted May 12, 2018 Emby for iOS 1.5 has been released with the new video player, wake on lan, and more. Enjoy.
