mmtrago 1 Posted January 26, 2018 Posted January 26, 2018 We are looking into it, thanks. So we're going to have to limit to 480p 1mbps, and also connect over ipv6 (if supported by your emby server). i'm using synology. do you know if ipv76 is supported? im not sure.
Luke 42145 Posted January 26, 2018 Posted January 26, 2018 i'm using synology. do you know if ipv76 is supported? im not sure. Emby Server supports it. The question is really about your internet router and your internet connection.
mmtrago 1 Posted January 26, 2018 Posted January 26, 2018 (edited) Emby Server supports it. The question is really about your internet router and your internet connection. i have a netgear nighthawk ac3200. are you talking LTE connection or home connection? Edited January 26, 2018 by mmtrago
Luke 42145 Posted January 26, 2018 Posted January 26, 2018 both, but i'm sure your LTE connection supports ipv6 so I wouldn't worry about that. but if your home network only supports ipv4 then the mobile device will only be able to connect over ipv4.
mmtrago 1 Posted January 26, 2018 Posted January 26, 2018 both, but i'm sure your LTE connection supports ipv6 so I wouldn't worry about that. but if your home network only supports ipv4 then the mobile device will only be able to connect over ipv4. i have comcast gigabit, so i'm thinking that should be good, but my concern is getting this to work over LTE. Connecting to home wifi, at least for me, is not an issue.
Luke 42145 Posted January 26, 2018 Posted January 26, 2018 You should still check your router settings and make sure ipv6 is enabled. I know for some routers it is off by default.
Luke 42145 Posted January 26, 2018 Posted January 26, 2018 Ok so your connection supports it. We'll get these changes into the app in an upcoming release. thanks. 1
Luke 42145 Posted March 2, 2018 Posted March 2, 2018 Can you try the latest server release with the iOS app quality setting on auto? Thanks.
Deihmos 169 Posted March 11, 2018 Posted March 11, 2018 (edited) I have yet to get a single video to show on LTE. I don't know anything about IPV6 but tried all the options for it in the router. All I could get is a spinning circle and a black screen that shows nothing. It works on wifi and I doubt it has anything to do with IPV6. I have IPv6 off and plex works find on wifi and LTE. Edited March 11, 2018 by Deihmos
Deihmos 169 Posted March 12, 2018 Posted March 12, 2018 (edited) Installing the linked carrier settings fixed the issue. The app needs updatingto work with t-mobile. https://developer.apple.com/support/ipv6/ https://www.reddit.com/r/tmobile/comments/7o498k/ipv4_config_for_iphone_ended/?st=jenso0j1&sh=86bba294 i Edited March 12, 2018 by Deihmos
mmtrago 1 Posted March 12, 2018 Posted March 12, 2018 Installing the linked carrier settings fixed the issue. The app needs updatingto work with t-mobile. https://developer.apple.com/support/ipv6/ https://www.reddit.com/r/tmobile/comments/7o498k/ipv4_config_for_iphone_ended/?st=jenso0j1&sh=86bba294 didnt work for me i
Deihmos 169 Posted March 12, 2018 Posted March 12, 2018 Installing the linked carrier settings fixed the issue. The app needs updatingto work with t-mobile. https://developer.apple.com/support/ipv6/ https://www.reddit.com/r/tmobile/comments/7o498k/ipv4_config_for_iphone_ended/?st=jenso0j1&sh=86bba294 didnt work for me i Did you install it? Emby worked fine after and even my security camera worked again. Stopped working ever since iOS 11.
Luke 42145 Posted March 12, 2018 Posted March 12, 2018 @@Deihmos, do you connect remotely to your emby server using ip address, or using a host name?
Deihmos 169 Posted March 12, 2018 Posted March 12, 2018 (edited) @@Deihmos, do you connect remotely to your emby server using ip address, or using a host name?I use a host name. This issue only affected T-Mobile customers because of how their network is setup. Edited March 12, 2018 by Deihmos
Luke 42145 Posted March 12, 2018 Posted March 12, 2018 I believe if you were to connect via IP, even with this change you made, that you'd still see the problem, right?
Deihmos 169 Posted March 13, 2018 Posted March 13, 2018 (edited) I believe if you were to connect via IP, even with this change you made, that you'd still see the problem, right? It worked fine with the IP. To install it I emailed it to myself. iOS IPv4/IPv6 Fix: Try this profile if you’re running into IP issues on your iOS device. It enables address translation. https://www.reddit.com/r/tmobile/wiki/index Edited March 13, 2018 by Deihmos
mmtrago 1 Posted March 14, 2018 Posted March 14, 2018 it's sad that an app that costs $4.99 requires you to have to be a computer engineer to get it working. I'm done with this.
szerby 0 Posted March 14, 2018 Author Posted March 14, 2018 I agree. This app needs to be revised to use a modern network solution - that is all. Many, many media apps have already done this. The developer has been told specifically the issue, and the response is still to ask more questions. Are you using a host name, and ip, what os do you have> Fix the IPV6 issue. Period.
mmtrago 1 Posted March 14, 2018 Posted March 14, 2018 I agree. This app needs to be revised to use a modern network solution - that is all. Many, many media apps have already done this. The developer has been told specifically the issue, and the response is still to ask more questions. Are you using a host name, and ip, what os do you have> Fix the IPV6 issue. Period. I believe Plex resolved the issue, so i'm setting up with them.
Deihmos 169 Posted March 16, 2018 Posted March 16, 2018 I believe Plex resolved the issue, so i'm setting up with them. A lot of the blame is on T-Mobile and Apple. T-Mobile is the only provider with the limitation and even my security camera app stopped working until I found a solution. Not a chance I could get the developer to update the app
hstamas 179 Posted March 22, 2018 Posted March 22, 2018 (edited) @@Luke. Has the new beta IOS app fixed this issue some how? Im on T-Mobile and after installing the beta I am able to stream from my server over LTE again. Edited March 22, 2018 by hstamas
Luke 42145 Posted March 22, 2018 Posted March 22, 2018 It really shouldn't fix it because regardless of what player we use, the same rules still apply. It is possible that the player's http modules have the requirements self-contained. I will do some testing on that soon. Thanks for the feedback.
hstamas 179 Posted March 22, 2018 Posted March 22, 2018 (edited) Confirmed. Beta app allows playback over T-Mobile LTE.I uninstalled the beta and installed the App Store version and that broke functionality.Another interesting observation is that for some reason, I am able to select 720p playback. I was under the impression that T-Mobile restricted video streaming over LTE to 480p? Edited March 23, 2018 by hstamas
