BurntTech 6 Posted October 20, 2017 Posted October 20, 2017 I'm guessing this started after I enabled cover art plugin? I'm assuming this might be related to FreeBSD and less about the plugin? 2017-10-20 11:21:37.311 Error DtoService: Error in image enhancer: CoverArtVideoEnhancer *** Error Report *** Version: 3.2.32.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 11.0.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:53:22 UTC 2017) Processor count: 2 Program data path: /var/db/emby-server Application directory: /usr/pbi/emby-amd64/lib/emby-server ImageMagickSharp.WandException: unable to load module `/usr/pbi/emby-amd64/lib/ImageMagick-6.9.0//modules-Q8/coders/png.la': file not found @ error/module.c/OpenModule/1282 at ImageMagickSharp.WandCore`1[T].CheckErrorBool (System.Int32 status) [0x00009] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand.OpenImage (System.String path) [0x0000d] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand..ctor (System.String path) [0x0003e] in <953a0750dcf04671b3542271d1ee6221>:0 at CoverArt.ImageMagick.ImageSet.GetCachedResource (System.String name) [0x0000b] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetFrame (System.String name, CoverArt.ColorShift colorShift) [0x00035] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.CreateCase (System.String root, CoverArt.ColorShift colorShift, System.String logo) [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet+<>c__DisplayClass6_0.<GetCase>b__0 () [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetSavedWand (System.String path, System.Func`1[TResult] factory) [0x00060] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetCase (System.String baseCase) [0x00022] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet+<>c.<get_InternalMetroCase>b__15_0 () [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetFrameFile (System.String frameType) [0x00046] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.GetFrameSize (CoverArt.Entities.BaseImageSet imageSet, System.String frame) [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.GetEnhancedImageSize (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType, System.Int32 imageIndex, MediaBrowser.Model.Drawing.ImageSize originalImageSize) [0x0007d] in <d04ce2decef746d7a5462e05f791beb4>:0 at Emby.Server.Implementations.Dto.DtoService.GetPrimaryImageAspectRatio (MediaBrowser.Controller.Entities.IHasMetadata item) [0x000c8] in <084b0c6ff50247d4bcf368af1d7e0375>:0 ImageMagickSharp.WandException at ImageMagickSharp.WandCore`1[T].CheckErrorBool (System.Int32 status) [0x00009] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand.OpenImage (System.String path) [0x0000d] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand..ctor (System.String path) [0x0003e] in <953a0750dcf04671b3542271d1ee6221>:0 at CoverArt.ImageMagick.ImageSet.GetCachedResource (System.String name) [0x0000b] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetFrame (System.String name, CoverArt.ColorShift colorShift) [0x00035] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.CreateCase (System.String root, CoverArt.ColorShift colorShift, System.String logo) [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet+<>c__DisplayClass6_0.<GetCase>b__0 () [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetSavedWand (System.String path, System.Func`1[TResult] factory) [0x00060] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetCase (System.String baseCase) [0x00022] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet+<>c.<get_InternalMetroCase>b__15_0 () [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.ImageMagick.ImageSet.GetFrameFile (System.String frameType) [0x00046] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.GetFrameSize (CoverArt.Entities.BaseImageSet imageSet, System.String frame) [0x00000] in <d04ce2decef746d7a5462e05f791beb4>:0 at CoverArt.Enhancers.CoverArtBaseEnhancer.GetEnhancedImageSize (MediaBrowser.Controller.Entities.IHasMetadata item, MediaBrowser.Model.Entities.ImageType imageType, System.Int32 imageIndex, MediaBrowser.Model.Drawing.ImageSize originalImageSize) [0x0007d] in <d04ce2decef746d7a5462e05f791beb4>:0 at Emby.Server.Implementations.Dto.DtoService.GetPrimaryImageAspectRatio (MediaBrowser.Controller.Entities.IHasMetadata item) [0x000c8] in <084b0c6ff50247d4bcf368af1d7e0375>:0 1
Luke 42238 Posted October 20, 2017 Posted October 20, 2017 hi @@BurntTech yes it does look like the image magick installation is missing some libraries that are needed for the cover art plugin. I'll have to get input from @@woodsb02. Thanks. 1
woodsb02 17 Posted October 22, 2017 Posted October 22, 2017 (edited) The options enabled and disabled in the default ImageMagick library on FreeBSD can be seen here: https://www.freshports.org/graphics/ImageMagick We have instructions on the emby page for FreeBSD to recompile ImageMagick with the 16BIT_PIXEL option disabled. Are there any other things we need that we should also recommend? Edited October 22, 2017 by woodsb02 1
woodsb02 17 Posted October 22, 2017 Posted October 22, 2017 Note that the FreeBSD emby port is depending on the ImageMagick 6.9 branch (still the “default” in our ports tree). If emby support it, I could easily depend on the new 7 branch instead: https://www.freshports.org/graphics/ImageMagick7 Not sure if this will assist with this issue or not.
Luke 42238 Posted October 22, 2017 Posted October 22, 2017 Ok, yea, we're still only supporting image magick 6.x at this point.
woodsb02 17 Posted October 22, 2017 Posted October 22, 2017 Ok, and do the list of ImageMagick 6 options we have available by default on FreeBSD? ===> The following configuration options are available for ImageMagick-6.9.9.15,1: 16BIT_PIXEL=on: 16bit pixel support BZIP2=on: bzip2 compression support DJVU=off: DJVU format support (needs THREADS) DOCS=on: Build and/or install documentation FFTW=on: Discrete Fourier Transform support FONTCONFIG=on: X11 font configuration support FPX=off: FlashPix image format support FREETYPE=on: TrueType font rendering support GRAPHVIZ=off: Graphviz graph drawing support GSLIB=off: libgs (Postscript SHLIB) support HDRI=off: High dynamic range images support JBIG=on: JBIG image format support JPEG=on: JPEG image format support JPEG2000=on: OpenJPEG 2000 support via openjpeg LCMS2=on: Little CMS 2.x support LQR=on: Liquid Rescale support LZMA=on: LZMA compression support MODULES=on: Modules support OPENEXR=off: HDR image format support via OpenEXR OPENMP=off: Parallel processing support via OpenMP PANGO=off: Pango rendering library support PDF=on: PDF document support PERL=on: Perl scripting language support PNG=on: PNG image format support RAW=on: RAW format support SVG=on: SVG vector image format support (via librsvg) TESTS=off: Run bundled self-tests after build THREADS=on: Threading support TIFF=on: TIFF image format support WEBP=on: WebP image format support WMF=on: Windows Metafile image format support X11=on: X11 (graphics) support
BurntTech 6 Posted October 23, 2017 Author Posted October 23, 2017 Doing 'pkg install ImageMagick-6.9.9.15,1' worked great. I think the errors are gone but getting the error below about too many files open. Not sure if there is an issue with throttling? CPU is running warm for 60% for last 3 days but shouldn't be causing too many files open. I may look at restarting 2017-10-23 09:20:24.606 Error ImageProcessor: Error encoding image *** Error Report *** Version: 3.2.32.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 11.0.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:53:22 UTC 2017) Processor count: 2 Program data path: /var/db/emby-server Application directory: /usr/pbi/emby-amd64/lib/emby-server ImageMagickSharp.WandException: unable to open image `/var/db/emby-server/metadata/library/8f/8f3e04c1bc361191c16f63a5c8f9c190/poster.png': Too many open files @ error/blob.c/OpenBlob/2675 at ImageMagickSharp.WandCore`1[T].CheckErrorBool (System.Int32 status) [0x00009] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand.OpenImage (System.String path) [0x0000d] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand..ctor (System.String path) [0x0003e] in <953a0750dcf04671b3542271d1ee6221>:0 at Emby.Drawing.ImageMagick.ImageMagickEncoder.EncodeImage (System.String inputPath, System.DateTime dateModified, System.String outputPath, System.Boolean autoOrient, System.Nullable`1[T] orientation, System.Int32 quality, MediaBrowser.Controller.Drawing.ImageProcessingOptions options, MediaBrowser.Model.Drawing.ImageFormat selectedOutputFormat) [0x00028] in <2efafaccd8b5421e94415577a4c08b66>:0 at Emby.Drawing.ImageProcessor+<ProcessImage>c__async1.MoveNext () [0x00648] in <96a39096258c4c9fbd5786007d1a758e>:0 ImageMagickSharp.WandException at ImageMagickSharp.WandCore`1[T].CheckErrorBool (System.Int32 status) [0x00009] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand.OpenImage (System.String path) [0x0000d] in <953a0750dcf04671b3542271d1ee6221>:0 at ImageMagickSharp.MagickWand..ctor (System.String path) [0x0003e] in <953a0750dcf04671b3542271d1ee6221>:0 at Emby.Drawing.ImageMagick.ImageMagickEncoder.EncodeImage (System.String inputPath, System.DateTime dateModified, System.String outputPath, System.Boolean autoOrient, System.Nullable`1[T] orientation, System.Int32 quality, MediaBrowser.Controller.Drawing.ImageProcessingOptions options, MediaBrowser.Model.Drawing.ImageFormat selectedOutputFormat) [0x00028] in <2efafaccd8b5421e94415577a4c08b66>:0 at Emby.Drawing.ImageProcessor+<ProcessImage>c__async1.MoveNext () [0x00648] in <96a39096258c4c9fbd5786007d1a758e>:0
Luke 42238 Posted October 23, 2017 Posted October 23, 2017 Try to restart and see if it persists. Please be advised the cover art plugin is not for everyone. It will cause the server to consume additional resources and for some systems it could be too much to handle.
BurntTech 6 Posted October 23, 2017 Author Posted October 23, 2017 Should I be concerned if I removed the plugin and restarted and its still trying to encode movie images?
Luke 42238 Posted October 23, 2017 Posted October 23, 2017 No because the core server requires image processing functions, just not to the degree of the cover art plugin. Are you having an issue?
