AdrianW 1058 Posted October 19, 2017 Posted October 19, 2017 (edited) Not sure whether this post belongs in the Apple TV or the Server forum. I was playing an mp4 file (AVC + AAC) on the Apple TV but according to the server it was transcoding because the bitrate was too high. I had the ATV bitrate set to Auto and then later I tried specifically setting it to 40MBs - with no difference. Here's the appropriate lines from the log: Info HttpServer: HTTP GET http://192.168.86.25:8096/emby/Users/350b3ec5da2e85267bcbdd50295e5aaf/Items/eee7c7de06f0cab720313f3c2b131727. UserAgent: Emby/2 CFNetwork/882 Darwin/17.0.0 2017-10-19 16:51:37.604 Info HttpServer: HTTP Response 200 to 192.168.86.110. Time: 12ms. http://192.168.86.25:8096/emby/Users/350b3ec5da2e85267bcbdd50295e5aaf/Items/eee7c7de06f0cab720313f3c2b131727 2017-10-19 16:51:37.615 Info HttpServer: HTTP GET http://192.168.86.25:8096/emby/Items/eee7c7de06f0cab720313f3c2b131727/ThemeMedia?userId=350b3ec5da2e85267bcbdd50295e5aaf&InheritFromParent=true. UserAgent: Emby/2 CFNetwork/882 Darwin/17.0.0 2017-10-19 16:51:37.619 Info HttpServer: HTTP Response 200 to 192.168.86.110. Time: 4ms. http://192.168.86.25:8096/emby/Items/eee7c7de06f0cab720313f3c2b131727/ThemeMedia?userId=350b3ec5da2e85267bcbdd50295e5aaf&InheritFromParent=true 2017-10-19 16:51:37.630 Info HttpServer: HTTP POST http://192.168.86.25:8096/emby/Items/eee7c7de06f0cab720313f3c2b131727/PlaybackInfo?UserId=350b3ec5da2e85267bcbdd50295e5aaf&StartTimeTicks=0&AutoOpenLiveStream=true. UserAgent: Emby/2 CFNetwork/882 Darwin/17.0.0 2017-10-19 16:51:37.635 Info App: User policy for Adrian. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2017-10-19 16:51:37.640 Info App: Bitrate exceeds DirectStream limit: media bitrate: 3171024, max bitrate: 1500000 2017-10-19 16:51:37.640 Info App: Profile: Unknown Profile, Path: \\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-10-19 16:51:37.645 Info App: Bitrate exceeds DirectStream limit: media bitrate: 3171024, max bitrate: 1500000 2017-10-19 16:51:37.645 Info App: Profile: Unknown Profile, Path: \\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-10-19 16:51:37.645 Info App: Bitrate exceeds DirectStream limit: media bitrate: 3171024, max bitrate: 1500000 2017-10-19 16:51:37.645 Info App: Profile: Unknown Profile, Path: \\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-10-19 16:51:37.646 Info HttpServer: HTTP Response 200 to 192.168.86.110. Time: 16ms. http://192.168.86.25:8096/emby/Items/eee7c7de06f0cab720313f3c2b131727/PlaybackInfo?UserId=350b3ec5da2e85267bcbdd50295e5aaf&StartTimeTicks=0&AutoOpenLiveStream=true 2017-10-19 16:51:37.652 Info HttpServer: HTTP GET http://192.168.86.25:8096/emby/Shows/eee7c7de06f0cab720313f3c2b131727/Episodes?userId=350b3ec5da2e85267bcbdd50295e5aaf&seasonId=5d1773224b43115e8e33ad983ab72de5&startIndex=1&fields=PrimaryImageAspectRatio%2CParentId. UserAgent: Emby/2 CFNetwork/882 Darwin/17.0.0 2017-10-19 16:51:37.661 Info HttpServer: HTTP Response 200 to 192.168.86.110. Time: 9ms. http://192.168.86.25:8096/emby/Shows/eee7c7de06f0cab720313f3c2b131727/Episodes?userId=350b3ec5da2e85267bcbdd50295e5aaf&seasonId=5d1773224b43115e8e33ad983ab72de5&startIndex=1&fields=PrimaryImageAspectRatio%2CParentId 2017-10-19 16:51:37.930 Info HttpServer: HTTP GET http://192.168.86.25:8096/emby/Items/d61b16ca5542cde659dfc94362a7fd27/Images/backdrop/0?maxHeight=720&foregroundLayer=0.50&quality=80. UserAgent: emby.media.emby-tvos/1.0.7 iOS/11.0 AppleTV/11.0 model/AppleTV6,2 hwp/t8011 build/15J381 (3; dt:163) 2017-10-19 16:51:37.932 Info HttpResultFactory: Transmit file C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\cache\images\resized-images\e\e902c6ab-e547-059b-bfd5-5d6842c1c38a.jpg 2017-10-19 16:51:37.935 Info HttpServer: HTTP Response 200 to 192.168.86.110. Time: 5ms. http://192.168.86.25:8096/emby/Items/d61b16ca5542cde659dfc94362a7fd27/Images/backdrop/0?maxHeight=720&foregroundLayer=0.50&quality=80 And here's the media info for the file: General Complete name : \\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 731 MiB Duration : 32 min 13 s Overall bit rate mode : Variable Overall bit rate : 3 171 kb/s Writing application : MH ENCODER Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.2 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Format settings, GOP : M=4, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 32 min 13 s Bit rate : 2 974 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.108 Stream size : 685 MiB (94%) Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 32 min 13 s Bit rate mode : Variable Bit rate : 192 kb/s Maximum bit rate : 206 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 spf) Compression mode : Lossy Stream size : 43.7 MiB (6%) Default : Yes Alternate group : 1 Edited October 19, 2017 by AdrianW
AdrianW 1058 Posted October 19, 2017 Author Posted October 19, 2017 Application version: 3.2.33.13 http://192.168.86.25:8096/emby/videos/eee7c7de06f0cab720313f3c2b131727/hls1/main/247.ts?DeviceId=40EF6837-A76B-41DB-BE47-7054C41A6477&MediaSourceId=eee7c7de06f0cab720313f3c2b131727&VideoCodec=h264&AudioCodec=aac,ac3,mp3&AudioStreamIndex=1&SubtitleStreamIndex=2&VideoBitrate=1310625&AudioBitrate=189375&MaxAudioChannels=6&MaxWidth=3840&PlaySessionId=e52a2312aa5e4d6388f154f3f7971827&api_key=abf22df806bf4f749b3aa433dbea55b3&CopyTimestamps=false&SubtitleMethod=Hls&EnableSubtitlesInManifest=true&Tag=3ef4a29dd8928ee126813921e90cfd30&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerBitrateExceedsLimit&h264-profile=high,main,baseline,constrainedbaseline&h264-level=41 {"Protocol":"File","Id":"eee7c7de06f0cab720313f3c2b131727","Path":"\\\\KANAME\\Video\\Asian\\Drama\\Hospital Ship\\Season 1\\Hospital Ship S01E01 The Hospital Ship.mp4","Type":"Default","Container":"mov,mp4,m4a,3gp,3g2,mj2","Name":"720P/H264/AAC","IsRemote":false,"ETag":"3ef4a29dd8928ee126813921e90cfd30","RunTimeTicks":19336990720,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","CodecTag":"avc1","Language":"und","TimeBase":"1/90000","CodecTimeBase":"1001/60000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":2973576,"BitDepth":8,"RefFrames":3,"IsDefault":true,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":29.97003,"RealFrameRate":29.97003,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":32,"IsAnamorphic":false},{"Codec":"aac","CodecTag":"mp4a","Language":"und","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"Und AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":189375,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"srt","DisplayTitle":"Und","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"\\\\KANAME\\Video\\Asian\\Drama\\Hospital Ship\\Season 1\\Hospital Ship S01E01 The Hospital Ship.srt","IsAnamorphic":true}],"Formats":[],"Bitrate":3171024,"RequiredHttpHeaders":{}} User policy for Adrian: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\System\ffmpeg.exe -ss 00:12:21.000 -c:v h264_qsv -i file:"\\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 1310625 -maxrate 1310625 -bufsize 2621250 -profile:v high -level 4.1 -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -vf "scale=trunc(min(max(iw\,ih*dar)\,720)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -segment_time_delta -741 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 247 -segment_list "C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8" -y "C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085%d.ts" ffmpeg version 3.4 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.2.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:\\KANAME\Video\Asian\Drama\Hospital Ship\Season 1\Hospital Ship S01E01 The Hospital Ship.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : MH ENCODER Duration: 00:32:13.70, start: 0.000000, bitrate: 3171 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 2973 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default) Metadata: handler_name : VideoHandler Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default) Metadata: handler_name : SoundHandler Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085247.ts' for writing Output #0, segment, to 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085%d.ts': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (h264_qsv), nv12, 720x404 [SAR 404:405 DAR 16:9], q=2-31, 1310 kb/s, 29.97 fps, 90k tbn, 29.97 tbc (default) Metadata: encoder : Lavc57.107.100 h264_qsv Side data: cpb: bitrate max/min/avg: 1310625/0/1310625 buffer size: 2621250 vbv_delay: -1 Stream #0:1: Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default) frame= 65 fps=0.0 q=-0.0 size=N/A time=00:12:23.42 bitrate=N/A speed=1.45e+003x frame= 200 fps=198 q=-0.0 size=N/A time=00:12:27.92 bitrate=N/A speed= 739x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085248.ts' for writing frame= 334 fps=221 q=-0.0 size=N/A time=00:12:32.40 bitrate=N/A speed= 497x frame= 447 fps=222 q=-0.0 size=N/A time=00:12:36.16 bitrate=N/A speed= 375x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085249.ts' for writing frame= 572 fps=227 q=-0.0 size=N/A time=00:12:40.34 bitrate=N/A speed= 302x frame= 705 fps=234 q=-0.0 size=N/A time=00:12:44.77 bitrate=N/A speed= 254x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085250.ts' for writing frame= 835 fps=237 q=-0.0 size=N/A time=00:12:49.10 bitrate=N/A speed= 219x frame= 968 fps=241 q=-0.0 size=N/A time=00:12:53.54 bitrate=N/A speed= 192x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085251.ts' for writing frame= 1099 fps=243 q=-0.0 size=N/A time=00:12:57.92 bitrate=N/A speed= 172x frame= 1231 fps=245 q=-0.0 size=N/A time=00:13:02.33 bitrate=N/A speed= 156x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085252.ts' for writing frame= 1361 fps=247 q=-0.0 size=N/A time=00:13:06.66 bitrate=N/A speed= 143x frame= 1495 fps=248 q=-0.0 size=N/A time=00:13:11.12 bitrate=N/A speed= 131x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085253.ts' for writing frame= 1627 fps=249 q=-0.0 size=N/A time=00:13:15.54 bitrate=N/A speed= 122x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085254.ts' for writing frame= 1762 fps=251 q=-0.0 size=N/A time=00:13:20.04 bitrate=N/A speed= 114x frame= 1894 fps=252 q=-0.0 size=N/A time=00:13:24.43 bitrate=N/A speed= 107x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085255.ts' for writing frame= 2028 fps=253 q=-0.0 size=N/A time=00:13:28.91 bitrate=N/A speed= 101x frame= 2162 fps=254 q=-0.0 size=N/A time=00:13:33.39 bitrate=N/A speed=95.4x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085256.ts' for writing frame= 2292 fps=254 q=-0.0 size=N/A time=00:13:37.72 bitrate=N/A speed=90.6x frame= 2426 fps=255 q=-0.0 size=N/A time=00:13:42.20 bitrate=N/A speed=86.3x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085257.ts' for writing frame= 2544 fps=254 q=-0.0 size=N/A time=00:13:46.13 bitrate=N/A speed=82.4x frame= 2683 fps=254 q=-0.0 size=N/A time=00:13:50.78 bitrate=N/A speed=78.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085258.ts' for writing frame= 2805 fps=254 q=-0.0 size=N/A time=00:13:54.83 bitrate=N/A speed=75.6x frame= 2936 fps=254 q=-0.0 size=N/A time=00:13:59.21 bitrate=N/A speed=72.7x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085259.ts' for writing frame= 3069 fps=255 q=-0.0 size=N/A time=00:14:03.64 bitrate=N/A speed= 70x frame= 3203 fps=255 q=-0.0 size=N/A time=00:14:08.12 bitrate=N/A speed=67.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085260.ts' for writing frame= 3338 fps=256 q=-0.0 size=N/A time=00:14:12.62 bitrate=N/A speed=65.3x frame= 3469 fps=256 q=-0.0 size=N/A time=00:14:17.00 bitrate=N/A speed=63.2x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085261.ts' for writing frame= 3602 fps=256 q=-0.0 size=N/A time=00:14:21.44 bitrate=N/A speed=61.3x frame= 3735 fps=257 q=-0.0 size=N/A time=00:14:25.87 bitrate=N/A speed=59.5x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085262.ts' for writing frame= 3867 fps=257 q=-0.0 size=N/A time=00:14:30.27 bitrate=N/A speed=57.8x frame= 4001 fps=257 q=-0.0 size=N/A time=00:14:34.75 bitrate=N/A speed=56.2x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085263.ts' for writing frame= 4133 fps=257 q=-0.0 size=N/A time=00:14:39.14 bitrate=N/A speed=54.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085264.ts' for writing frame= 4266 fps=258 q=-0.0 size=N/A time=00:14:43.58 bitrate=N/A speed=53.4x frame= 4400 fps=258 q=-0.0 size=N/A time=00:14:48.06 bitrate=N/A speed=52.1x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085265.ts' for writing frame= 4534 fps=258 q=-0.0 size=N/A time=00:14:52.54 bitrate=N/A speed=50.8x frame= 4666 fps=258 q=-0.0 size=N/A time=00:14:56.93 bitrate=N/A speed=49.7x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085266.ts' for writing frame= 4797 fps=258 q=-0.0 size=N/A time=00:15:01.31 bitrate=N/A speed=48.6x frame= 4932 fps=259 q=-0.0 size=N/A time=00:15:05.81 bitrate=N/A speed=47.5x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085267.ts' for writing frame= 5063 fps=259 q=-0.0 size=N/A time=00:15:10.18 bitrate=N/A speed=46.5x frame= 5195 fps=259 q=-0.0 size=N/A time=00:15:14.58 bitrate=N/A speed=45.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085268.ts' for writing frame= 5329 fps=259 q=-0.0 size=N/A time=00:15:19.06 bitrate=N/A speed=44.7x frame= 5464 fps=259 q=-0.0 size=N/A time=00:15:23.56 bitrate=N/A speed=43.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085269.ts' for writing frame= 5597 fps=259 q=-0.0 size=N/A time=00:15:28.00 bitrate=N/A speed= 43x frame= 5732 fps=260 q=-0.0 size=N/A time=00:15:32.50 bitrate=N/A speed=42.3x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085270.ts' for writing frame= 5864 fps=260 q=-0.0 size=N/A time=00:15:36.91 bitrate=N/A speed=41.5x frame= 5999 fps=260 q=-0.0 size=N/A time=00:15:41.41 bitrate=N/A speed=40.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085271.ts' for writing frame= 6134 fps=260 q=-0.0 size=N/A time=00:15:45.92 bitrate=N/A speed=40.1x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085272.ts' for writing frame= 6267 fps=260 q=-0.0 size=N/A time=00:15:50.35 bitrate=N/A speed=39.5x frame= 6399 fps=260 q=-0.0 size=N/A time=00:15:54.77 bitrate=N/A speed=38.9x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085273.ts' for writing frame= 6534 fps=261 q=-0.0 size=N/A time=00:15:59.27 bitrate=N/A speed=38.3x frame= 6666 fps=261 q=-0.0 size=N/A time=00:16:03.66 bitrate=N/A speed=37.7x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085274.ts' for writing frame= 6798 fps=261 q=-0.0 size=N/A time=00:16:08.08 bitrate=N/A speed=37.1x frame= 6933 fps=261 q=-0.0 size=N/A time=00:16:12.58 bitrate=N/A speed=36.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085275.ts' for writing frame= 7067 fps=261 q=-0.0 size=N/A time=00:16:17.04 bitrate=N/A speed=36.1x frame= 7200 fps=261 q=-0.0 size=N/A time=00:16:21.48 bitrate=N/A speed=35.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085276.ts' for writing frame= 7334 fps=261 q=-0.0 size=N/A time=00:16:25.96 bitrate=N/A speed=35.1x frame= 7468 fps=261 q=-0.0 size=N/A time=00:16:30.44 bitrate=N/A speed=34.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085277.ts' for writing frame= 7603 fps=261 q=-0.0 size=N/A time=00:16:34.94 bitrate=N/A speed=34.2x frame= 7735 fps=261 q=-0.0 size=N/A time=00:16:39.33 bitrate=N/A speed=33.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085278.ts' for writing frame= 7869 fps=262 q=-0.0 size=N/A time=00:16:43.81 bitrate=N/A speed=33.4x frame= 8000 fps=262 q=-0.0 size=N/A time=00:16:48.19 bitrate=N/A speed= 33x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085279.ts' for writing frame= 8131 fps=262 q=-0.0 size=N/A time=00:16:52.56 bitrate=N/A speed=32.6x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085280.ts' for writing frame= 8265 fps=262 q=-0.0 size=N/A time=00:16:57.02 bitrate=N/A speed=32.2x frame= 8398 fps=262 q=-0.0 size=N/A time=00:17:01.46 bitrate=N/A speed=31.8x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085281.ts' for writing frame= 8532 fps=262 q=-0.0 size=N/A time=00:17:05.94 bitrate=N/A speed=31.5x frame= 8668 fps=262 q=-0.0 size=N/A time=00:17:10.46 bitrate=N/A speed=31.1x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085282.ts' for writing frame= 8800 fps=262 q=-0.0 size=N/A time=00:17:14.88 bitrate=N/A speed=30.8x frame= 8934 fps=262 q=-0.0 size=N/A time=00:17:19.33 bitrate=N/A speed=30.5x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085283.ts' for writing frame= 9062 fps=262 q=-0.0 size=N/A time=00:17:23.62 bitrate=N/A speed=30.2x frame= 9194 fps=262 q=-0.0 size=N/A time=00:17:28.02 bitrate=N/A speed=29.9x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085284.ts' for writing frame= 9328 fps=262 q=-0.0 size=N/A time=00:17:32.50 bitrate=N/A speed=29.6x frame= 9460 fps=262 q=-0.0 size=N/A time=00:17:36.89 bitrate=N/A speed=29.3x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085285.ts' for writing frame= 9594 fps=262 q=-0.0 size=N/A time=00:17:41.37 bitrate=N/A speed= 29x frame= 9727 fps=262 q=-0.0 size=N/A time=00:17:45.81 bitrate=N/A speed=28.7x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085286.ts' for writing frame= 9858 fps=262 q=-0.0 size=N/A time=00:17:50.18 bitrate=N/A speed=28.5x frame= 9990 fps=262 q=-0.0 size=N/A time=00:17:54.58 bitrate=N/A speed=28.2x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085287.ts' for writing frame=10122 fps=262 q=-0.0 size=N/A time=00:17:58.99 bitrate=N/A speed=27.9x frame=10255 fps=262 q=-0.0 size=N/A time=00:18:03.43 bitrate=N/A speed=27.7x [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085288.ts' for writing [segment @ 0000027de1b9e060] Opening 'C:\Users\Adrian\AppData\Roaming\MediaBrowser-Server\transcoding-temp\418c0713c2a1096613303e1f47724085.m3u8.tmp' for writing frame=10266 fps=262 q=-0.0 Lsize=N/A time=00:18:03.77 bitrate=N/A speed=27.7x video:55022kB audio:7930kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
AdrianW 1058 Posted October 19, 2017 Author Posted October 19, 2017 This is the same video that the the two sets of subtitles that I mentioned in the other thread. But it doesn't look like it was actually encoding the subs into the video.
ebr 16335 Posted October 19, 2017 Posted October 19, 2017 What kind of item is this in the Emby system? Is it classified as a trailer? Also, was the above when you had it set to Auto or 40Mb?
AdrianW 1058 Posted October 19, 2017 Author Posted October 19, 2017 What kind of item is this in the Emby system? Is it classified as a trailer? Also, was the above when you had it set to Auto or 40Mb? It's a TV episode. The output above was for Auto - but even after I changed it to 40Mb the ffmpeg log was identical and the server log still showed "max bitrate: 1500000".
ebr 16335 Posted October 19, 2017 Posted October 19, 2017 As a quick test, can you re-start the app (be sure and force-close it) and try that item again?
AdrianW 1058 Posted October 21, 2017 Author Posted October 21, 2017 @@AdrianW were you able to re-test this? Sorry, not yet.
AdrianW 1058 Posted October 21, 2017 Author Posted October 21, 2017 OK, just checked - it now direct plays. But, strangely I'm getting the small subtitles (high up on the screen) where previously I was getting two sets of subs - the small ones plus the ATV styled ones lower down. On the episode's detail screen there's a subtitle button where I can choose subs or not (it was preselected to show subs) - but if I bring down the details during playback the subtitle tab is missing (it was there previously).
ebr 16335 Posted October 21, 2017 Posted October 21, 2017 OK, just checked - it now direct plays. Okay, exactly where is this item from? Is it an IPTV channel or is it really an episode inside a series in Emby? The app thinks this is remote channel content so it is limiting the bitrate. But, strangely I'm getting the small subtitles (high up on the screen) where previously I was getting two sets of subs - the small ones plus the ATV styled ones lower down. On the episode's detail screen there's a subtitle button where I can choose subs or not (it was preselected to show subs) - but if I bring down the details during playback the subtitle tab is missing (it was there previously). What is the format of the subs and are they internal or external. The subtitle support in the Apple player is very limited which is why we have to have the way to select them externally.
AdrianW 1058 Posted October 21, 2017 Author Posted October 21, 2017 It's a TV episode stored locally on my NAS. The subs are external SRT, but I've seen the same thing with internally muxed SRT subs.
ebr 16335 Posted October 21, 2017 Posted October 21, 2017 It's a TV episode stored locally on my NAS. Can you invite me as a guest to your server and give me access to this item so I can look at what is really going on? The subs are external SRT, but I've seen the same thing with internally muxed SRT subs. The Apple player has no way of knowing about those subs because they are not a part of the video when we are direct playing them. Therefore, the only way to play them is to tell Emby you want them through the special playback menu. When the item is being transcoded, we can sometimes package up the subs and send them along with the video stream so that the player knows they are there. We can't do that when direct playing.
