legallink 187 Posted October 19, 2017 Posted October 19, 2017 See screen shot for "organize button" render error attached. Additionally, when I click on it, nothing happens.
ebr 16342 Posted October 19, 2017 Posted October 19, 2017 If you bring up the browser console, are there errors in it?
Luke 42253 Posted October 19, 2017 Posted October 19, 2017 Additionally, how to report a problem. Thanks ! While we're here I'd like to point out that auto-organize is a community addition, and contributions are welcome and encouraged. the source code for the plugin can be found here: https://github.com/MediaBrowser/Emby.AutoOrganize Thanks !
mutu310 70 Posted November 5, 2017 Posted November 5, 2017 Is this a good place to suggest an improvement in AutoOrganize? Basically, sometimes you may have a downloaded folder containing a movie file and a subtitle file, but while the movie file is renamed and moved, the subtitle file would be left over leaving one to have to manually rename it and move it. I know there's a "download missing subtitles" schedule but sometimes it doesn't find the subtitle or it's not properly in sync, so the one in the folder readily available is always going to be a better choice.
mutu310 70 Posted November 21, 2017 Posted November 21, 2017 Yes I think that's a good idea. Was it included in 1.1.4? *fingers crossed*
