Rozell365 0 Posted May 19, 2020 Posted May 19, 2020 How do I get a folder off of my cloud to add to emby library
Luke 42287 Posted May 20, 2020 Posted May 20, 2020 How do I get a folder off of my cloud to add to emby library Hi there, can you mount it as a local drive? Then add that local drive into emby.
raudraido 48 Posted October 24, 2020 Posted October 24, 2020 Emby server on windows won't let you add network share if server runs as service. Is it possible to resolve that?
pwhodges 2039 Posted October 24, 2020 Posted October 24, 2020 Specify a user login for the service. Paul
raudraido 48 Posted October 24, 2020 Posted October 24, 2020 (edited) 2 hours ago, pwhodges said: Specify a user login for the service. Paul Do you know that works or guessing? For me, it's not working Edited October 24, 2020 by raudraido
pwhodges 2039 Posted October 24, 2020 Posted October 24, 2020 (edited) Before I retired I was a network administrator for a couple of decades... There are many articles on the web that talk about this, e.g.: https://www.pdfblog.at/2011/06/windows-service-access-to-network-resources-what-to-consider/ or https://stackoverflow.com/questions/13268559/network-access-to-windows-service. Note there are some details to get right. Note in particular that @Luke's advice doesn't apply to a service - a service cannot use a mapped drive letter, but requires the UNC path. Paul Edited October 24, 2020 by pwhodges 2
raudraido 48 Posted October 24, 2020 Posted October 24, 2020 10 minutes ago, pwhodges said: Before I retired I was a network administrator for a couple of decades... There are many articles on the web that talk about this, e.g.: https://www.pdfblog.at/2011/06/windows-service-access-to-network-resources-what-to-consider/ or https://stackoverflow.com/questions/13268559/network-access-to-windows-service. Note there are some details to get right. Note in particular that Luke's advice doesn't apply to a service - a service cannot use a mapped drive letter, but requires the URI. Paul Oh, silly me. Ofcourse URI. Thanks, works!
Luke 42287 Posted October 24, 2020 Posted October 24, 2020 On Windows I don't recommend using mapped drives anyway, service or not. Windows will disconnect them when idle and that will prevent Emby from being able to use them.
AlexanderV 0 Posted July 20, 2022 Posted July 20, 2022 On 24/10/2020 at 8:02, pwhodges said: Antes de jubilarme, fui administrador de red durante un par de décadas... Hay muchos artículos en la web que hablan de esto, por ejemplo: https://www.pdfblog.at/2011/06/windows-service-access-to-network-resources-what-to-consider/ o https:/ /stackoverflow.com/questions/13268559/network-access-to-windows-service . Tenga en cuenta que hay algunos detalles para hacerlo bien. Nótese en particular que@LucasEl consejo de no se aplica a un servicio: un servicio no puede usar una letra de unidad asignada, sino que requiere la ruta UNC. Pablo Gracias, tambien funciono para mi.
