Paxalou 4 Posted October 19, 2017 Posted October 19, 2017 (edited) Bonjour, J'utilise la dernière version de Emby Server, sur Debian Stretch. J'utilise Emby Web Player, et parfois, le film démarre, mais le cercle de chargement reste présent pendant la lecture, et l'interface de navigation (qui permet de choisir les sous-titres, la piste audio, et qui montre la progression de la lecture en cours) n'apparaît pas. Comme ceci : Et parfois, la lecture se déroule tout à fait normalement. Je n'arrive pas à comprendre de quoi cela vient. Pouvez-vous m'aider ? Log1.txt Edited October 19, 2017 by Paxalou
Luke 42239 Posted October 19, 2017 Posted October 19, 2017 Hi, are there any errors in the browser console?
Paxalou 4 Posted October 19, 2017 Author Posted October 19, 2017 J'ai un avertissement JS : Impossible de lire le média. Aucun décodeur pour les formats nécessaires : application/x-mpegURL, application/vnd.apple.mpegURL
Paxalou 4 Posted October 19, 2017 Author Posted October 19, 2017 Firefox 56.0 Mais j'ai l'avertissement JS aussi quand la lecture marche bien....
Paxalou 4 Posted October 23, 2017 Author Posted October 23, 2017 (edited) Ok, j'ai fait ça, mais c'est pire... Le film ne démarre même pas...le cercle de chargement tourne sans cesse, et rien ne se passe... OK I did that, but it's worse...The movie doesn't even start...the loading circle is turning round forever... and nothing else happens EDIT : Il semble que ce problème ne se produise qu'avce les films récemment ajouté (moins d'une heure). It seems that this problems occurs only with recently added movies (less than one hour). Edited October 23, 2017 by Paxalou
Luke 42239 Posted October 27, 2017 Posted October 27, 2017 @@Paxalou Is this still an issue? Have you updated to the latest release, 3.2.34? Thanks !
Paxalou 4 Posted October 27, 2017 Author Posted October 27, 2017 Yes, it is still an issue, but I have to update to 3.2.34.
Paxalou 4 Posted October 29, 2017 Author Posted October 29, 2017 I made the update, and it seems to be better. But I have to try further to be sure.
