Tuner not released after recording
Guest asrequested
I've just started having this happen. I have 2 primes. 6 tuners and they never all get used or 'over booked'. One tuner is stuck on, right now. I have to restart the server to release it.
What makes you think it's stuck on?
Guest asrequested
I see the tuner light on long after the recording has ended and the server reports it in use.
maegibbons
Hmmm looking at the logs the recording of channel 705 completed nornally and the hdhr stream was closed.
Earlier in the evening you had quite a few steam openings for Live TV on channels 702 and 703.  Are you sure that one of those devices running Live TV was still not connected to the stream.
i.e i do not think it was the recording that hung the Tuner up.  I think it was one of the live TV streams.
If it happens again check directly on the HDHR which channel is actually tumed in.  It will help to debug.what is actually holding the tuner.
Krs
Mark
Guest asrequested
All but one of those streams were recordings, too. It isn't watching live TV that caused this, as the tuner turns off. This leaves only one option. One the recordings.
maegibbons
Thats not true as per the log.  There was a recording at 8pm and one at 9pm.
Live stream was opened at 18:36, 18:51, 18:52, 18:53, 18.54, 18:55, 19:00, 19:04, 19:06, 19:53 and others. (Looks like they were all chan 702)
I am only going from what is in the logs.  You may have had an error condition.
However, i will leave you to it.
Krs
Mark
Guest asrequested
Oh I forgot I was testing the DXVA2 issue. But I did record several shows. I'll try to be more diligent, when it happens next time.
