Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Can you setup this portable version and compare: https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/embyserver-win-x64-3.2.33.0.7z Thanks. Hi, just started to setup and it wants to update to 3.2.34.0, I presume you don't want me to do that?
Nathanio 35 Posted October 24, 2017 Author Posted October 24, 2017 Please see attached. It didn't work but different errors Emby_33_LiveTV.txt
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Can you setup this portable version and compare: https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/embyserver-win-x64-3.2.33.0.7z Thanks. Yeah same as Nathanio, it tried but produced different errors : The remote server returned an error: (400) Bad Request.
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 I think it's actually the same error but that version of the server is just logging it differently.
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Can you now compare to this one? https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/emby.windows.zip Thanks.
Nathanio 35 Posted October 24, 2017 Author Posted October 24, 2017 Can you now compare to this one? https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/emby.windows.zip Thanks. Doing now
Nathanio 35 Posted October 24, 2017 Author Posted October 24, 2017 Can you now compare to this one? https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/emby.windows.zip Thanks. This one worked (please see attached). I have a full guide Version 3.2.33.0.log 1
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Can you now compare to this one? https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/emby.windows.zip Thanks. Success
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Ok, now try this one: https://github.com/MediaBrowser/Emby/releases/download/3.2.34.0/emby.windows.zip Thanks.
Nathanio 35 Posted October 24, 2017 Author Posted October 24, 2017 Success. Please see attached 3.2.34.0.log
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Ok, now try this one: https://github.com/MediaBrowser/Emby/releases/download/3.2.34.0/emby.windows.zip Thanks. Success again, still lots of errors in log.
Nathanio 35 Posted October 26, 2017 Author Posted October 26, 2017 Hi Luke, Do you have any ideas whether you will be able to fix it for us older OS folk or whether we'll need to update? Ta
Luke 42237 Posted October 26, 2017 Posted October 26, 2017 yea stay on the beta server and hopefully we can resolve it there. thanks. 1
Nathanio 35 Posted October 27, 2017 Author Posted October 27, 2017 yea stay on the beta server and hopefully we can resolve it there. thanks. Thanks Luke
Latchmor 584 Posted October 27, 2017 Posted October 27, 2017 yea stay on the beta server and hopefully we can resolve it there. thanks. Hi, you probably didn't try anything yet but still the same DEFLATE errors on 3.2.34.1 beta. Cheers
Luke 42237 Posted October 27, 2017 Posted October 27, 2017 Can you install fiddler and monitor the outgoing http request?
Nathanio 35 Posted October 28, 2017 Author Posted October 28, 2017 You guys are both on windows 7? Windows home server 2011 which is based on server 2008 which is Win7 core. What is fiddler as never used it
Nathanio 35 Posted October 28, 2017 Author Posted October 28, 2017 Hi Luke, I think that is now working, Just running again to confirm 1
Latchmor 584 Posted October 28, 2017 Posted October 28, 2017 First try the 3.2.34.2 beta. thanks. Hi, working again this morning but some channels being stubborn for some reason. ITV2, More 4 and Film4 are some that are still blank. Cheers
Latchmor 584 Posted October 28, 2017 Posted October 28, 2017 Hang on, instead of being here They are all down the bottom with different numbers There are 10 channels down the bottom from 5000 to 5009. No idea what's going on there. Cheers
maegibbons 1287 Posted October 28, 2017 Posted October 28, 2017 Hi i have had the 5000 thing before. Cannot remmber what fixed it. but try the following in order. 1. Update HDHR firmware. 2. Retune HDHR- Check channel numbers directly on the device 3. Delete and re-setup HDHR tuner in Emby Krs Mark
